FPGA
FPGA
Blog Creating a Custom Kria App - Part 1
  • Author Author: albertabeef
  • Date Created: 30 Dec 2021 4:11 PM Date Created
  • Views 11805 views
  • Comments 6 comments
  • firmware
  • kria
  • vvas
  • overlay
  • kv260
  • vitis-ai
  • app
  • dfx-mgr
  • kria app
  • smart_model_select
  • xmutil
albertabeef
albertabeef
30 Dec 2021
This blog is part of a series of blogs which describe the development steps for an in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-blog
This part of the tutorial provides a description of the Xilinx repositories that will be used.
Installing the Xilinx tools
The following tools will be used for this tutorial
Xilinx Tools
Version
Vitis Core Development Kit
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vitis/2021-1.html
2021.1
Petalinux
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools/2021-1.html
2021.1
Petalinux eSDK update 1
https://xilinx.github.io/kria-apps-docs/main/build/html/docs/build_petalinux.html
2021.1 update 1
NOTE : The eSDK update 1 for use with Kria is not compatible with other platforms so should be kept separate, if working on other platforms as well.
Creating a base directory
This project tutorial can be placed in any location on your linux machine.
To facilitate the flow of the tutorial, we will define an environment variable corresponding to this base directory for the project.
$ export PROJ_DIR=$(pwd)
$ cd $PROJ_DIR
Cloning the Xilinx repositories
The following repositories will be used for this tutorial.
Xilinx Repository
Branch
https://github.com/Xilinx/kv260-vitis
release-2021.1
https://github.com/Xilinx/kv260-firmware
release-2021.1
https://github.com/Xilinx/Vitis-AI
v1.4
https://github.com/Xilinx/VVAS
VVAS_REL_v1.0
On a linux machine, clone the following repositories to the same location:
$ cd $PROJ_DIR
$ git clone -b release-2021.1 https://github.com/Xilinx/kv260-vitis
$ git clone -b release-2021.1 https://github.com/Xilinx/kv260-firmware
$ git clone -b v1.4 https://github.com/Xilinx/Vitis-AI
$ git clone -b VVAS_REL_v1.0 https://github.com/Xilinx/VVAS
Downloading the Xilinx smart_model_select archives
We will also make use to the following pre-built solution for ZCU104:
  • https://www.xilinx.com/member/forms/download/xef.html?filename=vvas_smart_model_select_2021.1_zcu104.zip
We will also make use of the provided video files:
  • https://www.xilinx.com/member/forms/download/xef.html?filename=videos_smart_model_select.zip
Download and extract these archives to the same location as the previous repositories.
Downloading the modified source files and pre-built binaries
Throughout this tutorial, some of the source file will be modified, to create new binaries targeting the Kria KV260 Vision AI Starter Kit.
Although not required to complete the tutorial, the modified files and pre-built binaries are provided for reference:
  • Modified source files
    • http://avnet.me/kv260-vvas-sms-2021-1-files
      (2022-01-10 - md5sum : 095a29873297295b462dc881768b9f9b)
  • Pre-built binaries
    • http://avnet.me/kv260-vvas-sms-2021-1-prebuilt
      (2022-01-10 - md5sum : f3fa7059d657a2f0bd115cafb325ff41)
These archives can be extracted to the same location as the previous content.
Understanding the Vitis platforms and examples
The Vitis Examples (VVAS) and Overlays (kv260-vitis) provided by Xilinx have the following architecture:
The Vitis Examples and Overlays are built on top of Vitis platforms.
The Vitis platforms are composed of:
  • Hardware – Vivado project
  • Software – Petalinux project, or other
An important observation is that the Vitis platforms may or may not include the petalinux project corresponding to the vivado project.
For the ZCU104 platforms (VVAS), the petalinux projects are included.
For the KV260 platforms (kv260-vitis), the petalinux project is not provided.  Instead, a common petalinux project will be used to dynamically load the “overlay”.  We can define that our custom Kria app will be a dynamically loaded “overlay”.
The Vitis platform is a wrapper, that defines the resources that are available, including:
  • Resources (LUTs, FFs, BRAMs, URAMs, DSPs, etc…)
  • Interconnect
  • Clocks
  • Resets
  • Interrupts
The Vitis Examples and Overlays define and instantiate one or more accelerators, which may include:
  • DPU
  • HLS-based functions from the Vitis Accelerated Libraries
The “VVAS” and “kv260-vitis” repositories both contain examples of this, as shown below:
Vitis Platform
Vitis Example / Overlay
VVAS/ivas-platforms/Embedded
  • zcu104_vcuDec_DP
  • zcu104_vcuDec_vmixHdmiTx
VVAS/ivas-examples/Embedded
  • multichannel_ml
k260-vitis/platforms/
  • kv260_ispMipiRx_vcu_DP
  • kv260_vcuDecode_vmixDP
  • kv260_ispMipiRx_vmixDP
  • kv260_ispMipiRx_DP
k260-vitis/overlays
  • smartcam, benchmark
  • aibox-reid
  • defect-detect
  • nlp-smartvision
The “VVAS” repository includes two (2) platforms, and two (2) examples:
The smart_model_select and multichannel_ml examples both implement the following accelerators:
  • preprocess : multi-channel scaler with color space conversion and normalization
  • AI engine : B4096 DPU
Each of the VVAS vitis platforms include a combination of the following features:
  • vcuDec : VCU, in decode only configuration
  • DP : DisplayPort output
  • vmixHdmiTx : HDMI output with video mixer
    • zcu104_vcuDec_vmixHdmiTx has nine NV12 layers
Both examples target a ZCU104 platform with VCU (decode only).
The smart_model_select example provides support for 16 different models from the Xilinx Model Zoo, executing one at a time, and using the DisplayPort as output.
The multichannel_ml example provides support for 4 different models, and uses the platform enabled with Video Mixer and HDMI TX to display up to 8 streams at the same time on the HDMI monitor.
The “kv260-vitis” repository includes four (4) platforms, and five (5) overlays:
Each of the kv260 vitis platforms include a combination of the following features:
  • ispMipiRx : MIPI capture pipeline, for use with the AR1335 sensor module
  • vcu : VCU, in decode + encode configuration
  • vcuDecode : VCU, in decode only configuration
  • vmixDP : DisplayPort output with video mixer
    • kv260_vcuDecode_vmixDP has one BGRA8 layer and four NV12 layers
    • kv260_ispMipiRx_vmixDP has one BGRA8 layer and four Y8 layers
We can see that the kv260_ispMipiRx_vcu_DP platform, which includes a MIPI capture pipeline and VCU in decode + encode configuration, is used for two different overlays.
The smartcam overlay implements the following accelerators:
  • preprocess : normalization and scaling
  • AI engine : B3136 DPU
The benchmark overlay implements the following accelerator:
In this tutorial, we will combine the following two components together to create our custom Kria app:
  • Vitis Example/Overlay : smart_model_select, from VVAS repository
  • Vitis Platform : kv260_ispMipiRx_vcu_DP, from kv260-vitis repository
Next Steps
The following blogs will cover the remaining development steps for this in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-part2
  • http://avnet.me/kv260-vvas-sms-2021-1-part3
  • http://avnet.me/kv260-vvas-sms-2021-1-part4
  • http://avnet.me/kv260-vvas-sms-2021-1-part5
  • http://avnet.me/kv260-vvas-sms-2021-1-part6
  • http://avnet.me/kv260-vvas-sms-2021-1-part7
Revision History
Revision
Date
Description
1.0
2022/01/12
Initial Version, ready for publishing Blush
1.1
2022/02/24
Update part 1 to specify "VVAS_REL_v1.0" branch for VVAS repository.
  • albertabeef
    albertabeef over 4 years ago
    Please note that a new version of the modified files and pre-built binaries was updated on January 10, 2022 (20220110):
      • kv260-vvas-sms-2021-1-files-20220110.zip
      • kv260-vvas-sms-2021-1-prebuilt-20220110.zip
        (2022-01-10 - md5sum : c0ba002bd340828b282b9f7549fe46dd)
  • albertabeef
  • ralphjy
    ralphjy over 4 years ago in reply to albertabeef
    Hi Mario,
    I think that your prebuilt zip archive may not have built correctly.  The md5sum is correct but it won't extract in either Win10 or Ubuntu.  Could you verify that it will extract correctly.  Maybe something on my end.
    In Win10:
    In Ubuntu the error message is more verbose:
    $ unzip kv260-vvas-sms-2021-1-prebuilt-20220110.zip
    Archive: kv260-vvas-sms-2021-1-prebuilt-20220110.zip
    End-of-central-directory signature not found. Either this file is not
    a zipfile, or it constitutes one disk of a multi-part archive. In the
    latter case the central directory and zipfile comment will be found on
    the last disk(s) of this archive.
    note: kv260-vvas-sms-2021-1-prebuilt-20220110.zip may be a plain executable, not an archive
    unzip: cannot find zipfile directory in one of kv260-vvas-sms-2021-1-prebuilt-20220110.zip or
    kv260-vvas-sms-2021-1-prebuilt-20220110.zip.zip, and cannot find kv260-vvas-sms-2021-1-prebuilt-20220110.zip.ZIP, period.
    I can see the two binaries but they won't extract.  I have been running the prebuilt image from your Hackster project, but decided to try the updated files.
  • ralphjy
    Hi Mario,
    I just tried to provide you feedback on problems that I have trying to extract the prebuilt archive, but it got flagged as spam.  Hope that it will clear moderation.
    Ralph
  • albertabeef
    albertabeef over 4 years ago in reply to ralphjy
    Ralph,
    As always, thank you for your valuable feedback.
    You are correct, there is an issue with the prebuilt archive ... I am re-uploading, and will update the md5sum soon ...
    Regards,
    Mario.
  • albertabeef
    Ralph,
    I updated the archive for the pre-built archive, and updated the md5sum.
    Use the same link:
    Very sorry about this inconvenience, and thank you very much for bring this to my attention.
    Regards,
    Mario.
