How do I connect a circle to a NET?
I want to draw a circle and connect that circle to ground.
Gary Gofstein thanks for the answer the half circles worked for me.
"Tilmann Reh" <usenet2007nospam@autometer.de> wrote in message
news:hqopjb$t2d$2@cheetah.cadsoft.de...
Gary Gofstein schrieb:
just make 2 semicircles and overlap them. this is a good use for the
COPY command ( which really duplicates objects).
i don't think the 2nd coordinate is a point that is drawn, it is just
used to define the diameter and that leads to an error since you don't
have the correct diameter. i can't offer you a better answer since I use
v4 which is slightly different but I can do it with semicircles exactly.
watch out for grid settings.
With V5, this is the same.
A CIRCLE can't have a signal name, but ARCs can. So the correct solution
to this is drawing to half circles. (BTDT.)
Tilmann
Tilmann
On 4/21/2010 4:44 PM, Dang Tran wrote:
The arc command, when trying to make a circle is not as accurate as the
circle command.
Say I want to use the arc command to create a circle with a radius of 9.5mm
centered at (20mm,20mm)
My calculation for creating the circle using the arc command are (20,29.5)
to (20.17,29.5) Curve = -359.
If you try it in eagle the center is off.
circle command.
"Gary Gofstein" <nospam@use.forum.net> wrote in message
news:hqnvjd$9gu$1@cheetah.cadsoft.de...
On 4/21/2010 3:35 PM, Dang Tran wrote:
If I click on NAME command and then click the circle nothing happens.
I dont see a dialog to enter in the name.
"Gary Gofstein"<nospam@use.forum.net> wrote in message
news:hqnpor$iqr$2@cheetah.cadsoft.de...
use the NAME command to name it to the net it belongs to. it must be
drawn
in a copper layer.
yup, I get the same. but it works for arcs so just make it out of one or
two arcs.
use the NAME command to name it to the net it belongs to. it must be drawn
in a copper layer.
two arcs.
in a copper layer.
drawn in a copper layer.
