Raspberry Pi
Raspberry Pi
Documents Introducing The New Raspberry Pi 4 Model B 8GB
  • Author Author: e14phil
  • Date Created: 28 May 2020 5:50 AM Date Created
  • Last Updated Last Updated: 28 May 2020 8:11 AM
  • Views 14258 views
  • Likes 12 likes
  • Comments 12 comments
NEW! Raspberry Pi 4
Technical Specifications | GPIO Pin Out | Unboxing Video | Benchmark Tests | Comparison Chart | FAQ | Quiz | Pi Accessories | Pi Projects | RoadTest
Introducing the new addition to the Raspberry Pi 4 line, The Raspberry Pi 4 Model B 8GB.
This revision of the ever popular Raspberry Pi will be a welcome addition to most serious or even casual users.
It has the same physical footprint as the other Raspberry Pi 4 range, with some slight changes to the PCB, and TWICE the ram as the previous most powerful, 4GB, unit.
Users of the Raspberry Pi 4 have been crying out for more power and the Raspberry Pi Foundation has heard their call. This 8GB Raspberry Pi will give you the RAM headroom to open more chrome tabs and give your applications way more wiggle room.  This welcome upgrade will really help people use the Raspberry Pi 4 as a day to day computer.
RASPBERRY PI 4 MODEL B, 8GBRASPBERRY PI 4 MODEL B, 8GB
Buy The Raspberry Pi 4 8GB
Buy the Raspberry Pi 4 Model B 8GB here.
NEW! Raspberry Pi 4 Model B 8GB RAM
  • 1.5-GHz Quad Core Cortex-A72
  • Dual Micro-HDMI
    (Up to 4Kp60)
  • 5V/3A USB type C
  • 2x USB 3.0 and
  • USB 2.0
  • 8GB RAM
1GB RAM
2GB RAM
4GB RAM
  • 1.5-GHz
  • Dual Micro-HDMI
    (Up to 4Kp60)
  • 5V/3A USB type C
  • 2x USB 3.0
  • 2x USB 2.0
  • 1GB RAM
RASPBERRY PI 4 MODEL B, 1GBRASPBERRY PI 4 MODEL B, 1GB
  • 1.5-GHz
  • Dual Micro-HDMI
    (Up to 4Kp60)
  • 5V/3A USB type C
  • 2x USB 3.0
  • 2x USB 2.0
  • 2GB RAM
RASPBERRY PI 4 MODEL B, 2GBRASPBERRY PI 4 MODEL B, 2GB
  • 1.5-GHz
  • Dual Micro-HDMI
    (Up to 4Kp60)
  • 5V/3A USB type C
  • 2x USB 3.0
  • 2x USB 2.0
  • 4GB RAM
RASPBERRY PI 4 MODEL B, 4GBRASPBERRY PI 4 MODEL B, 4GB
The Board that should not have existed.
Some of you may remember that when the initial versions of the Raspberry Pi 4 launched, the Compliance leaflet mentioned a 8GB Variant, to which all hopes were quickly squashed as a typo.
To quote Eben Upton:
While we launched with 1GB, 2GB and 4GB variants, even at that point we had our eye on the possibility of an 8GB Raspberry Pi 4. We were so enthusiastic about the idea that the non-existent product made its way into both the Beginner’s Guide and the compliance leaflet.
The BCM2711 chip that we use on Raspberry Pi 4 can address up to 16GB of LPDDR4 SDRAM, so the real barrier to our offering a larger-memory variant was the lack of an 8GB LPDDR4 package. These didn’t exist (at least in a form that we could address) in 2019, but happily our partners at Micron stepped up earlier this year with a suitable part. And so, today, we’re delighted to announce the immediate availability of the 8GB Raspberry Pi 4, priced at just $75.
How to Identify your Raspberry Pi 4 8GB
To Identify the amount of ram on your Raspberry Pi 4 you simply need to have a look at the numbers written on the RAM Chip and match them to this handy guide:
1GB - 4HBMGCJ
2GB - D9WHZ
4GB - D9WHV
8GB - D9ZCL
Raspberry Pi 4 8GB - D9ZCL
Raspberry Pi 4 8GB PCB Changes
As we spotted in our unboxing video the Raspberry Pi 4 8GB has some PCB changes that help out the new beefier memory package.
James at the Raspberry Pi Foundation has shuffled the power supply components around the board, removing a switch-mode power supply from the right-hand side of the board next to the USB 2.0 sockets and adding a new switcher next to the USB-C power connnector.
In addition to the changes in power supply components the Raspberry Pi 4 8GB has had some changes to the silkscreen on the back.
Will my old case fit the New Raspberry Pi 4?
Fairly unlikely that your pre-raspberry pi 4 case will fit and if it does It likely wont have I/O holes in the right places for the new Micro HDMI, USB 3, USB C and Ethernet, but any case made for any version of the Raspberry Pi 4 will fit.
Will I need a new charger for the Raspberry Pi 4?
Yes. This one swap is the greatest positive, you are now less constrained and less likely to get "Brown Outs" caused by power hungry peripherals.
Will my GPIO Hat work on the new Raspberry Pi?
Very Likely! The Raspberry Pi 40Pin GPIO is built to be backwards compatible! You can double-check this here: Raspberry Pi 4 Model B Default GPIO Pinout with PoE Header
Will I need a new version of the PoE hat?
No, the PoE HAT designed for the Raspberry Pi 3 Model B+ is fully compatible with the Raspberry Pi 4 Model B.
element14 Recommended Accessories
Due to the change in board layout and the new USB Type C power connector, we recommend the following accessories.
USB Power Supplies
USB C Power Supplies
USB C Power SupplyManufacturer
5.1V, 3A USB-C PSU - UK WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - EU WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - US WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - AU WHITERaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - UK BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - EU BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - US BLACKRaspberry PiBuy NowBuy Now
5.1V, 3A USB-C PSU - AU BLACKRaspberry PiBuy NowBuy Now
Micro HDMI to HDMI Cable
Micro HDMI to HDMI CableManufacturer
1M MICRO-HDMI TO HDMI CABLE - WHITERaspberry PiBuy NowBuy Now
2M MICRO HDMI TO HDMI CABLE - WHITERaspberry PiBuy NowBuy Now
1M MICRO-HDMI TO HDMI CABLE - BLACKRaspberry PiBuy NowBuy Now
2M MICRO HDMI TO HDMI CABLE - BLACKRaspberry PiBuy NowBuy Now
Compatible Cases
Compatible Cases
Raspberry Pi 4 CasesManufacturer
Official Pi 4 CasesRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 CASE - BLACKMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - WHITEMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - CLEARMulticomp ProBuy NowBuy Now
RASPBERRY PI 4 CASE - REDMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - BLACKMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - WHITEMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - CLEARMulticomp ProBuy NowBuy Now
RPI 4 CASE W/PWR BUTTON - REDMulticomp ProBuy NowBuy Now
Want to know more?
Meet The New Raspberry Pi 4 Model B - element14 Presents
Raspberry Pi 4 Model B - Technical Specifications
Raspberry Pi 4 Model B Frequently Asked Questions (FAQ)
Benchmarking the Raspberry Pi 4 Model B
Which accessories are compatible with the New Raspberry Pi 4 Model B?
Do You Know Your Pi from Pie? Raspberry Pi Quiz!
Eben Upton talks about the new Raspberry Pi 4 Model B
Want to buy the new Raspberry Pi 4 Model B?
Product NameManufacturer
RASPBERRY PI 4 MODEL B, 1GBRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 MODEL B, 2GBRaspberry PiBuy NowBuy Now
RASPBERRY PI 4 MODEL B, 4GBRaspberry PiBuy NowBuy Now
RASPBERRY Pi 4 MODEL B, 8GBRaspberry PiBuy NowBuy Now
  • raspberry pi 4 8gb
  • raspberry pi 4 accessories
  • rpi 4 8gb
  • Fred27
    Fred27 over 6 years ago +4
    8GB was inevitable, wasn't it!
    shabaz over 6 years ago +4
    That's very neat! I've never looked into the A72 specs, and now the Pi 4 finally has 8GB DDR4, just out of curiosity I wonder if with an SSD it outperforms the average consumer laptop (not that it replaces…
  • ashutosh_pandey
    ashutosh_pandey over 6 years ago in reply to shabaz +4
    It entirely depends on the use case. Making a comparison is not at all straightforward because the Raspberry Pi is an ARM SBC while all laptops and desktops are x86 based. This makes benchmarking so much…
  • kmikemoo
    kmikemoo over 6 years ago
    This is AWESOME!  After playing with a RPi4 for the last couple of months, I agree with shabaz that this isn't a low-end computer any more.  Either that or I'm the only one with who is still trying to limp some old tower PC's along.
  • ashutosh_pandey
    The major limiting factor would be the USB 3.0 interface. Almost all modern SSDs use PCIe slots to achieve multiple GB/s of performance. The older Pi 3B+ had a theoretical maximum of 480 mbps , while the newer 4B can hit a max of 5 Gbps. The real world figures are half that roughly.
    Apparently some users have successfully managed to hack into the PCI express, although this appears to be not at all straightforward: Raspberry Pi 4 PCI Express: It actually works! USB3, SATA… GPUs? | "Domipheus Labs"
    For a comparison of external storage drives, you can check: https://www.google.com/amp/s/www.tomshardware.com/amp/news/raspberry-pi-4-ssd-test,39811.html
    In contrast, the RAM upgrade is huge. Not only does the 4B have 8 times the RAM, it's also LPDDR4, up from DDR2. That makes for a huge difference in performance.
    Ultimately these are still just numbers, real world usage is more than adequate, as long as you keep your expectations in check.
  • ashutosh_pandey
    This makes benchmarking so much more difficult. Several benchmarks are only for windows, and even if they exist for Linux, the Linux Raspberry Pi uses is not the same as the Linux x86 systems use (though they are superficially similar, the software written for one may not compile on the other).
    ARM based laptops are only just beginning to take off - Lenovo launched a laptop with Snapdragon 8CX. It doesn't perform anywhere near a midrange laptop yet. The reason we want ARM laptops is because the chips are so much more power efficient than their x86 counterparts.
    Given that the Pi is good enough for Browsing now (which is what most users do anyway) and it can run LibreOffice, open media files etc, it can work just fine as a low end computer. How ever the GPU isn't the strongest out there, and it lacks some of the features of bigger computers in terms of PCIe slots. Still, for anyone buying a generic computer off Craigslist, the RPi should be a suitable replacement given that they don't use any OS specific software.
    Just my 2 cents,
    Ashutosh
    shabaz over 6 years ago in reply to ashutosh_pandey
    Hi Ashutosh,
    ashutosh_pandey  wrote:
    This is proper low end desktop replacement territory.
    I think it might not be low-end any more, I would love to know though. Just speculating, that it might be typical PC/laptop performance (I bet most consumers do not purchase cutting-edge computers.. the local PC store here has maybe 5 laptops models with current or one previous generation CPU, and maybe 30 different models with CPUs that are several generations behind).
    That's very neat! I've never looked into the A72 specs, and now the Pi 4 finally has 8GB DDR4, just out of curiosity I wonder if with an SSD it outperforms the average consumer laptop (not that it replaces a laptop, but nice to get an idea of the performance difference) presuming that an average new-purchase laptop by parents for kids might still contain a several-generations old Core i3 or lower-performance processor,
    I wish raspberrypi.org would look at pricing though. The USD pricing doesn't work as well in the UK (and many other countries). Maybe time raspberrypi.org considered pricing differently for different regions, like any other manufacturer does. It isn't looking after consumers best interests that they use the old excuse that it has a fixed price worldwide in USD to reduce price fluctuations due to components being purchased in USD - other businesses manage it.
    DAB over 6 years ago
    They are doing a good job of keeping the series moving, while still trying to maintain its affordability.
  • aswinvenu
    aswinvenu over 6 years ago in reply to ashutosh_pandey
    Okay It came on February this year. Missed that! I still have the old version.
    https://hackaday.com/2020/02/23/raspberry-pi-slips-out-new-pcb-version-with-usb-c-power-fix/
  • ashutosh_pandey
    ashutosh_pandey over 6 years ago in reply to aswinvenu
    They fixed that on the 1,2 and 4 GB versions before with a hardware update. It should be safe to say that since this board is releasing way after the fix, it should not be a problem.
  • aswinvenu
    Did they fix the smart USB-C charging issue?
  • dwinhold
    dwinhold over 6 years ago
    Next dual processors? It’s only getting cooler!!
    Dale
