Spring Clean!
  • Spring Clean!
Spring Clean!
  • News and Projects
  • Views 3976 views
  • Comments 28 comments
  • spring cleaning
  • antenna
3 May 2025
image     image
image     image
image     image
    Also perhaps keep in mind the width of your yardstick, as the one from Ace Hardware used in the article was 1-1/8” wide
    so that 1-1/8" width in conjunction with the 1/2" length shown, gives your effective area of the capacitor plate.
  • kmikemoo
    kmikemoo over 1 year ago in reply to scottiebabe
    scottiebabe Cold sweat Wow.  Than really stinks.  One of the things I recently learned was that the weather satellites feed (or fed) info to the spy satellites about cloud coverage.  There's no sense in taking high resolution pictures of the tops of clouds.
    This also leans on that very frayed nerve of people that don't understand the value of routine maintenance.  The Death Spiral is quick on vintage equipment - and then you have nothing. Frowning2
  • kmikemoo
    beacon_dave The width of the gap absolutely determines the resonant frequency.  The smaller the gap, the lower the resonant frequency.  My challenge was raising the frequency 10MHz.  It's a bit like my eyesight.  It's fine.  My arms just aren't long enough.  Neither was my plastic bolt.
    I tried to logic through how increasing the capacitance made the antenna appear longer.  Okay... it offsets the inductance of the yardstick that isn't a full half wave... plus the optical range of a field mouse divided by the mass of a dill pickle - I don't know!  We cut dipoles shorter to raise their resonant frequency.  I'm making the loop shorter.  Some day.
    Credit to you.  When I do this again, I will probably experiment with the size of the capacitor plates.  I totally missed or forgot that measurement.  Eventually there is a horizontally polarized 144.05MHz version of this that I will want to build.
    * As to the "ruler on hand"... there were definitely times that I deeply regretted painting that yardstick. Laughing
  • kmikemoo
    kmikemoo over 1 year ago in reply to robogary
    robogary Interesting question.  If someone says they found it, I take that to mean that they actually saw the antenna and transmitter bag.  Sometimes folks will text me or Facebook Messenger me pictures.  There are no prizes so folks compete for bragging rights.  Each one of them gets praised.  "Great job!  You're the first!"  "That's fantastic!  Thanks for hunting.  Knowing that you did makes getting up early on a Saturday worth it. Thumbsup"
    I also get messages of "I was close but I just couldn't find it.", so I'll tell them where it was and what it looked like.  "Ah!  So close!  Great job!  You'll get it next month."
    My club members all have access to my cell phone number and I try to monitor our Facebook page as best I can.  The hunt starts at 0730 and ends at 1630 (sometimes later).  Part of the Rules of Engagement are not sharing the location until after noon.  Hints should guide but not ruin the hunt.  After lunch... less subtle.  Mid afternoon... blatant.  I WANT people to find the fox, but not so quickly that it isn't challenging and fun.  If folks are hunting when I show up to recover the fox, I'll coach them - or tell them - depending on where they are psychologically.  If they'll give it another go next month... we're winning.
    I guess all those Anger Management classes I had to take are finally bearing fruit - at least outside of work. LaughingThumbsup
  • robogary
    robogary over 1 year ago in reply to kmikemoo
    How close do you need to be to call this fox found ?
