Test & Tools
Test & Tools
Blog Sound and Vibration Measurement: MCC172 DAQ Hat - analogue front end
  • Date Created: 11 Apr 2022 1:02 PM Date Created
  • Views 2195 views
  • Likes 8 likes
  • RoadTest
  • mcc172
  • adc
11 Apr 2022
For the Sound and Vibration Measurement Hat for Raspberry Pi road test, I'm reviewing Measurement Computing's IEPE Measurement DAQ HAT for Raspberry Pi. In this little breakout post: the analogue front end.
In a previous post, I checked the hat's components, and found these ICs at the analogue side:
  • Input buffer: 2 channel OPA2277U OpAmp.
  • Then a  THS4531A differential amp per channel.
  • ADC: a differential ADS1271 per channel
The hyperlinks point to the datasheets.
The simplified schematic could be this:
Link to all posts.
    Jan Cumps over 4 years ago
    Probe, 50 Hz, 1 Vpp. Yellow is input signal at channel 0, blue is probe point:
    Output OPA2774
    output + THS4531
    output - of the same IC :
    ADC AIN +
    and AIN- :
    User action photo: probing with the right hand, taking a photo with the left one:
    I've been probing if the analysis above makes sense. I think it's correct: Channel input appears inverted after the buffer, then differential on both diff-amp outputs, then differential on ADC inputs AIN+ and AIN-
