Test & Tools
Test & Tools
Documents Fluke Linecard
  • Author Author: Yiying
  • Date Created: 29 Nov 2012 3:26 AM Date Created
  • Last Updated Last Updated: 7 Mar 2014 9:01 PM
  • Views 667 views
Fluke Linecard
Digital Multimeters (DMM)Back to Top
Product Series
ModelsMeasurementsResolution DigitsDC AccuracyDescription
884xA
8845A8845A
8846A8846A
AC/DC Voltage, AC/DC Current, Resistance, Frequency & Period, Continuity/ Diode Test6.5 Digits
The Fluke 8845A8845A and 8846A8846A 6.5 digit precision multimeters have the precision and versatility to handle your most demanding measurements, on the bench or in a system. These meters are both high performance and feature rich, yet also remarkably easy to use.Learn More
8808A8808A8808A8808AAC/DC Voltage, AC/DC Current, Resistance, Frequency, Math functions, Limit compare test, with pass and fail indicators5.5 Digits
The Fluke 8808A8808A multimeter has a broad range of functions, measuring volts, ohms and amps with a basic V dc accuracy of 0.015 %. It is remarkably easy to use, even by unskilled operators, because it makes the measurements you perform most often extremely easy and fast to do. Learn More
287 / 289
FLUKE-287FLUKE-287
FLUKE-289FLUKE-289
AC/DC Voltage, AC/DC Current, Resistance, Frequency, Capacitance, Temperature (excludes probe)1 μV
The Fluke 287/289 true-RMS digital multimeters were designed for those of you at the top of your field. The instruments replace popular 180 Series, with all the same features, plus more. The two multimeters perform advanced unattended data logging, and show trend data on screen without having to download to a PC.Learn More
