      • Japan
      • Vietnam
Member Blogs Analog Discovery 3 - Neat Enclosure
  • Author Author: dougw
  • Date Created: 31 Dec 2023 9:22 PM Date Created
  • Views 2601 views
  • Likes 15 likes
  • Comments 15 comments
  • AD3 enclosure
  • BNC Adapter
  • Digilent Analog Discovery 3
dougw
dougw
31 Dec 2023
Intro
I am road testing a Digilent Analog Discovery 3 which included a BNC Adapter accessory module. The adapter connects to the Analog Discovery module via a 30 pin header, but there are no other mechanical fasteners to stabilize the connection. BNC cables are usually stiff enough to create stress on the header connection so I designed a chassis to mount both modules and stabilize the connection.
Enclosure Image
Design Features
  1. Shelters exposed PCB and connections from accidental touching and ESD
  2. Provides mechanical stability between the modules
  3. Prevents random metal objects from accidentally shorting pins on the pass-through 30 pin connector
  4. Prevents the pass-through connector pins from getting bumped and bent
  5. Retains visual access to labels on the main module
  6. Holds the 2 modules rigidly in optimal mating positions
  7. Provides clear labels for the BNC connectors
  8. Provides access to the configuration jumpers without any disassembly
  9. Provides easy access to the pass-through logic analyzer pins without any disassembly
  10. Provides non-slip feet that prevent the device from slipping around on the bench
  11. Provides clearance under the BNC connectors to allow adequate finger access to operate BNC connectors
  12. The case is a snug fit and quick to assemble
  13. Matches the black color scheme while still exposing the green side walls
  14. Provides the system with a robust, functional, "finished product" aesthetic
Enclosure Video
Discussion
I put some significant thought into designing an appropriate enclosure for the AD3 and BNC adapter assembly and it paid off with a very functional system that meets all my design criteria.
I am very pleased with the way it turned out. It definitely makes the AD3 into a more useful instrument.
AD3Case .stl files
DigilentAD3.zip
Links:
AD3 Unboxing
 Pretty Cool Raster Text Display on an AD3
AD3 Enclosure
AD# - Frequency-to-Voltage Converter
AD3 - Capacitance-to-Voltage Converter
My Road Test of the Analog Discovery 3
Digilent Analog Discovery 3 road test page
Digilent AD3 page
  • Andrew J
    Andrew J over 2 years ago
    That’s great.  I’m really getting into my 3D printer for useful stuff: conformed toolboxes for hand tools that were previously rolling around the bench drawer for example.
    dougw over 2 years ago in reply to Andrew J
    Tool storage is a big topic - I'm always planning to make a better way to store and access hand tools. Haven't come up with anything new recently, but not for lack of effort...Thinking
    If you have it solved, let us know the secret...
  • Andrew J
    Andrew J over 2 years ago in reply to dougw
    I created a box and insert for some tools: box is re-usable but insert is specific to the tool.  It's somewhat parametric in Fusion 360 although I'm still getting to grips with that so it probably isn't perfect for adjusting the sizes.  The box has a print-in-place hinge with catches.  For the Deburrer tool I created holes under the bits and tools to stick a magnet to hold them in place but this wasn't necessary for the scriber and centre punch.  Everything fits together snugly and I'm pretty pleased with myself for early-doors designing and printing.
    I think it might be worth investigating the GridFinity system (new window) as well.
    Looks awesome...
    Looks awesome...
