The Learning Circuit
  • The Learning Circuit
Documents How Transistors Work -- The Learning Circuit 27
  • Date Created: 8 Oct 2018 4:06 PM Date Created
  • Last Updated Last Updated: 24 Oct 2018 7:24 AM
  • Views 12340 views
  • Likes 12 likes
  • Comments 27 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In today's Episode Karen discusses transistors. Rather than using a physical, mechanical switch, a transistor can act as an electronic switch, using signals to turn it on or off.  She'll go over what they are, how they work, and some types of transistors.  She'll cover Bipololar junction transistors (BJT), NPN transistors, PNP transistors, and darlington transistors.
The Learning Circuit 37: Community Feedback: Revisiting Transistors
Transistors eBook Part 1
  • stem_projects
  • tlc
  • vbe
  • mosfets
  • base-emitter voltage
  • e14presents_makerkaren
  • switches
  • pnp transistors
  • circuit
  • jfet
  • field-effect transistors
  • battery
  • npn transistors
  • collector-emitter voltage
  • vce
  • diodes
  • darlington transistors
  • thelearningcircuit
  • darlington pair
  • jc2048
    jc2048 over 7 years ago +5
    There's some good information in this episode but there are a few things I think you might want to review. 4:24 "Leaving 8.3V as your VCE." The VCE with the transistor on, assuming that there's enough…
  • Sean_Miller
    Sean_Miller over 8 years ago +4
    Great stuff. The graphics add a lot for understanding. -Sean
  • jc2048
    jc2048 over 7 years ago in reply to jc2048 +4
    Anyone looking at this episode might like to know that Karen and James Lewis revisted this topic in The Learning Circuit 37: Community Feedback: Revisiting Transistors so it's worth watching that one too…
    Jan Cumps over 5 years ago in reply to shabaz
    shabaz  wrote:
    Also, a really good book that covers it in an easy yet quite thorough way, is 'The Art of Electronics', ...
    Page 81 image
    image source: my copy. Fair use.
    shabaz over 5 years ago in reply to mkubiak
    Hi Matt,
    Also, a really good book that covers it in an easy yet quite thorough way, is 'The Art of Electronics', either 2nd or 3rd edition is fine (a used 2nd edition may be cheaper, and it's just as good as the third edition). It contains many pattern layouts, all practical, but the authors explain them really well too.
    Hi Matt,
    The biasing is altered by the change of topology and resistances. Transistors have an analog behavior that does not extend linearly in every direction and topology, nothing is symmetrical when using them, they are not like mechanical switches which can have parts swapped onto either side etc. They need to be deployed in known patterns (this will be in the video, it's been a while since I've seen it, but I'm sure it is there), otherwise the behaviour changes.
    You can see the voltage and current flowing in each of the three legs, to get a very good idea what is occurring, provided you're OK with Ohm's Law and diode drops, by building up this circuit in a simulator, e.g. Falstad. There is an example here, but you can modify it and monitor the behaviour: https://www.falstad.com/circuit/e-transswitch.html
    Jan Cumps over 5 years ago in reply to mkubiak
    Check Shabaz' schema 2.
    You have 3 issues:
    There's a 1K resistor in the emitter path. It is no longer a switch now, but a amplifier with negative feedback.
    There is no resistor in the base path (say: 1 KOhm).
    There is no series resistor for the LED (say: 330 Ohm)
  • mkubiak
    mkubiak over 5 years ago in reply to shabaz
    Thank you that link is very helpful! This is the set up I had that would not activate the transistor. I see what I did was not conventional, but why didn't it work?image
    Hi Matt,
    As Jan says, the base resistor should not be omitted, and there is no minimum voltage between collector and base, so 3.3V can be used too.
    These are from the 'output design tips' section here:
    Raspberry Pi GPIO Explained
    Do you have a resistor (say: a few kiloOhm) between the GPIO output and the base?
    Else things will go wrong.
  • mkubiak
    I'm fooling around on a breadboard with the GPIO pin from a RPi.
    I attach the collector of a standard NPN BJT to the 3.3V power pin of the pi, the emitter to the Ground Pin. But when I command 3.3V out of the GPIO to the base, the transistor stays off.
    But when I change the collector to the 5V pin, then the 3.3V from the GPIO pin activates the transistor.
    Is there some minimum voltage difference needed between the collector and base in order for the transistor to activate?
  • gaurav30
    gaurav30 over 5 years ago
    You wrongly represented diode symbol in the video. Current flow in diode is from P to N.
  • miles90
    miles90 over 5 years ago in reply to makerkaren
    Will you please work on transistor biasing and amplifiers (class A, B, C, D amplifiers ...) ? That would be great.
