EAGLE User Chat (English) 6.1.5, DRC err on tStop layer...sometimes
  • Views 726 views
Most likely my error someplace, brand new to Eagle CAD. Anyway, my
question is: Is tStop layer invisible by default? Reason for this
question: I was down to zero DRC errors on my first small board layout
with Eagle, then I notice part of the perimeter (layer 20) had vanished
on my layout. So, I turned off view of all layers, then turned on just
layer 20 so I could redraw the border outline. Fine, done with that,
turn on ALL layers and ran DRC. Now have about 30 errors re tStop layer.
How is it possible to not see this before? Just for fun, I turned off
tStop layer and ran DRC again. No errors! What the heck... can anyone
shed some light on this, is there something I need to fix? By the way, I
did 99% of this layout with original default design rules, then found
that SunStone had a .DRU file for Eagle, so I loaded that. Still did not
see errors before turning on ALL layers. Should I be concerned about
these errors I almost did not notice before ordering boards? I made
Gerber files & looked at them with GerbV, they look fine to my
eyeball...but i don't perceive 3mil objects all that well! That seems to
be the top solder mask min/max in the SunStone rules.
Thanks for any enlightenment,
Bill
    On 04/13/2012 08:31 AM, Robert Scott wrote:
    On Thu, 12 Apr 2012 20:51:25 -0700, Bill Martin<wwm@wwmartin.net>
    wrote:
    >> Hi,
    I just posted a similar issue in the support forum and got the same
    answer as you got from Joern.  DRC only checks visible layers.  I also
    got lots of tStop errors when I temporarily turned on tStop (29)
    visibility.  It turned out that all those errors were for the
    silkscreen layer overlapping the stop mask.  However even those errors
    seemed to be calculated on unrealistic rules.  It seems that a
    conflict is detected when any part of the silkscreen text rectangle
    intersects with any part of the stop mask, even if no part of the
    actual silkscreen text is anywhere near the stop mask.  I suppose it
    is just very difficult for Eagle to check the rendering of each letter
    in the text to see if it overlaps with the stop mask.  It is much
    easier to just check the rectangle that contains the text.  In most
    cases you can just approve such errors and go on.  But imagine what
    would happen if some silkscreen were placed squarely on top of a
    surface-mount pad.  It would make that pad unsolderable.  So we
    certainly want an error to be declared in that case.
    Robert Scott
    Ypsilanti, Michigan
    Ok, it seems like the majority of my 31 DRC errors came from a couple of
    thru-hole library parts I used. The rest appear to be of the
    "encroaching text rectangle" variety, so I think I am done with this
    little exercise.
    It certainly is great to have these newsgroups for sanity checking!
    Bill
    Bill Martin wrote:
    .................. I have not found any way to make these tStop errors
    go away, short of just turning off visibility to layer 29. This does
    not seem normal...or correct. Maybe the thing to do is just submit
    the files to SunStone & see if "their" DRC passes or fails.
    Best Regards,
    Bill
    One of the most usefull and common actions a  board house will do is post
    process your design to remove any silk sreen that is not on top of solder
    solder mask.
    As always you need to confirm your chosen board house does this.
    Generally it is accepted that you should have your libraries as correct as
    possible in this matter. Names that are smashed and moved later should be
    placed sensibly to prevent placement in mask clear areas. The board house
    then chops out the remainder
    HTH
    Warren
    news.cadsoft.de
    wrote:
    >> Hi,
    >> Gerber files&  looked at them with GerbV, they look fine to my
    Robert Scott
    Ypsilanti, Michigan
    On 04/13/2012 01:10 AM, Joern Paschedag wrote:
    Am 13.04.2012 05:51, schrieb Bill Martin:
    >> Hi,
    >> Bill
    DRC checks visible (selected) layers only.
    Ok, thank you for the confirmation of my "discovery". This then implies
    that the tStop layer is by default not visible. Is the the correct
    behavior? I have not found any way to make these tStop errors go away,
    short of just turning off visibility to layer 29. This does not seem
    normal...or correct. Maybe the thing to do is just submit the files to
    Best Regards,
    Bill
    On Thu, 12 Apr 2012 20:51:25 -0700, Bill Martin <wwm@wwmartin.net>
    wrote:
    >Hi,
    Robert Scott
    Ypsilanti, Michigan
    Bill
    Joern Paschedag
