Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog Connecting the Tree to the Internet
Join Merry Boxes & LEDs to participate - click to join for free!
  • Author Author: ntewinkel
  • Date Created: 2 Jan 2019 6:30 AM Date Created
  • Views 3431 views
  • Likes 10 likes
  • Comments 6 comments
  • wifi
  • mqtt
  • merryboxesledsch
  • holidayspecial19ch
  • xmas
  • esp8266
ntewinkel
ntewinkel
2 Jan 2019
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Project14 Home
Monthly Themes
Monthly Theme Poll
I made some headway today, and was able to wire up one of the XMas trees to one of the Wemos boards.
Initial testing went well - it looks like the lights are properly controlled the way I had intended (hooray!).
However, the motion sensor is not doing the right thing yet, so I'll have to work on that.
edit: I think I might have found the issue (will test tomorrow) - line 77 sets the motion sensor input as "INPUT_PULLUP" like a regular button, but the PIR module should already handle that, so it probably should just be "INPUT". edit again: Sadly that wasn't the problem. I'll test it separately later.
I have the wires and the transistors just soldered together dead-bug style to keep things simple.
Once it all works I'll give the exposed bits a nice coat of... you guessed it... nail polish!
And then I need to somehow tuck the wires and board into a neat little finished package.
I made a little video showing my progress so far.
I'm using a Witty Wifi as the other tree. pressing the button simulates the motion detected, and the different LEDs simulate the tree.
Sorry about the video, I took it in portrait mode LIKE A BARBARIAN! (no offence intended to barbarians).
Here is a screenshot that shows the online MQTT client I also used for testing. It's super handy for this kind of thing!
You can see the debug info in the serial console too.
Since it looks like the software is ok for the most part (it may need a tweak for the motion detector), I've published it on GitHub, including the version that runs on the Witty for testing.
https://github.com/ntewinkel/electronics/tree/master/ConnectedXMasTrees
Cheers,
-Nico
Previous posts:
Connected Christmas Trees
Assembling the Trees
Finally! Two Trees Assembled
Two Trees by a Tree
Next posts:
Motion Sensor on Wemos
Trees! one with motion sickness...
Motion Sensor Issues, continued
The Connected Trees are Working!
Merry Boxes - A Project Within a Project
Connected Christmas Trees - Finished!
    genebren over 7 years ago +2
    Nice update on your connected trees project. Hopefully your testing will find that you have solved your motion sensing problem. Good luck on wrapping up this project! Gene
    mcb1 over 7 years ago +2
    ntewinkel Not that the english is particularilyt good, but it looks like the output goes high when it is triggered. Many of them have an open collector so they go low when triggered. The PCB has the option…
  • ntewinkel
    ntewinkel over 7 years ago in reply to genebren +1
    Thanks Gene! > Hopefully your testing will find that you have solved your motion sensing problem. Unfortunately it wasn't the simple software fix I had hoped for. I'll have to try just the motion sensor…
    Gene
