Renesas CAT-M1 Cloud Kit CK-RA6M5
View table of contents
RoadTest Goals
This is a new product, so the sponsor would like the RoadTester to test the out of box experience of the product. Building a simple IOT project would be an ideal way to test this product. The board has a number of sensors, so those could be tested and reviewed. Connecting it to the Cloud would be another thing to be tested. It has Testing the documentation should be included in the roadtest. The review should share your experience of the product.
Product Variants
  • CK-RA6M5 – this is the one we are using for this roadtest
  • CK-RX65N
Description
The CK-RA6M5 cloud kit enables users to securely connect to the cloud and explore the features of the Cortex®-M33 based RA6M5 group of MCUs and cloud services.
With Renesas’ LTE Cellular CAT-M1 module RYZ014A and ethernet network connectivity options the kit provides a seamless cloud connectivity experience to most of the global cloud service providers. With Renesas Flexible Software Package (FSP) the kit has complete software stack support using FreeRTOS, AzureRTOS and other middleware stacks, thereby making it an ideal platform for efficiently developing cloud solutions and greatly reducing the time-to-market.
The cloud kit is equipped with Renesas’ RYZ014A Cat-M1 module, a certified LTE cellular module that offers the ability to establish wireless connection between MCUs and cloud services quickly and securely without a gateway.
The kit is ready to connect to global cloud service providers such as AWS Cloud and IoT services. Both kits are designed to run on AWS (Amazon Web Services) FreeRTOS for CK-RA6M5 using FSP (Flexible Software Package) and CK-RX65N using RDP (RX Driver Package). Once connected to AWS IoT Core, the kits have access to many Cloud and IoT services from AWS for data analytics and IoT device management.
Features
  • LTE CAT-M1 with RYZ014A Pmod
  • Ethernet
  • 0 Full Speed Host and Device
  • Multiple on-board sensors
  • 2 MEMS microphones
  • 2-pin header for battery connector
  • 5V input through USB or external power supply
  • USB-serial converter
  • Debug on-board2 Digilent Pmod (SPI/UART/I2
  • C) connectors
  • MCU and Pmod current measurement points
  • ArduinoTm (Uno R3) connector
Kit Contents
  • CK-RA6M5 v1 board
  • RYZ014A PMOD (CAT-M1 Cellular Module)
  • Micro USB to A cable
  • Micro USB A/B to A adapter cable
  • SIM card
  • Antenna
Onboard Sensors
  • Humidity & Temp
  • Indoor Air Quality
  • Outdoor Air Quality
  • Biometric
  • Barometric Pressure
  • IMU Gyroscope/Accelerometer/Magnetometer
  • MEMS Microphones
FSP is an enhanced software package designed to provide easy-to-use, scalable, high-quality software for embedded system designs using Renesas RA Family of Arm Microcontrollers.
Note: FSP with e² studio Installer (Platform Installer) will install the e² studio tool, FSP packs, GCC toolchain and Segger J-Link drivers required to use this software. No additional installations are required.
Additional Information
Cloud Kit Overview
Getting Started
RA6M5 MCUs
LTE CAT M1 Modem Datasheet
RYZ014A LTE Cat-M1 Cellular IoT Module
RYZ014A Pmod Expansion Board - Quick Start Guide
Quick Start Guide
AWS Dashboard Note
Simplify Cellular-to-Cloud Development with the Renesas Cloud Kits
Cloud Kit Page
RA AWS MQTT/TLS Cloud Connectivity Solution – Cellular
CAT-M1 Cloud Kit Forum
Use this thread to comment or ask any questions about the CAT-M1 Cloud Kit.
Important Dates
Begin enrollment: August 15, 2022
End enrollment: Oct 31, 2022*
Select roadtesters: Nov 2 2022*
Ship unit: Nov 16 2022
Begin Roadtesting: Nov 21 2022
Element14 follow up: Dec 21 2022
Post Reviews by: Jan 21 2022
Enrollment extended
Terms and Conditions
Click Here to read the Terms and Conditions.
Roadtesters
  • skruglewicz - due date Jan 17 2023
  • work14 - due date Jan 21 2023
  • badjasper - due date Jan 21 2023
  • hajami - due date Jan 21 2023
RoadTest Reviews
Comment List
