Project Videos
  • Project Videos
Project Videos
Documents 4D Gaming with the MATRIX Creator -- Episode 376
  • Date Created: 19 Dec 2018 3:01 AM Date Created
  • Last Updated Last Updated: 11 Jan 2019 8:24 AM
  • Views 2688 views
element14 presents  | Raising Awesome's VCP Profile    |  Project Videos
Sean and Connor from Raising Awesome have been looking for a project that would establish a full suite of PCB Eagle Design Blocks and IoT code for a multitude of platforms for future projects.  Then, Connor burned through all his lawn mowing money on an Oculus Rift.  Using it gave them an idea - what if instead of going into the game world, the game comes to our world!  So, they set out to build their most ambitious IoT build to date - the 4D IoT Game Engine.  .
Supplemental Content:
  • 4D IoT Game Engine Blog
  • Home Automation Mojo You Must Know Part 1
  • Home Automation Mojo You Must Know Part 2: Notification
  • Home Automation Mojo You Must Know Part 3: Environmental Awareness
  • Home Automation Mojo You Must Know Part 4:  Actuation
  • Home Automation Mojo You Must Know Part 5:  The House Hub
Bill of Material:
PartQuantityBuy Kit
MATRIX Creator
2Buy Now
Raspberry Pi 3 Model B+
1Buy Now
Arduino MKR1000 Without Pin Headers1Buy Now
Breakout Board, ESP8266 Wifi Module, Serial Transceiver, 1MB Flash 5Buy Now
General Purpose Relay, SRM Series, Power, Non Latching, SPDT, 5 VDC, 10 A3Buy Now
Linear Voltage Regulator, Fixed, Positive, 7.5V To 35V In, 5V And 1A Out, TO- 220-35Buy Now
Linear Voltage Regulators, Fixed, 5.3V To 25V In, 3.3V And 0.5A Out, TO- 220-35Buy Now
Optocoupler, Transistor Output, 1 Channel, DIP, 4 Pins, 50 mA, 5 kV, 50 %1Buy Now
Bipolar (BJT) Single Transistor, NPN, 30 V, 100 MHz, 625 mW, 800 mA, 100 hFE 5Buy Now
Standard Recovery Diode, General Purpose, 400 V, 1 A, Single, 1.1 V, 30 A5Buy Now
MOSFET Transistor, P Channel, 7 A, -60 V, 0.41 ohm, -10 V, -4 V5Buy Now
Prototyping Board, Small PC, 25 Rows2Buy Now
Prototype Board, Phenolic, 1.6 mm, 72 mm, 47 mm2Buy Now
STRIPBOARD, FR2, 100X160MM2Buy Now
Jumper Wire Kit, Multicolor, 2 mm - 125 mm, 22 AWG, 350 Piece 2Buy Now
Motor Driver/Controller, Half-H, 4.5V to 36V supply, 36V/600 mA/4 Outputs, DIP- 162Buy Now
  • raspberry pi 3 b plus
  • linear voltage regulators
  • arduino mkr 1000
  • optocoupler
  • e14presents_raisingawesome
  • mosfet transistor
  • sean miller
  • friday release
  • 4d gaming engine
  • matrix creator
  • standard recovery diode
  • friday_release
    DAB over 7 years ago +1
    I love this design approach. Use all opensource software, add a few bits of hardware and you have a basic system to set up just about any interactive environment. Well done. DAB
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to DAB +1
    Thanks, DAB. You are right - with the Unity game engine, you could make a 2D or 3D interface that can generate a build for just about anything - Xbox, PS4, iPhone, , Android, Windows, Linux, etc. Using…
  • Sean_Miller
    Sean_Miller over 7 years ago in reply to shabaz +1
    Thanks, Shabaz. As for the TV program, my dream would be to do an HGTV show where we go in and create assistive tech solutions throughout a home to help the elderly and impaired. It would be one of those…
    Well done.
  • Sean_Miller
    Thanks, DAB.
    You are right - with the Unity game engine, you could make a 2D or 3D interface that can generate a build for just about anything - Xbox, PS4, iPhone, , Android, Windows, Linux, etc.  Using similar Web Socket code showcased, you can then control any wifi enabled mechanical gadget you make from anywhere on earth.
    Learning all this makes the world seem simpler and simpler.  When dreaming up gizmos, I find it amazing how little there is left to make our lives even more convenient.  I think that autonomous lawnmower may be in my future after all.
    See ya',
    Sean
  • Sean_Miller
    Thanks, DAB.
    See ya',
    Sean
