Single-Board Computers
  • Single-Board Computers
Forum SBC CPU Throughput
  • Replies 88 replies
  • Subscribers 63 subscribers
  • Views 11324 views
  • cubieboard
  • olinuxino
  • sabrelite
  • bbb
  • BeagleBone
  • rpi
SBC CPU Throughput
morgaine
morgaine over 13 years ago
I notice that people are doing some initial benchmarking of BBB and other boards on the RPF forum.  Results roughly as expected I guess:
Using just a simple
time echo "scale=2000;4*a(1)" | bc -l
as a lightweight benchmark, I see these numbers reported (smaller Time is better):
[table now updated with extra datapoints reported in current thread below]
Submitter
Time (s)
Board
SoC
Clock (MHz)
O/S
shuckle26.488Raspberry Pi BBCM2835700Raspbian 3.1.9
morgaine25.719Raspberry Pi BBCM2835700Raspbian 3.1.9+ #272
shuckle25.009Raspberry Pi BBCM2835700Raspbian 3.2.27
trn24.280Raspberry Pi BBCM2835700Raspbian ?
morgaine22.456Raspberry Pi BBCM2835800Raspbian 3.1.9+ #272
morgaine21.256Raspberry Pi BBCM2835800Raspbian 3.6.11+ #545, new firmware only
selsinork21.0MinnowboardAtom E640T1000Angstrom minnow-2013.07.10.img
shuckle17.0Raspberry Pi BBCM28351000Raspbian ?
morgaine16.153BB (white)AM3359720Angstrom v2012.01-core 3.2.5+, user-gov
selsinork15.850A20-OLinuXino-MICROA20912Debian 7.0, 3.4.67+
selsinork15.328CubieboardA20912Ubuntu/Debian 7.1
pluggy14.510BBBAM33591000Debian
morgaine14.153BBBAM33591000Debian 7.0, 3.8.13-bone20, perf-gov
selsinork13.927A10-OLinuXino-LIMEA101000Debian 7.0, 3.4.67+
Heydt13.159CubieboardA101000?
selsinork12.8Sabre-litei.MX61000Debian armhf
selsinork12.752CubieboardA20912Ubuntu/Debian 7.1 + Angstrom bc
selsinork12.090BBBAM33591000Angstrom dmnd-gov
pluggy11.923BBBAM33591000Angstrom
selsinork11.86BBBAM33591000Angstrom perf-gov
selsinork9.7Sabre-litei.MX61000Debian armhf + Angstrom bc
selsinork9.606Sabre-litei.MX61000LFS 3.12, gcc-4.8.2, glibc-2.18
As usual, take benchmarks with a truckload of salt, and evaluate with a suitable mixture of suspicion, snoring, and mirth. Use the numbers wisely, and don't draw inappropriate conclusions. image
Morgaine.
    e14 Contributor over 13 years ago in reply to gdstew +2
    floating point doesn't get you 2000 digits.
  • morgaine
    morgaine over 13 years ago in reply to gdstew +1
    Data is always good, and sharing it is also good. The warnings are to help people avoid unwarranted conclusions. And when used properly, synthetic and other artificial benchmarks can be very valuable,…
    e14 Contributor over 13 years ago in reply to gdstew +1
    > and don't understand why you think it is a good idea to keep it in the loop so you can benchmark it. Come on. It's not that complicated. Johnny wanted to know how fast his new computer was. He decided…
  • gdstew
    gdstew over 13 years ago in reply to e14 Contributor
    So Johnny learned his lesson and from now on insists on benchmarks that don't involve a loop
    containing an invariant calculation.
    Not sure why any good benchmark would do that anyway since it wouldn't produce useful results.
    You're exactly right.  No good benchmark would do that, which is why I said:
    3)  it doesn't rely on computing the same value over and over in a loop.
        Benchmarks that do that can be overly sensitive to compiler loop
        optimizations, and to just-in-time code-generation techniques.
  • gdstew
    http://www.hvks.com/Numerical/arbitrary_precision.html
    http://www.apfloat.org/apfloat/
    http://gmplib.org/
    There are more, and you can find them using google.
  • gdstew
    gdstew over 13 years ago in reply to shabaz
    As part of a suite of benchmark programs, exactly.
    I was looking for ones that are implemented using floating-point.
    All the ones I'm aware of use integers, as described in Knuth's Volume 2.
  • gdstew
    gdstew over 13 years ago in reply to morgaine
    Nobody here has made any inappropriate conclusions from this data
    Never said they did, I just said that useful conclusions can't be derived from the data.
    so whatever are you arguing about?
    DAB says it best:
    In my architecture analysis days we used the term " Lies, damn lies and benchmarks!"
    Most computer architectures are too varied to assess with simple benchmarks.  You really need to look at your proposed application and look into the system architecture to get a good feel about how well one processor will perform over another.
    Unless you work with each processor in assembly language, you will seldom collect anything but interesting data.
    True performance is always dependant upon the compiler, application structure, operating system, I/O drivers and many other details.
    Raw power is seldom the only answer needed for a good system design.
  • gdstew
    http://www.nongnu.org/hpalib/
    "The functions forming the HPA library are all implemented in a portable fashion in the C language. The IEEE 754 standard for floating point hardware and software is assumed in the PC/Unix version of this library."
    There are also several papers (pdfs) from that describe using IEEE 754 floating point hardware for arbitrary precision arithmetic.
  • morgaine
    Which coder27 disproved very specifically by making useful engineering conclusions from the data, and which I had also noted as being useful in my opening post by saying that the results were as expected.  Indeed, they are as expected, by any rational engineer with basic knowledge of architecture and types of ARM core.  You've now ignored these useful conclusions twice over in a hopeless attempt to salvage your completely empty and nonsensical set of posts.
    If you dispute the data, go argue with those who captured it.  If you dispute that it is useful when applied sensibly in the way that we have applied it, that suggests lack of familiarity with basic CPU architecture.  In fact, you have not disputed anything at all, neither the data nor the reasoning, and you even agree with the cautioning about inappropriate use of benchmarks.
    Yet somehow you still find a way to argue beligerantly here without denying the given data, without providing new data, without denying the given reasoning, without providing new reasoning, and in fact without contributing anything at all.  Your posts on this topic have significantly raised the bar on the concept of empty.
    This thread was created to informatively and usefully summarize the simple benchmarking started in the RPF forum.  If you can't get your head around how this data can be interpreted usefully in the limited way that makes sense, fine, nobody is forcing you.  But please don't disrupt without clear reasoning an objective engineering thread in which data is considered valuable and in which the people present know how to use this data safely and sensibly.
    Morgaine.
    I have looked at this C code, and it sure looks to me like it is doing everything using integers.
    For example, xadd.c contains the code to add two numbers, and it declares these variables:
         unsigned short pe[XDIM + 1], h, u;
         register unsigned short *pa, *pb, *pc, *pf = pe;
         register unsigned int n = 0;
         short e;
         register short k;
    all of which are integers.
    The arbitrary precision numbers are stored in a struct called xpr,
    declared in xpre.h, defined as:
      struct xpr
         unsigned short nmm[XDIM + 1];
    which is clearly declaring an array of integers.
    Where are you seeing the floating-point operations in this library?
  • gdstew
    The only thing I have trouble wrapping my head around is why stating the obvious is a considered a useful engineering conclusion.
    coder 27:
    They confirm that when the clock rate increases from 700MHz to 1GHz on
    the same architecture, that the benchmark timings have a corresponding
    improvement.
    Fairly sure this has been well known since the dawn of of non one of a kind computers and doesn't really need confirmation.
    They confirm that when the architecture improves from ARMv6 to the superscalar ARMv7, but the clock rate is held constant,
    there is acorresponding improvement.
    Again well known since the ARMv7 has been out for quite a while now. I guess it doesn't hurt to confirm it one more time.
    They confirm that when both the architecture and clock rate are both held constant, such as between the cubieboard and BBB, that the
    benchmark timings are relatively constant.
    Again simply stating the obvious. At least it disproves the negative right ?
    They confirm that between the RPi and BBB there is a substantial performance difference, for integer compute bound, much greater than
    the difference in price.
    As long as this narrowly defined benchmark is the only performance difference that is important to you, great. One simple benchmark
    and done.
    Back to you:
    No, I have been around almost all of the microprocessor based CPU architectures (and a couple that used discrete TTL and real magnetic core memory
    as well) since before the Z80, so there's no lack of familiarity there.
    Never disputed the accuracy data, I did dispute the reasoning used to "prove" that it provided much in the way of useful engineering information with a
    reason in every reply to you. Of course I agree with cautioning about the inappropriate use of a benchmark (different from benchmarks as only one
    benchmark was run here and that one of the reasons I used that you "lost") but yours went well beyond any semblance of an appropriate caution
    and showed a distinct lack of faith in the usefulness of the benchmark data (not the data itself) which is exactly what I said.
    Never questioned the accuracy of the data just the usefulness of the interpretation of a single narrowly focused benchmark so why do you keep bringing
    that up ?
    I have provided both in my posts and have done so again in this one. That you continue to "miss" it is hardly surprising. You have a knack for
    never responding to any "given" or "new" reasoning at all or with anything other than repeating what you said before in effect doing exactly
    what you say I am doing. Or just accusing someone of not using reasoning at all or at least your interpretation of it again exactly as you
    have done here.
    An area you have also ventured into yourself on occasion including this very thread. And several personal attacks from you to boot !
    I thought you didn't approve of such things. Well again, not surprising.
    And the simplicity of this single benchmark and the fact that it is a single benchmark have been the center of the reasoning about the usefulness
    of its data since the beginning. Any conclusions about the performance of a complex system based on one simple test is more likely to misinform
    than inform, or at best just prove what you already know. I guess that can be considered useful to some.
    If you can't get your head around what is actually useful fine nobody is forcing you.
    Sorry, I don't consider you to be the final arbitrator on what clear reasoning or objective engineering is although I know you have
    projected yourself as such several times in the past often rejecting clear reasoning and objective engineering when doing so.
    Yes it is valuable, the more data (from benchmarks, note the plural) the better, especially when you need to use it sensibly.
    I'm not sure were using benchmark data safely comes from and you forgot responsibly.
