Technical Library
  • Technical Library
Technical Library
Documents Atmel ARM Solutions
  • Author Author: atomar
  • Date Created: 7 Jun 2012 2:46 AM Date Created
  • Last Updated Last Updated: 9 Jul 2013 7:01 AM
  • Views 2548 views
Atmel ARM Solutions
Kits & Evaluation ModulesKey FeaturesDevelopment ToolsApplicationsVideo
More Resources
imageAtmel Line card
imageAtmel Studio 6 IDE
imageKnode Development Kits & Platform Room
imageelement14 Knode
Overview
AtmelRegistered ARM-based Flash Microcontrollers and Embedded Microprocessors
Atmel's two decades of microcontroller (MCU) leadership and innovation includes many industry-firsts: the first Flash MCU, the first ARM7Tm-based 32-bit Flash MCU, the first 100nA MCU with RAM retention, and the first ARM9Tm-based Flash MCU. We continue to leverage this experience to build solutions that help you bring to market smart and innovative products. In addition to ARM-based MCU products, Atmel offers ARM-based microprocessors (MPUs) that do not have on-board Flash memory. These MPUs include ARM CortexRegistered-A5-based products such as the ARM926EJ-STm-based AtmelRegistered SAMA5D3 and AT91SAM9261 devices.
  • Flexible, highly integrated Atmel ARM-based MCUs are designed to optimize system control, user interface management and ease of use. The ARM Cortex-M3 and Cortex-M4 based devices share a single integrated development platform (IDP)—Atmel Studio 6. This platform provides time-saving source code with more than 1600 example projects, access to debuggers/simulators, integration with Atmel QTouchRegistered tools for capacitive touch applications, and access to the Atmel Gallery online apps store for embedded software and extensions.
  • Atmel ARM-based MPUs range from entry-level devices to advance highly integrated devices with extensive connectivity, refined interfaces and ironclad security. Atmel provides a full range of hardware and software tools for our ARM-based MPUs to make your design process easier and reduce time to market. Atmel also works with a worldwide network of partners to deliver additional hardware and software solutions for these devices.
In order to optimize and simplify the embedded design process we have built a robust ecosystem around our microcontrollers and microprocessors. This enables you to complete your projects more easily and get new products to market quickly. Atmel provides a wide range of software tools and embedded software that support leading operating systems. Atmel Studio 6 enables you to get fast results with Atmel MCU devices. You can program and debug Atmel MPUs with familiar third-party tools in conjunction with Atmel in-circuit emulators (ICE).
Key Features
Atmel ARM-based Flash MCUs: ARM Cortex-M4, Cortex-M3, ARM926EJ-STm and ARM7TDMIRegistered-based Flash MCUs offer:
  • Up to 2MB of Flash memory and 160KB of SRAM, with operating frequencies up to 120MHz
  • Innovative direct memory access (DMA) and memory implementations, which enable high-speed data transfers while freeing the processor for the application
  • "Touch-ready" capability through Atmel QTouchRegistered capacitive touch technology
  • Serial communication module (SERCOM), available in the SAM D20 series, is fully software-configurable to handle I2C, USART/UART and SPI communications to enhance interface flexibility.
  • The lowest power consumption available in an ARM Cortex-M4-based MCU
Atmel ARM-based embedded MPUs: ARM Cortex-A5 and ARM926EJ-STm based embedded MPUs are easy to use and ideal for cost-sensitive applications. They offer:
  • Performance up to 850DMIPS at 536MHz with a floating point unit
  • Market-leading power consumption at less than 200mW when running at maximum speed
  • Powerful peripherals including USB high-speed host and device, Gigabit Ethernet, CAN, TFT LCD controller, camera interface and more
  • Robust security thanks to hardware crypto engine and secure boot
  • Free Linux and Android distributions and a comprehensive partner ecosystem to provide additional hardware and software solutions
Back to top
Development Tools
Software Development Tools:
IDEAtmel
Atmel Studio 6
ALL ARM
Atmel Studio 6 Integrated Development Environment (IDE) is the integrated development environment (IDE) for developing and debugging Atmel ARMRegistered CortexTm-M and Atmel AVRRegistered microcontroller (MCU) based applications. The Atmel Studio 6 IDE gives you a seamless and easy-to-use environment to write, build and debug your applications written in C/C++ or assembly code. Learn More
IDEARM KeilMDK ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9Tm
The MDK-ARM (Microcontroller Development Kit) is the complete software development environment for ARM7, ARM9, Cortex-M, and Cortex-R4 processor-based devices.  Learn More
RTOSMicrium
Micrium uc/OSIII
ALL ARM
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Learn More
RTOSSegger
embOS
ALL ARM
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications. Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsAtmel
AT91SAM-ICEAT91SAM-ICE
SAM3 / SAM7 / SAM9USB JTAG In-Circuit Emulator for SAM3, SAM7 and SAM9 ARM-based microcontrollers
Emulator / Debugger / ProgrammerARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmULINK2 Debug Adapter
Emulator / Debugger / ProgrammerARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmULINKpro Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Applications
  • Industrial Control
  • Metering
  • Consumer Goods and Toys
  • Medica
  • High-Speed Gateways in Industrial and Medical Applications
  • PC & Mobile Phone Accessories
  • USB Tokens & Drives
  • Data Loggers
Back to top
Video
Video1Video2Video3
Back to top
SAM3 (Cortex-M3)
Part NumberCore ArchitectureSilicon FamilyDescription
ATSAM3N-EKATSAM3N-EKARM Cortex-M3ATSAM3NATSAM3N-EK Evaluation Kit for ARM Cortex-M3 based SAM3N series MCUs
ATSAM3S-EK2ATSAM3S-EK2ARM Cortex-M3ATSAM3S / ATSAM3SDATSAM3S-EK2 Evaluation Kit for ARM Cortex-M3 based SAM3S and SAM3SD MCUs
ATSAM3U-EKATSAM3U-EKARM Cortex-M3ATSAM3UATSAM3U-EK Evaluation Kit for ARM Cortex-M3 based SAM3U MCUs
ATSAM3X-EKATSAM3X-EKARM Cortex-M3ATSAM3X / ATSAM3AATSAM3X-EK Evaluation Kit for ARM Cortex-M3 based SAM3X and SAM3A MCUs
SAM4 (Cortex-M4)
ATSAM4L-XPROATSAM4L-XPROARM Cortex-M4ATSAM4LATSAM4L-XPRO Xplained Pro Evaluation Kit for ARM Cortex-M4 based SAM4L MCU
ATSAM4L-XSTKATSAM4L-XSTKARM Cortex-M4ATSAM4LATSAM4L-XSTK Xplained Pro Starter Kit for ARM Cortex-M4 based SAM4L MCU
ATSAM4S-XPROATSAM4S-XPROARM Cortex-M4ATSAM4SATSAM4S-XPRO Xplained Pro Evaluation Kit for ARM Cortex-M4 based SAM4S MCU
ATSAM4S-XSTKATSAM4S-XSTKARM Cortex-M4ATSAM4SATSAM4S-XPRO Xplained Pro Starter Kit for ARM Cortex-M4 based SAM4S MCU
ATSAM4S-EK2ATSAM4S-EK2ARM Cortex-M4ATSAM4SATSAM4S-EK2 Evaluation Kit for ARM Cortex-M4 based SAM4S MCU
SAM7 (ARM7)
AT91SAM7SE-EKAT91SAM7SE-EKARM7ATSAM7SEAT91SAM7SE-EK Evaluation Kit for the SAM7SE MCU
AT91SAM7X-EKAT91SAM7X-EKARM7ATSAM7XAT91SAM7X-EK Evaluation Board for the AT91SAM7X and AT91SAM7XC MCUs
SAM9 (ARM9)
AT91SAM9260-EKAT91SAM9260-EKARM9ATSAM9260AT91SAM9260-EK Evaluation Board for the SAM9260 MCU
AT91SAM9G20-EKAT91SAM9G20-EKARM9ATSAM9G20AT91SAM9G20-EK Evaluation Board for the SAM9G20 MCU
Back to top
  • cortex-m4
  • microprocessors
  • at91sam9261
  • atmel_studio_6
  • cortex-m3
  • microcontrollers
  • arm7
  • sama5d3
  • arm926ej-s
  • arm
  • arm9
  • atmel
