Test & Tools
Test & Tools
Forum Diode identification and car radio repair
  • Replies 14 replies
  • Subscribers 387 subscribers
  • Views 6918 views
edumcg
edumcg over 6 years ago
I'm trying to repair my nissan car radio model: Clarion BTS33
The problem began when the fuel volumen line of my car shortcircuited with 12V.  As soon as that happened my radio turned off and never came back again. I sent the radio with some folks to repair it, they replaced some ICs that were burned out but they couldn't replace one specific diode.
Right now, when I plug the radio into my car only the screen shows up but it prints nothing. Just a blank orange screen. No audio output no matter what buttons I press.
I found the cable on Amazon: https://www.amazon.com/20-pin-Subaru-Headunit-Harness-Steering/dp/B01D9K3L44
I also found the user manual of the radio: https://fccid.io/2ABGYBTS33-CLARION/User-Manual/User-guide-2150158
The only component that looks burned out is the diode D402. The diode is the same as de diode D403 so I can see the marking is "C308" the 08 is fllipped to the right 90 degress.
My plan is to replace the diode but I haven't been able to find a datasheet.
I've attached images of the radio and the circuit board. Any help would be appreciated.
Thanks!
  • colporteur
    colporteur over 6 years ago in reply to MDeGrauw +3
    Well now, would you lookie there. Thanks MdG & JC, I learned something. SOT-23 packaging never existed before my absenteeism from electronics. I noticed the more bright members ignored my comments and…
  • fiddler_in_the_lab
    fiddler_in_the_lab over 6 years ago +2
    I would not have to high hopes that replacing that diode will fix the problem.... but as it is an easy thing to do if you (or a friend) have a multimeter and basic soldering skills. So it sure is worth…
  • msbettyhunt
    msbettyhunt over 6 years ago in reply to fiddler_in_the_lab +2
    It is a good idea of replacing the diode with the general purpose diode. Hope it will work.
  • MDeGrauw
    MDeGrauw over 6 years ago in reply to colporteur
    I don't want to ruin your day but at a quick glance at Farnell website I find hundreds of SOT-23 style diodes.
  • colporteur
    Well now, would you lookie there. Thanks MdG & JC, I learned something. SOT-23 packaging never existed before my absenteeism from electronics. I noticed the more bright members ignored my comments and continued to troubleshoot the problem. Your comment motivated me to look at my PCB engineering ruler and sure enough there is an SOT-23 layout listed.
    If I had of spent as much time investigating as drawing the circles on the picture I might have found out about the diode packaging. Thanks for the share. My day is still intact.
  • edumcg
    edumcg over 6 years ago in reply to fiddler_in_the_lab
    I did the diode test with a multimeter and these are my results:
    I don't know if the diode marked with a orange  may be faulty since the reading was the same when exchanging the positive and negative probes of my multimeter.
    The one marked by a yellow box is surely a common cathode. Both have the same marking code.
    I'm gonna get a general purpose diode with the same characteristic and replace both of them. One at a time.
    Thanks for posting.
  • flcs2020
    flcs2020 over 6 years ago
    you can try to check smd marking codes (topmark)on this website www.marking-codes.com
