Open Arduino
  • Open Arduino
Open Arduino
Blog Arduino in Test Instrumentation - Part 2: Firmware
Join Open Arduino to participate - click to join for free!
  • Date Created: 6 Apr 2018 9:13 PM Date Created
  • Views 5016 views
  • Likes 9 likes
  • Comments 8 comments
  • diytestequipch
  • ardexpert
  • openarduinoch
  • scpi
  • arduino_test_instrumentation
6 Apr 2018
Open Arduino
Enter Your Project for a chance to win a grand prize for the most innovative use of Arduino or a $200 shopping cart! The Birthday Special: Arduino Projects for Arduino Day!
Project14 Home
Monthly Themes
Monthly Theme Poll
To celebrate Project 14's birthday, I'm going to make a programmable switch with an Arduino UNO.
This post describes the firmware and SCPI api.
SCPI Commands
The instrument supports the following commands:
CommandDescriptionExample
*IDN?instrument identity
*IDN?
element14,Arduino SCPI Switch,1,0
*RSTreset instrument. Set all switches off*RST
*CLSsame as *RST*CLS
:DIGITAL:SWITCH# ON|OFFturn a switch on or off. 1 based:DIGI:SWIT1 ON
:DIGITAL:SWITCH#?get a switch' status. 1 based
:DIGITAL:SWITCH1?
OFF
Firmware
Here's a link to the GIST: https://gist.github.com/jancumps/9573730e7bac392efcdbfa24e722bf4d#file-scpiswitch-ino
I don' know what's wrong with element14's code highlighter these days, but it fails to show #includes with angle brackets.
The first two lines are:
#include <scpiparser.h>
#include <Arduino.h>
#include
#include
#define NUMBEROFCHANNELS 2
struct scpi_parser_context ctx;
scpi_error_t identify(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t reset(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t get_digital_1(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t get_digital_2(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t set_digital_1(struct scpi_parser_context* context, struct scpi_token* command);
scpi_error_t set_digital_2(struct scpi_parser_context* context, struct scpi_token* command);
bool bDigital [NUMBEROFCHANNELS] = {};
int  iPins [NUMBEROFCHANNELS] = {2,3};
void setup() {
  struct scpi_command* digital;
  int i = 0;
  Serial.begin(38400);
  for (i = 0; i < NUMBEROFCHANNELS; i++) {
    pinMode(iPins[i], OUTPUT);
    digitalWrite(iPins[i], LOW);
  /* First, initialise the parser. */
  scpi_init(&ctx);
   * After initialising the parser, we set up the command tree.  Ours is
   *  *IDN?         -> identify
   *  *RST          -> reset
   *  :DIGI
   *    :SWIT1    -> channel 1
   *    :SWIT2    -> channel 2
  scpi_register_command(ctx.command_tree, SCPI_CL_SAMELEVEL, "*IDN?", 5, "*IDN?", 5, identify);
  scpi_register_command(ctx.command_tree, SCPI_CL_SAMELEVEL, "*RST", 4, "*RST", 4, reset);
  scpi_register_command(ctx.command_tree, SCPI_CL_SAMELEVEL, "*CLS", 4, "*CLS", 4, reset);
  digital = scpi_register_command(ctx.command_tree, SCPI_CL_CHILD, "DIGITAL", 7, "DIGI", 4, NULL);
  scpi_register_command(digital, SCPI_CL_CHILD, "SWITCH1?", 8, "SWIT1?", 6, get_digital_1);
  scpi_register_command(digital, SCPI_CL_CHILD, "SWITCH2?", 8, "SWIT2?", 6, get_digital_2);
  scpi_register_command(digital, SCPI_CL_CHILD, "SWITCH1", 7, "SWIT1", 5, set_digital_1);
  scpi_register_command(digital, SCPI_CL_CHILD, "SWITCH2", 7, "SWIT2", 5, set_digital_2);
void loop() {
  char line_buffer[256];
  unsigned char read_length;
  while(1)   {
    /* Read in a line and execute it. */
    read_length = Serial.readBytesUntil('\n', line_buffer, 256);
    if(read_length >0)
      if(line_buffer[read_length-1]=='\r')  // thank you jon clift
        read_length = read_length - 1;    if(read_length > 0)     {
      scpi_execute_command(&ctx, line_buffer, read_length);
 * Respond to *IDN?
scpi_error_t identify(struct scpi_parser_context* context, struct scpi_token* command) {
  scpi_free_tokens(command);
  Serial.println("Project14,Arduino SCPI Switch,1,0");
  return SCPI_SUCCESS;
 * Respond to *RST and *CLS
scpi_error_t reset(struct scpi_parser_context* context, struct scpi_token* command) {
  int i = 0;
    bDigital[i] = 0;
scpi_error_t get_digital(int channel, struct scpi_parser_context* context, struct scpi_token* command) {
  if (bDigital[channel] ) {
    Serial.println("ON");
  } else {
    Serial.println("OFF");
 * get digital 1 status
scpi_error_t get_digital_1(struct scpi_parser_context* context, struct scpi_token* command) {
  return get_digital(0, context, command);
 * get digital 2 status
scpi_error_t get_digital_2(struct scpi_parser_context* context, struct scpi_token* command) {
  return get_digital(1, context, command);
scpi_error_t set_digital(int channel, struct scpi_parser_context* context, struct scpi_token* command) {
  struct scpi_token* args;
  bool bSuccess = false;
  bool bSwitch = false;
  args = command;
  while(args != NULL && args->type == 0) {
    args = args->next;
  if (args->length == 1) {
    if (args->value[0] == '0') {
      bSuccess = true;
    if (args->value[0] == '1') {
      bSuccess = true;
      bSwitch = true;
  if (args->length == 2) {
    if ((args->value[0] == 'O') || (args->value[0] == 'o')) {
      if ((args->value[1] == 'N') || (args->value[1] == 'n')) {
        bSuccess = true;
        bSwitch = true;
  if (args->length == 3) {
      if ((args->value[1] == 'F') || (args->value[1] == 'f')) {
        if ((args->value[2] == 'F') || (args->value[2] == 'f')) {
        bSuccess = true;
//  Serial.print("Success: ");
//  Serial.print(bSuccess ? "y" : "n");
//  Serial.print(" channel: ");
//  Serial.print(channel);
//  Serial.print(" pin ");
//  Serial.print(iPins[channel]);
//  Serial.print(" switch ");
//  Serial.print(bSwitch ? "on" : "off");
//  Serial.print("\n");
  if (bSuccess) {
    digitalWrite(iPins[channel], bSwitch? HIGH : LOW);
    bDigital[channel] = bSwitch;
  return bSuccess ? SCPI_SUCCESS : SCPI_COMMAND_NOT_FOUND;
scpi_error_t set_digital_1(struct scpi_parser_context* context, struct scpi_token* command) {
  return set_digital(0, context, command);
scpi_error_t set_digital_2(struct scpi_parser_context* context, struct scpi_token* command) {
  return set_digital(1, context, command);
It isn't difficult to trace the SCPI commands back to the firmware functions. Not a lot is happening here.
Please check the code. If there's a construct that you have questions about, post a comment and I'll elaborate.
If you haven't got the SCPI library installed yet, check the previous post: Arduino in Test Instrumentation - Part 1: SCPI Lib.
Related Blog
Arduino in Test Instrumentation - Intro: SCPI Programmable Switch
Arduino in Test Instrumentation - Part 3a: LabVIEW Driver Intitialisation Block
Arduino in Test Instrumentation - Part 3b: LabVIEW Driver Switch Control Block
Arduino in Test Instrumentation - Part 3c: LabVIEW Driver Read Status Block
Arduino in Test Instrumentation - Outro: LabVIEW Example
    genebren over 8 years ago +3
    Jan, Another nice update to your project. I look forward to following the progress as you move forward. Gene
    Jan Cumps over 8 years ago +3
    These are the commands supported: *IDN? *RST :DIGITAL:SWITCH1 ON :DIGITAL:SWITCH1 OFF :DIGITAL:SWITCH2 ON :DIGITAL:SWITCH2 OFF :DIGITAL:SWITCH1? :DIGITAL:SWITCH1? :DIGITAL:SWITCH2? :DIGITAL:SWITCH2?
  • jc2048
    jc2048 over 8 years ago +3
    I got that to work, but had to put the library in my own documents folder (thanks, mcb1 , for that hint) and not in the Arduino installation library directory. Now all I need to do is dream up an instrument…
    I changed the serial baud setting to 38400.
    28800 was not supported by Arduino's Serial Monitor.
    If you're using my preliminary LabVIEW lib, edit the Initialize block. The final lib will default to 38400.
    mcb1 over 8 years ago in reply to Jan Cumps
    Sketches get saved where you want them, but the imported stuff tends to be saved in your user directory.
    The issue is if multiple people use the same machine, they all need to download the files, and board info etc.
    IMO it wasn't the best way to handle it.
  • jc2048
    jc2048 over 8 years ago in reply to Jan Cumps
    You had. It was just me getting it all wrong.
    Jan Cumps over 8 years ago in reply to jc2048
    I'm checking my previous blog post. I thought I had documented the location ...
    My IDE version is 1.8.1, sketchbook in Documents/Arduino ...
  • jc2048
    I got that to work, but had to put the library in my own documents folder (thanks, mcb1, for that hint) and not in the Arduino installation library directory.
    Now all I need to do is dream up an instrument for it to control and then build it.
