Forum Have a question about CadSoft EAGLE?  Ask our Expert, Richard! (Archive)
  • Replies 1129 replies
  • Subscribers 245 subscribers
  • Views 51379 views
  • eagle
  • expert
  • richard_hammerl
  • cadsoft
nlarson
nlarson over 16 years ago
This thread is now locked - but you can still ask Richard by posting your questions here.  If you'd rather browse other member's questions you can read the CadSoft EAGLE Forums for past questions and answers. Enjoy!
Browse past Q&A help on anything technical relating to CadSoft EAGLE!
Richard Hammerl
Richard is an engineer with 16 years experience in EAGLE customer support and is waiting for your questions.
  • heedaf
    heedaf over 15 years ago in reply to Richard_H
    This only provides the lenghts of the signals?  What about help in placing the traces?
    DeWayne
  • Richard_H
    Richard_H over 15 years ago in reply to levafreidin
    Hi Lev and Don,
    there are two ULPs that can help.
    length.ulp gives a list of all signals with its total lengths or when used with for example two signal names
    RUN length signal 1 signal2
    it gives a list of these two signals only.
    There is also length-freq-ri.ulp which gives a bit more information in the list of all signals. Try it. image
    Richard
  • heedaf
    heedaf over 15 years ago in reply to levafreidin
    Very clever!  I like it.  I'm going to have to do a lot of pairs so can this be done on a large scale?
  • levafreidin
    levafreidin over 15 years ago in reply to heedaf
    Hello Heedaf,
         I am sure there are files... but I make one trace from the pair wide as the sum of final traces + gap of the differential pair. After I finish layout, I change its width back to normal - and now there is enough room to place both traces in parallel.
        If you want to place traces in different layers (to do it you need, most probably, multilayer PCB), place one (let say, "top") trace first, keep room under it free than layout, "cut" whole trace (as "group"), "paste"  trace at the empty space, change its layer to "bottom" and move it as "group" to the designated place.
        Lev.
  • heedaf
    What is the best way to run a differential pair?  Is there any tricks or files I can run to help the process out?
    DR
    e14 Contributor over 15 years ago in reply to Richard_H
    Thanks Richard ... no need to send you the file as I've found the problem ... it was a case of 35 pins defined in the symbol and 34 pins in the package, due mainly (besides my oversight) to the data sheet for the part showing a NC pin in the pin list but no pad for it in the suggested footprint. Quite frustrating to find this the first time, would suggest some kind of more intelligent error message.
    Don
  • Richard_H
    Richard_H over 15 years ago in reply to e14 Contributor
    Panos,
    please check the settings in Windows 7 Control Panel, System and click onto Advanced System settings.
    There in the Advanced tab you find a button Environment Variable. Click it and check whther there is variable
    LANG defined. If not please set it to en_US.
    Does Designlink work then?
    Richard
    Richard Im using Winsows 7 but I'm not sure what do you mean about the locale settings?
    Regards Panos
  • Richard_H
    Hi Panos,
    no this can't be the problem. I am located in Europe as well and I can use the designlink ulp with Newark. I simply set the language setting to en_US and it works.
    What is your operating system and locale settings?
    Richard
    Do I get this problem because I am in Europe? Can I order from Newark when I;m outside US
    Best Regards
    Panos
