Technical Library
  • Technical Library
Technical Library
Documents Freescale: TWR-K60F120M Kinetis K60 120 MHz Tower System Module
  • Author Author: atomar
  • Date Created: 26 Aug 2013 3:58 AM Date Created
  • Last Updated Last Updated: 25 Jun 2014 12:52 AM
  • Views 1289 views
BUY NOWBUY NOWDevelopment ToolsTechnical DocumentsVideoFeaturesKit Contents
Overview
The TWR-K60F120MTWR-K60F120M is a development board for the Kinetis K10, K20 and K60 family 32-bit ARMRegistered CortexTm-M4 MCUs. The TWR-K60F120M is populated with a device rated for 120 MHz operation across the full -40C to 85C temperature range. At room temperatures the board can be over-clocked to 150 MHz to allow for evaluation of the K10, K20, and K60 devices that are rated for 150 MHz operation across the full temperature range.
The TWR-K60F120MTWR-K60F120M is a Tower Controller Module compatible with the Freescale Tower System. It can function as a stand-alone, low-cost platform for the evaluation of the Kinetis K10, K20, and K60 family of microcontroller (MCU) devices. The TWR-K60F120M features the Kinetis MK60FN1M0VLQ12MK60FN1M0VLQ12 low-power microcontroller based on the ARMRegistered CortexTm-M4 architecture with USB 2.0 HS Controller, USB 2.0 full-speed OTG controller and 10/100 Mbps Ethernet MAC with a maximum core operating frequency of 120MHz. It is intended for use in the Freescale Tower System but can operate stand-alone. An on-board debug circuit, OSJTAG, provides a JTAG debug interface and a power supply input through a single USB mini-AB connector.
The TWR-K60F120MTWR-K60F120M is available as a stand-alone product or as a kit (TWR-K60F120M-KIT) with the Tower Elevator Modules (TWR-ELEV) and the Tower Serial Module (TWR-SER). The TWR-K60F120M can also be combined with other Freescale Tower peripheral modules to create development platforms for a wide variety of applications.
The Kinetis MCU portfolio consists of multiple pin-, peripheral- and softwarecompatible MCU families based on the  ARMRegistered CortexTm‐M4 core. Families are built from innovative 90 nm thin-film storage (TFS) flash technology with unique FlexMemory (EEPROM) capability, and offer industry-leading low power and mixed signal analog integration.
Ordering Information:
MPNDescription
TWR-K60F120MTWR-K60F120MKinetis K60 120 MHz Tower System Module
TWR-K60F120M-KITTWR-K60F120M-KITKinetis K60 120 MHz Tower System Module with Tower Elevator Module (TWR‐ELEVTWR‐ELEV) and Tower Serial Module (TWR‐SERTWR‐SER)
Key Applications: Consumer (Home Appliances), Industrial ( Programmable Logic Control, Portable Electronic Point of Sale Terminals, Building Control, LCD Control Panel, Smart Cities Connectivity Through IPv6, Smart Grid and Smart Metering, Digital Power Conversion, Factory Automation )
imageFreescale Development KitsimageFreescale Development Tools
Development Tools
Software Development Tools:
IDEFreescaleCodeWarriorAll Freescale MCU's
Freescale's software and development solutions take you beyond the silicon, helping to bring your embedded applications to life.  Learn More
IDEARM KeilMDK ARMARM CortexTm-M  / Cortex-R4 / ARM7Tm / ARM9Tm
The MDK-ARM (Microcontroller Development Kit) is the complete software development environment for ARM7, ARM9, Cortex-M, and Cortex-R4 processor-based devices.  Learn More
RTOSFreescaleMQXColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
The Freescale MQX Real-Time Operating System (RTOS) provides real-time performance within a small, configurable footprint. This RTOS is designed to allow you to configure and balance code size with performance requirements. Learn More
RTOSMicriumuC/OS IIIColdFire / HC08 / HC12 / ARM / S08 / RS08 / PowerPC
μC/OS-III is Micrium’s newest RTOS, designed for developers who need to save time on their current and next embedded sytem projects. Using a commercial real-time kernel such as μC/OS-III provides a solid foundation and framework to the design engineer dealing with the growing complexity of embedded designs.  Learn More
RTOSSeggerembOSColdFire / HC08 / HC12 / ARM / S08 / RS08
SEGGER embOS (Real Time Operating System) follows strict, yet efficient coding and documentation standards. embOS is a priority-controlled real time operating system, designed to be used as foundation for the development of embedded real-time applications.  Learn More
Hardware Development Tools:
Debuggers, Emulators & JTAG ToolsFreescaleU-MULTILINKU-MULTILINKHC08 / HCS12 / S08 / RS08 / Coldfire / KinetisP&E USB Multilink Universal debug and programming interface for HCS08, HC(S)12(X), ColdFire, Qorivva MPC55xx/56xx, and Kinetis
Debuggers, Emulators & JTAG ToolsARMULINK2ULINK2ARM CortexTm-M  / ARM7Tm / ARM9TmUSB DEBUG
Debuggers, Emulators & JTAG ToolsARMULINKProULINKProARM CortexTm-M  / ARM7Tm / ARM9TmHigh-Speed Debug and Trace Unit
EmulatorSeggerJ-LinkJ-LinkARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmJTAG/SWD Emulator with USB interface
ProgrammerSeggerFlasher ARMFlasher ARMARM CortexTm-M  / Cortex-R4 / Cortex-A / ARM7Tm / ARM9TmFlash Programmer for ARM and Cortex cores
Back to top
Technical Documents
Learning Center
TypeDescription
User GuideFreescale: User Manual for TWR-K60F120M Kinetis K60 120 MHz Tower System Module
User GuideFreescale: Quick Start Guide for TWR-K60F120M Kinetis K60 120 MHz Tower System Module
DatasheetFreescale: Datasheet for MK60FN1M0VLQ12 Kinetis MCU
Product Brief
Freescale: Product Brief for Kinetis K60 Family
Product BriefFreescale: Factsheet for Kinetis K60 Family MCUs
Application NoteFreescale: Application Note for MQX Board Support Package Porting Guide on KEIL
Revision NoteFreescale: Revision Note for TWR-K60F120M Kinetis K60 120 MHz Tower System Module
Design Elements
TypeDescription
Application LibraryFreescale: Software Code for MQX Board Support Package Porting Guide on KEIL
Back to top
Video
Video1Video2
This video is unavailable.
Back to top
Kit Features
  • MK60FN1M0VLQ12MK60FN1M0VLQ12 Kinetis MCU
    • 32-bit ARMRegistered CortexTm-M4 core with DSP instructions
    • 120MHz maximum core operating frequency
    • 144 LQFP, 20mm x 20 mm, 0.5mm pitch package
    • 1.71V – 3.6V operating voltage input range
    • 1 Mbyte of program flash, 128 Kbytes of static RAM
    • NAND flash controller
    • External bus interface
    • Power management controller with 10 different power modes
    • Multi-purpose clock generator with PLL and FLL operation modes
    • 16-bit SAR ADC, 12-bit DAC
    • High-speed analog comparator with 6-bit DAC
    • Programmable voltage reference
    • USB high-speed OTG controller
    • USB full-speed/low-speed OTG/Host/Device controller with device charge detect
    • 10/100 Mbps Ethernet MAC
    • SPI, I2C (w/ SMBUS support), UART (w/ ISO7816, CEA709.1-B (LON), and IrDA support), CAN, I2S
    • SD Host Controller (SDHC)
    • GPIO with pin interrupt support, DMA request capability, digital glitch filtering
    • Capacitive touch sensing inputs (TSI)
    • Debug interfaces: JTAG, cJTAG, SWD
    • Trace: TPIO, FPB, DWT, ITM, ETM, ETB
  • S08JM60 based open-source BDM (OSBDM) circuit
  • On-board JTAG debug circuit (OSJTAG) with virtual serial port
  • 2Gb of SLC NAND flash memory
  • 4 user-controlled status LEDs
  • 4 Capacitive Touch Pads and 2 mechanical push buttons
  • Socket for Capacitive Touch Pad daughter board (Touch TWRPI)
  • Socket for Tower Plugin (TWRPI, e.g. sensor board)
  • Potentiometer
  • Three-axis digital accelerometer (MMA8451QMMA8451Q)
  • Battery Holder for 20mm lithium battery (e.g. 2032, 2025)
  • SD Card slot
Back to top
Kit Contents
The Freescale TWR-K60F120MTWR-K60F120M Module supplied with below contents:
  • TWR-K60F120MTWR-K60F120M board assembly
  • 3ft USB cable
  • Interactive DVD with software installers and documentation
  • Quick Start Guide
The Freescale TWR-K60F120M-KITTWR-K60F120M-KIT Kit supplied with below contents:
  • TWR-K60F120M MCU module
  • TWR‐ELEVTWR‐ELEV – Primary and Secondary Elevator Modules
  • TWR‐SERTWR‐SER – Serial module including USB host/device/OTG, Ethernet, CAN, RS232 and RS485
Back to top
  • k20
  • twr-k60f120m-kit
  • kinetis_k60
  • cortex™-m4
  • freescale
  • mk60fn1m0vlq12
  • arm®
  • twr-k60f120m
  • twr-ser
  • k60
  • twr-elev
  • tower_system_module
  • k10
