      • Japan
      • Vietnam
FPGA
FPGA
Forum Hardware Manager unconnected. Autoconnect crashes
  • Replies 8 replies
  • Subscribers 556 subscribers
  • Views 1282 views
  • jtag
  • usb
  • som
  • k24
sam_jones
sam_jones 8 months ago
Hi all,
i am able to run linux images on the K24 SoM board via SD card image.
However i cant access the board via JTAG. Open Hardware doesnt detect it.
I have run "install" scripts in /xicom. Other Xilinx FPGAs (e.g. Zybo) are immediately detectable.
Do i have to install any special drivers ?
Thanks
  • iksevas
    iksevas 8 months ago +2
    The JTAG interface uses an FTDI chip. Have you that driver installed?
  • kmikemoo
    kmikemoo 8 months ago in reply to sam_jones +1
    sam_jones If your cable is communicating enough to run the install scripts, you don't need a different cable. If the cable communicates on a different system, you don't need a different cable. If you're…
  • sam_jones
    sam_jones 8 months ago in reply to iksevas +1
    This did the trick for me . I thought that was only meant for Windows platforms. Btw. while running ftdi_program , i encountered some missing *.so error. Find more details on the link below on how to resolve…
  • ahsrabrifat
    ahsrabrifat 8 months ago
    You need a USB cable that is data-capable, not just a charging cable. Confirm that your cable is data-capable.
  • sam_jones
    sam_jones 8 months ago in reply to ahsrabrifat
    Thank you for the immediate response . Could you pErhard send me a link to a data-capable USB Cable?
  • kmikemoo
    sam_jones If your cable is communicating enough to run the install scripts, you don't need a different cable.  If the cable communicates on a different system, you don't need a different cable.  If you're using the really short cable that came with your (battery) power bank... try a different cable.
  • sam_jones
    sam_jones 8 months ago in reply to kmikemoo
    Thanks. My cable does all the above . Unfortunately the Zybo board that I have access to doesn’t have a USB C interface so I couldn’t verify if the cable works on other devices .
  • cstanton
    cstanton 8 months ago
    I've moved and converted this from a blog to a forum post in a more appropriate location Slight smile
  • manihatn
    manihatn 8 months ago
    I have only used KV260 boards and those didn't require any special driver. So I would expect the same here. It doesn't appear like a cable problem.
    A couple of questions:
    1. It might be good to check the default boot mode for the board. Have you tried setting the boot mode to JTAG? I remember we can do it using some tcl scripts.
    2. Which version of Vivado and Petalinux tools are you using to build your custom image ? What are the version of the tools with which the SD card image was built?
    3. The reason for the above is to check if the K24 SOM  is compatible with your version of Vivado tools
    Hardware manager can behave strange some times when you swapping between a K24 (Zynq US+) and Zybo (Zynq). I have had instances where it holds the state of the device even after disconnecting it and connecting it to a new device. So the hardware manager task needs to be removed cleanly from from the task list or a restarted. A cold restart might make a difference.
  • iksevas
  • sam_jones
    This did the trick for me . I thought that was only meant for Windows platforms. Btw. while running ftdi_program , i encountered some missing *.so error. Find more details on the link below on how to resolve that : https://adaptivesupport.amd.com/s/article/000036977?language=en_US
    Thank you to everyone for the support.
