Experimenting with Vibration Sensors
  • Experimenting with Vibration Sensors
Blog Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #7 (Final Conclusion)
  • Author Author: zst123
  • Date Created: 20 Jan 2021 1:23 PM Date Created
  • Views 792 views
zst123
zst123
20 Jan 2021
Final thoughts
As the competition comes to a close, these are my final thoughts...
I feel this sensor is well-suited for many applications such as industrial IoT and field devices. Because of its high sensitivity, I am able to sense the vibrations easily from my hard disk experiment. Although at a hobbyist level, it may be a hard decision due to the high price.
In my experiments, I have only done FFT analysis. But the possibilities are endless and it is up to the user's imagination to interpret and do analysis on the data. I have learnt about different techniques, such as anomaly detection and machine learning models, by reading what tools are used by other participants.
Thank you again element14 and the sponsor Kemet for giving me this opportunity. Thank you also to the other participants for your contributions.  I have learnt a lot from the process and from other people too! It has been a fun experience as my first Design Contest here and I hope to see you again next time.
Summary of my posts
Short Self-Introduction
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #1
Unboxing of Vibration Sensor Kit
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #2 (Introduction & Unboxing)
Experiment 1 – Initial Setup & Tapping Experiment
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #3 (Initial Setup & Tapping Experiment)
Experiment 2 – Detect Spinning Fan Obstructions
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #4 (Detect Spinning Fan Obstructions)
Experiment 3 – Fourier Transform Analysis to find RPM
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #5 (Fourier Transform Analysis to find RPM)
Experiment 4 – FFT Dashboard with Mbed DSP
Experimenting with Vibration Sensors - Characterize RPM of Spinning Devices #6 (FFT Dashboard with Mbed DSP)
