EAGLE User Support (English) Overlap error under IC
  • Replies 11 replies
  • Views 2149 views
I have manually placed GND vias under the IC, but the DRC can't accept it,
showing Overlap error, like seen in the snapshot. Why?
    if you mean will it connect, just look at your gerbers and see if it's
    connected. if not, EAGLE did not realize it is on the same net.
  • Richard_H
    Richard_H over 16 years ago
    Morten Leikvoll schrieb:
    "Thiago Henrique Rodrigues" <thiago_hr@yahoo.com.br> wrote in message
    news:hjn6vb$cqv$1@cheetah.cadsoft.de...
    I still don't understand that error... there is this ESD diode, with 3
    terminals (two of them connected to GND in schematic). I want to put vias
    on these pads directly to GND, but it keeps generating overlap error. But
    if I create a via name GND on the side of the diode, it connects the pad
    to the via... what is wrong?
    If you put vias ON smd pads, then you will always get drc error.
    You won't get an error, if you change the Design Rules.
    Go to the Clearance tab and set the value for Same signals
    for SMD - Via to 0.
    Richard Hammerl
    "Morten Leikvoll" <mleikvol@yahoo.nospam> escreveu na mensagem
    news:hjotkt$9je$1@cheetah.cadsoft.de...
    If you put vias ON smd pads, then you will always get drc error. I have
    been into the same problem when using a pcb battery holder where I wanted
    the smd to be the tallest point on the board, where I wanted the via
    inside the pad. I guess there is no other solution than to just approve
    that error.
    But will it work? I mean, will connect the pad to GND plane?
    autodeskguest over 16 years ago in reply to autodeskguest
    If you put vias ON smd pads, then you will always get drc error. I have been
    into the same problem when using a pcb battery holder where I wanted the smd
    to be the tallest point on the board, where I wanted the via inside the pad.
    I guess there is no other solution than to just approve that error.
    news:hiho1u$3mk$1@cheetah.cadsoft.de...
    news:hifi5f$pa5$1@cheetah.cadsoft.de...
    Actually, the big square under the IC has no name, nor it is connected to
    GND... I manually connected it using the VIAS. So I can leave it like
    this, that will work, right?
    No that will not work, cause the SMD pad will get a signal name wether you
    set it or not.
    You should edit your device so that the smd will get a pin that you can
    connect to GND. It could be a separate symbol with the pin direction set
    to 'power' and named 'GND' (and set add feature of this symbol to
    suiteable value - rtfm). This will hide the gnd connection, although
    personally I don't like hidden stuff.
    terminals (two of them connected to GND in schematic). I want to put vias on
    these pads directly to GND, but it keeps generating overlap error. But if I
    create a via name GND on the side of the diode, it connects the pad to the
    set it or not.
    connect to GND. It could be a separate symbol with the pin direction set to
    'power' and named 'GND' (and set add feature of this symbol to suiteable
    value - rtfm). This will hide the gnd connection, although personally I
    "eSilviu" <silviu.epure@ugal.ro> escreveu na mensagem
    news:hifieq$qdu$1@cheetah.cadsoft.de...
    It will work only if VIAS's name is GND (or whatever name is your gnd
    signal).
    Yes, they are. I named them to connect to the GND planes. So I'll just
    ignore the DRC error.
  • esilviu
    esilviu over 16 years ago
    signal).
    news:hif40t$lnm$1@cheetah.cadsoft.de...
    news:hied94$n06$1@cheetah.cadsoft.de...
    "Thiago Henrique Rodrigues" <thiago_hr@yahoo.com.br> escreveu na mensagem
    news:hidbj9$uje$1@cheetah.cadsoft.de...
    it,
    Overlap means that the net name of the via and the pad is not the same.
    Check the names of both. Placing a via there does not name it
    automatically. Click/write name, then click the vias to check their name.
    GND... I manually connected it using the VIAS. So I can leave it like this,
    Check the names of both. Placing a via there does not name it automatically.
