Member and Staff Blogs Pretty Cool Raster Text Display on an AD3
  • Author Author: dougw
  • Date Created: 14 Dec 2023 4:53 AM Date Created
  • Views 1112 views
  • Digilent Analog Discovery 3
  • raster display on a scope
dougw
dougw
14 Dec 2023
Intro
In the last bog I explored displaying text in 2 different ways:
  1. a 2 channel vertical split
  2. and an X-Y plot
This time I am exploring displaying text as a raster image (composite video) on the Digilent Analog Discovery 3.
Digital scopes are not great at this task, but it is fun to see how they fare...
New Content - 2 Channel Split Display
Before getting into the raster display video, here is an updated scope display of "element14" on the AD3 as a 2 channel split display  - trying to get the colors to be a bit more accurate. The AD3 allows full control over the trace colors, but how they turn out in the camera depends a lot on the ambient lighting. If you look closely you will see the image data is cleaned up a bit as well.
Raster Text Display on an Analog Discovery 3
Discussion
It is pretty hairy to display raster images on a digital scope, but it sort of works.
The raster display turned out better than my expensive scope and there is a lot more flexibility to size it on the big screen.
For more info on the little composite raster-to-scope circuit board see my Cinema-Scope blog.
As mentioned previously, this instrument is a blast to play around with.
Links:
Raster Text on an AD3
AD3 Unboxing
AD3 Enclosure
AD# - Frequency-to-Voltage Converter
AD3 - Capacitance-to-Voltage Converter
My Road Test of the Analog Discovery 3
Digilent Analog Discovery 3 road test page
Digilent AD3 page
    dougw over 2 years ago in reply to Andrew J
    It is significantly easier to apply these techniques to the AD3 than most traditional waveform generators and scopes, and the results can be displayed better as well.
  • Andrew J
    Andrew J over 2 years ago
    I do like this fun technique.
