Test & Tools
Test & Tools
Forum Mystery Part  What is it?
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 386 subscribers
  • Views 1807 views
jw0752
jw0752 over 11 years ago
While salvaging a board marked as an Auto Focus Servo I came across this component the likes of which I have never seen before. It is marked with the following numbers: 16 0M 9330SMI. It is identified as Y1 on the print layer of the board. It has 2 visible contacts along the edges. I have not removed it yet to see if there are more underneath. The front of the component is clear glass. Inside the window I can see what looks like a golden mirror with two legs that come down and make contacts. This is for my curiosity so it isn't very important but if anyone knows what it is let me know. Photos are attached.
    jw0752 over 11 years ago in reply to shabaz +1
    Hi Shabaz, Thanks for the insight into this part. You are right it is a little bit older, I would guess 10 years at least and from the construction of the board and the other components used perhaps a…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    probably a 16Mhz Xtal as part of an oscillator
    Crystals / resonators are typically marked with a Y, in this case Y1, the 16.0M is probably the frequency
    It is unusual to be clear but kind cool
    0 jw0752 over 11 years ago in reply to Robert Peter Oakes
    Hi Peter,
    I actually didn't see the decimal point in the 16 . 0 until I had posted it. You are probably correct as it is wired with caps to ground on each leg just like traditional crystals. Can you think of any reason why they would have exposed the crystal? Does light affect the crystal?
    0 shabaz over 11 years ago in reply to jw0752
    Hi John!
    I have not seen one like that in a while, but it does look familiar. It's something to do with the manufacture/quality of the product, I'm guessing some factories were better at making reliable crystals with a glass enclosure,
    whereas cheaper ones had metal cans and the crystal just hanging in mid-air - I remember taking some apart!). So you've probably got a crystal which is old but was a high quality part for its time.
    Nowadays I'm sure things have changed due to process improvements, and many crystals have metal or ceramic enclosure and looks alone would not indicate as much.
    0 jw0752 over 11 years ago in reply to shabaz
    Hi Shabaz,
    Thanks for the insight into this part. You are right it is a little bit older, I would guess 10 years at least and from the construction of the board and the other components used perhaps a little better quality too. When I get the chance I am going to hook it up in a simple oscillator circuit like we discussed a couple weeks ago and hit the crystal with a laser to see if the oscillation is affected. As you said it is probably just a neat way to package but the window peaks my curiosity about a light connection.
    based on the second code I would suggest it is a 1993 year and week 30, based on typical part numbering convention of the time
    Regards
    Peter
    Hi Peter,
    That makes it twice as old as my guess which was an estimate of the age of the piece of equipment it was in.
  • johnbeetem
    0 johnbeetem over 11 years ago
    I'd never seen a crystal package like that before.  I did a little research and I think it's a "ceramic surface-mount crystal with glass lid", which you can google for vendors and images.
    I don't know what the advantage of such a package would be.  From the age of the equipment, one theory could be that very few crystals at the time could withstand the heat of reflow soldering.  IIRC, it used to be that most crystals needed to be added as through-hole devices, usually hand-soldered.  OTOH, they had to solder the connector anyway, so might as well use a through-hole crystal.  Maybe the ceramic package has better stability.
  • johnbeetem
    0 johnbeetem over 11 years ago in reply to jw0752
    John Wiltrout wrote:
    Hi Peter,
    Maybe some purchasing agent got a good deal on some really old stock that nobody else wanted to buy :-)
    0 jw0752 over 11 years ago in reply to johnbeetem
    Hi John,
    Thanks for the good information. I will google the Ceramic Surface Mount Crystal as you recommend.
  • D_Hersey
    0 D_Hersey over 11 years ago
    https://www.fairchildsemi.com/datasheets/CD/CD4060BC.pdf
    page3
    second figure
