RoadTests & Reviews
RoadTests & Reviews
Review Blogs Illuminated Tricopter - Headlights
  • Blogs
  • RoadTests
  • Reviews
  • Author Author: tomaja
  • Date Created: 17 Jan 2016 6:44 PM Date Created
  • Views 2647 views
  • illuminated_multirotor
  • tps92512
  • wuerth_elektronik
  • ledroadtestplus
  • led
tomaja
tomaja
17 Jan 2016
Related posts:
Kit unboxing - LED RoadTest
Introduction to Bluetooth Low Energy Light Development Kit - CC2540TDK-LIGHT
Android Support for TI's BLE LED Control
MSP430FR4133 Launchpad - Magnetic North Visualisation
Illuminated Tricopter Upgrade - Adding an Addressable LED Ring
MSP430FR4133 BoosterPack for Illuminated Tricopter
Bookshelf Lights Using TI's CC2450 BLE LED Modules
MSP430FR4133 Launchpad with Custom BoosterPack in Action
MSP430FR4133 Launchpad with Custom BoosterPack in Action - appendix
MSP430FR4133 Launchpad with Custom BoosterPack update
Adding Remotely Controlled Headlights to Tricopter
Preparing headlights
Last couple of days I spent on making the headlights using Würth Elektronik’s bright LEDs driven by TPS92512TPS92512 evaluation module.
Aluminium substrate boards were used as they provide proper heat sinking. I got a bunch of them from eBay seller for just $2.5.
Würth Elektronik provided us with required components from their portfolio and I chose these LEDs High Brightness LED, WL-SWTC Series, WhiteHigh Brightness LED, WL-SWTC Series, White.
I also got some spacers that I used to mount the Launchpad to and rotary encoders which ended up unused.
I soldered the LED using solder paste and hot air soldering station. It all went very well and I soldered 8 LED without a fail.
TPS92512EVM found its place in a small repurposed box under the Launchpad (the way I remotely control TPS92512 was described in my previous post - Adding Remotely Controlled Headlights to Tricopter)
Yesterday I spent my free time on making the headlights enclosure using some depron, thick paper and super glue. Reflective surface was made using aluminium foil glued to thick paper.
I didn’t take too many pictures of this process but I have some and of course image of the final product is here:
{gallery} Headlights
Aluminium foil: Aluminium foil used as reflective surface inside headlights
Headlights: Würth LEDs inside thick paper case
Top view: Aluminium heatsink attached to four aluminium boards with LEDs (back side).
Plywood mount: Headlights are attached using plywood bracket
ON: Headlights turned on
This blog series will be finished with my last post where I make a short overview of everything I did during these 2 months + video footage of night flight.
Thanks,
Dragan
    mcb1 over 10 years ago +1
    Very clever method of providing directivity. I've added some of these to my order basket. Thanks Mark
    Thanks
