Single-Board Computers
  • Single-Board Computers
Forum Have a question about the Next-Gen BeagleBone? Ask it here!
  • Replies 197 replies
  • Subscribers 72 subscribers
  • Views 24648 views
  • beagle
  • bbb
  • BeagleBone
  • beagle_bone
  • bb_black
  • beagle_bone_black
bluescreen
bluescreen over 13 years ago
There is a lot of excitement about TI's Next-Gen BeagleBone. If you have a specific question about its performance characteristics, tech specs, or anything else, post it as a reply to this thread. We are working closely with TI and will make sure to respond to your questions.  Thanks everyone!  Sagar
    shabaz over 13 years ago in reply to e14 Contributor +2
    Until we have some space to work in, I might as well add to this thread: I've not had much time to experiment with the board recently, but I had an hour today, and I tried powering the board from a battery…
  • shobhitkukreti
    shobhitkukreti over 13 years ago +1
    I just ordered a Beagle Bone. What will be the difference in the present beagle bone and the next gen beagle bone ?
  • jkridner
    jkridner over 13 years ago in reply to johnbeetem +1
    The demo I've been showing here at ELC is using an Attic Lapdock. The only special hack required is a USB cable that doesn't short power sine the Lapdock sources power through a port that normally should…
    dhid wrote:
    I just need to try to sort out the overscan problem when connected to the TV.
    I don't own a TV, so probably not a lot of help here, but I know that some displays have an option to turn off overscan. My Samsung 400UX-2 has a 'Size' option with 'screen fit', Zoom1, Zoom2, 4:3, 16:9 options. Setting it to Screen fit defeats overscan and gives you a native resolution display. Not that I can understand why you'd ever want overscan on a display like this..
  • johnbeetem
    johnbeetem over 13 years ago in reply to e14 Contributor
    selsinork wrote:
    I'm not a fan of forums at the best of times, but that google groups thing they're using is awful, and the general mixture of beagleboard, beaglebone and beaglebone-black stuff leaves you never quite sure if what you're reading even applies to your board.
    The old Google Groups wasn't bad.  The new Google Groups is awful IMO which prevents me (and I'm sure many others) from casual use.  This means that if you do post a problem, the people who might be able to help you don't visit very often and your query goes unanswered.
    One thing I like about element14 is that you can quickly view presence of new comments in many groups (though not 'blog comments, alas) so in a few seconds I can see if there's something that might be of interest.
    In all cases, you do need a good wiki to back up the forum, and community members who have enough interest to keep the wiki up to date.  Are they updating the Beagle wiki with BBoneBlack lore?
  • fustini
    fustini over 13 years ago in reply to johnbeetem
    I prefer to view the beagleboard forum directly in google groups versus embedded on bealgeboard.org: https://groups.google.com/forum/?fromgroups#!categories/beagleboard
    The CircuitCo wiki has an extensive article for BeagleBone Black (BBB):
    http://circuitco.com/support/index.php?title=BeagleBoneBlack
    Other important BBB articles:
    Updating the software: http://circuitco.com/support/index.php?title=Updating_The_Software
    Accessories (including cape testing): http://circuitco.com/support/index.php?title=BeagleBone_Black_Accessories
  • morgaine
    morgaine over 13 years ago in reply to johnbeetem
    CircuitCo is updating their BeagleBoneBlack wiki pages periodically, and I started adding BBB info to the eLinux BeagleBone wiki page which I maintain, although since I currently lack a BBB myself I can't base it on first-hand experience.
    Wikis are wikis though ... those of you who actually have BBBs already, you can help out if you want to. image
    gryphon wrote:
    Something must have been wrong with the build.  Looks like they pulled it.  I can see it in the change history so you're not a liar image
    2013.05.08 is there right now... quick grab it before it vanishes image
    dhid wrote:
    I've been trying to find a fix for a problem I'm having with using HDMI
    The notes against the 2013.05.08 release that's recently appeared suggests there may be light at the end of that tunnel..
    Audio now supported. Will default to 1280x720 for audio support and should be compatible with TVs and displays.
    Fixed bug in HDMI driver that was sending conflicting information to the display.
    Anyone get hotplug USB to work ?
    I've not had much time to experiment with the board recently, but I had an hour today, and I tried powering the board from a battery.
    The LiPo was from Olimex, and basically just connects to the pins as according to the SRM table 3:
    My LiPo has built-in circuit, so I soldered a 10k resistor to TS and GND. The LiPo connector was convenient to solder to pins TP6 and TP8, and then  a zero-ohm link between TP5 and TP6 on the underside.
    I had only a right-angle connector so I bent it appropriately (the connector is on a 2mm pitch whereas the holes are not, so the pins need slight bending, so maybe an already-vertical connector would not have space to bend them)
    Plugging it in, the board worked fine, and the serial port allowed for the usual access. I didn't try Ethernet yet.
    The battery (Olimex code "BATTERY-LIPO1400mAh") by luck fits flush with the connectors so a daughter board can still be stacked over it in future.
    Really I need to write to the config registers to set the charge voltage to 4.2V (the default is 4.1V) but I've not looked to see how to do that yet.
  • morgaine
    morgaine over 13 years ago in reply to shabaz
    Excellent info and write-up, shabaz.
    I have Olimex's OLIMEXINO-STM32, which is a a Cortex-M3 microcontroller board that semi-clones the Maple and provides some Arduino compatibility in its headers.  The white connector at the bottom left of the Olimexino pictures is the LiPo batter connector, the same one which you've attached to your BBB, and works great on the Olimexino.
    I'm looking forward to replicating your mod on BBB in due course.
    Note to E14 admins.  Useful posts like shabaz's which many people are likely to want to reference in the future are going to get lost through lack of a BeagleBone group. image
  • fustini
    fustini over 13 years ago in reply to morgaine
    Very nice post, indeed.
    About the lack of BeagleBone group, this BeagleBone Black sub-space in the Knode has similar functionality to a regular group: http://www.element14.com/community/community/knode/dev_platforms_kits/element14_dev_kits/next-gen_beaglebone  Is there something that is lacking?  Or is it just that it is buried too deep under the Knode?
    thanks,
    drew
