EAGLE User Support (English) Libraries for LGA-16 anyone?
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 1077 views
Has anyone a library with the LGA-16 design in it?
I'm want to use LIS3LV02DL (STMicroelectronics) or MMA7455L (Freescale
Semiconductor).
Anywhere to be found in the libraries??
Thank you
    Oh my!!!
    Thank you so much!
    I won't give up, I will try to make a library for all LGA
    configurations and share it.
    Thanks again!!
    Attached is a library with a correct layout according to the PDF.  According
    to the dimensions in the PDF, the soldermask is P1 - T1 = .175  and  P2 - T2
    = .150 so the mask is slightly bigger in one direction by .025.  No big deal
    but something to note.  Also the outline is slightly enlarged so that the
    silkscreen doesn't overwrite the solder area.   I didn't read the stencil
    requirements for paste, but I figured you could try to take it from here.
    Good luck and have fun!  I do my schematics on paper so I don't have/use the
    schematic editor.
    <test@testnospam.nl> wrote in message
    news:fb3iq4lp02uhaai7r7opr1btpu25dsvd7l@4ax.com...
    Thank you all again, will try again this night.
    The problem is that I need to learn it and need to have a small PCB by
    Tuesday.
    Will try my best.
    schematic editor.
    Tuesday.
    Will try my best.
    Tuesday.
    Will try my best.
    Good  Freescale technical paper on LGA soldering parameters:
    http://www.freescale.com/files/32bit/doc/package_info/AN2920.pdf
    Gary is correct.  The copper metal pad is the same size as the pin size T1
    and T2.  The solder mask opening is P1 and P2.
    "Robert Leavitt" <bb@hotdogdigital.com> wrote in message
    news:goa8at$eru$1@cheetah.cadsoft.de...
    The package outline is a good start.  Is it correctly centered and the
    right dimension of  7.5 by 4.4mm?  I suggest you make the GRID size =
    .01mm , since all of the placement coordinates are at .05mm resolution.
    You will have to scroll in to see the grid, but it makes placement easier.
    For the smd pads you use the SMD button (a red rectangle next to the round
    green PAD button).  When you click on the SMD button, an SMD properties
    bar will appear in the top menu bar area.  Boxes with "Smd:" "Roundness"
    and "Angle" are displayed.  In the "Smd:" box, enter the P1 and P2
    dimensions given in the PDF.  So you should enter 0.975 x 0.65 <enter>.
    Now you have the correct pad size to place.  Use the Right Mouse Button to
    rotate the smd pad before placement when required.
    There are ways to command an smd pad to be placed at any coordinate, but
    start with the basics first.  Let me know if you need furthur help.
    news:9c3hq41tp95ccof5t39rvv675rrchlnme4@4ax.com...
    Hey, thanks...
    I've been trying for the last hours to work that out, but all I have
    is a rectangle...
    Can I make a pad from a rectangle in stead of using a pad?
    I'ts hard to make a rectangle pad with certain dimensions.
    I made one from two square pads, grouped them, and tried to copy
    them...
    Didn't succeed..
    Quickly?? Not for me..
    The PDF for the  LIS3LV02DLLIS3LV02DL has the pad dimensions for it's footprint
    You
    can make your own quite quickly if no one has one to share.
    news:deeeq41bkm7ea8j4dm6fr87vbv0360sjiq@4ax.com...
    Semiconductor).
    Thank you
    The package outline is a good start.  Is it correctly centered and the right
    dimension of  7.5 by 4.4mm?  I suggest you make the GRID size = .01mm ,
    since all of the placement coordinates are at .05mm resolution.  You will
    have to scroll in to see the grid, but it makes placement easier.  For the
    smd pads you use the SMD button (a red rectangle next to the round green PAD
    button).  When you click on the SMD button, an SMD properties bar will
    appear in the top menu bar area.  Boxes with "Smd:" "Roundness" and "Angle"
    are displayed.  In the "Smd:" box, enter the P1 and P2 dimensions given in
    the PDF.  So you should enter 0.975 x 0.65  wrote in message
    Hey, thanks...
    is a rectangle...
    them...
    Didn't succeed..
    The PDF for the  LIS3LV02DLLIS3LV02DL has the pad dimensions for it's footprint You
    Semiconductor).
    Thank you
    set grid to 1mm (pitch from data sheet)
    draw the outline in the tPlace layer with wires.
    type SMD 0.8 0.5 in command line so that you will have the pad size
    defined in the data sheet.
    place them where you need them.
    be very careful with the top /bottom view to get pin1 in the right place!
    check that the solder mask is correct in the board with the
    recommendation from the data sheet, there's a way to override the
    default size of the mask, but I don't know it.
    Hey, thanks...
    is a rectangle...
    them...
    Didn't succeed..
    Semiconductor).
    Thank you
    Semiconductor).
    Thank you
