FPGA
FPGA
Blog Creating a Custom Kria App - Part 2
  • Author Author: albertabeef
  • Date Created: 10 Jan 2022 1:14 PM Date Created
  • Views 10329 views
  • Comments 19 comments
  • firmware
  • kria
  • vvas
  • overlay
  • kv260
  • vitis-ai
  • app
  • dfx-mgr
  • kria app
  • smart_model_select
  • xmutil
albertabeef
albertabeef
10 Jan 2022
This blog is part of a series of blogs which describe the development steps for an in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-blog
This part of the tutorial describes how to create the Vitis Platform for our custom Kria App.
Building the Vitis Platform
In order to build the kv260_ispMipiRx_vcu_DP platform, simply invoke make as shown below:
$ cd $PROJ_DIR/kv260-vitis
$ make platform PFM=kv260_ispMipiRx_vcu_DP
After the build, the Vitis Platform will be located in the following location:
platforms/xilinx_kv260_ispMipiRx_vcu_DP_202110_1
Understanding the Vitis Platform
We already mentioned that the Vitis platform is a wrapper that defines the available resources for use by Vitis.  We can query these resources with the platforminfo command:
$ platforminfo platforms/xilinx_kv260_ispMipiRx_vcu_DP_202110_1/kv260_ispMipiRx_vcu_DP.xpfm
Basic Platform Information
Platform:           kv260_ispMipiRx_vcu_DP
File:               .../kv260_ispMipiRx_vcu_DP.xpfm
Description:
Hardware Platform (Shell) Information
Vendor:                           xilinx
Board:                            kv260_ispMipiRx_vcu_DP
Version:                          1.0
Generated Version:                2021.1
Hardware:                         1
Software Emulation:               1
Hardware Emulation:               1
Hardware Emulation Platform:      0
FPGA Family:                      zynquplus
FPGA Device:                      xck26
Board Vendor:                     xilinx.com
Board Name:                       xilinx.com:kv260:1.1
Board Part:                       XCK26-SFVC784-2LV-C
Clock Information
  Default Clock Index: 0
  Clock Index:         0
    Frequency:         299.997000
  Clock Index:         1
    Frequency:         599.994000
  Clock Index:         2
    Frequency:         99.999000
Memory Information
  Bus SP Tag: HP1
  Bus SP Tag: HP3
  Bus SP Tag: HPC1
  Bus SP Tag: LPD
Software Platform Information
Number of Runtimes:            1
Default System Configuration:  kv260_ispMipiRx_vcu_DP
System Configurations:
  System Config Name:                      kv260_ispMipiRx_vcu_DP
  System Config Description:               kv260_ispMipiRx_vcu_DP
  System Config Default Processor Group:   smp_linux
  System Config Default Boot Image:        standard
  System Config Is QEMU Supported:         1
  System Config Processor Groups:
    Processor Group Name:      smp_linux
    Processor Group CPU Type:  cortex-a53
    Processor Group OS Name:   linux
  System Config Boot Images:
    Boot Image Name:           standard
    Boot Image Type:
    Boot Image BIF:            kv260_ispMipiRx_vcu_DP/boot/linux.bif
    Boot Image Data:           kv260_ispMipiRx_vcu_DP/smp_linux/image
    Boot Image Boot Mode:      sd
    Boot Image RootFileSystem:
    Boot Image Mount Path:     /mnt
    Boot Image Read Me:        kv260_ispMipiRx_vcu_DP/boot/generic.readme
    Boot Image QEMU Args:      kv260_ispMipiRx_vcu_DP/qemu/pmu_args.txt:kv260_ispMipiRx_vcu_DP/qemu/qemu_args.txt
    Boot Image QEMU Boot:
    Boot Image QEMU Dev Tree:
Supported Runtimes:
  Runtime: OpenCL
We can see that the following clocks and interconnects are available for use by Vitis:
  • Clocks
    • 300MHz
    • 600MHz
    • 100MHz
  • High-Performance Interconnect
    • LPD
    • HP1
    • HP3
    • HPC1
This information will be important when configuring a Vitis Example or Overlay to be built with this Vitis platform.
Next Steps
The following blogs cover the previous development steps for this in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-part1
The following blogs will cover the remaining development steps for this in-depth project tutorial.
  • http://avnet.me/kv260-vvas-sms-2021-1-part3
  • http://avnet.me/kv260-vvas-sms-2021-1-part4
  • http://avnet.me/kv260-vvas-sms-2021-1-part5
  • http://avnet.me/kv260-vvas-sms-2021-1-part6
  • http://avnet.me/kv260-vvas-sms-2021-1-part7
  • juanyi
    juanyi over 4 years ago in reply to albertabeef +2
    I have a positive news to share, searching through xilinx support and found this thread. https://support.xilinx.com/s/question/0D52E00006vFXkwSAG/is-there-a-workaround-for-vivado-rdiprog-crash-during-synth…
  • schneisw
    schneisw over 4 years ago +1
    Tip: If you are getting some errors after running make, you might not have sourced the settings scripts for both Vivado and Vitis. I noticed this after doing neither, and then only Vivado, which incidentally…
    Jan Cumps over 4 years ago in reply to juanyi +1
    Before my Ubuntu knows where the tools are, I first have to execute an environment setting script: for Vivado: source /tools/Xilinx/Vivado/2020.2/settings64.sh for Vitis: source /tools/Xilinx…
  • schneisw
    Tip:
    If you are getting some errors after running make, you might not have sourced the settings scripts for both Vivado and Vitis.  I noticed this after doing neither, and then only Vivado, which incidentally gave me a successful return on “which vitis” resulting in my not sourcing the Vitis script until later.
  • schneisw
    Tip:
  • schneisw
    schneisw over 4 years ago in reply to schneisw
    Also source the petalinux setup script and this bug fix per the instructions in part 1:
    petalinux-upgrade -u 'petalinux.xilinx.com/.../' -p 'aarch64'
  • juanyi
    juanyi over 4 years ago in reply to schneisw
    hi, i'm new to vitis and vivado. I'm trying to follow this tutorial but already having difficulty to get started. I had installed the vitis & vivado in Ubuntu 18.04, had error when i run the first line
    the error is:
    make[2]: /bin/vivado: Command not found
    Makefile:29: recipe for target 'project/kv260_ispMipiRx_vcu_DP.xsa' failed
    make[2]: *** [project/kv260_ispMipiRx_vcu_DP.xsa] Error 127
    make[2]: Leaving directory '/home/yyee/Desktop/Custom/kv260-vitis/platforms/vivado/kv260_ispMipiRx_vcu_DP'
    Makefile:42: recipe for target 'vivado/kv260_ispMipiRx_vcu_DP/project/kv260_ispMipiRx_vcu_DP.xsa' failed
    Can you show me how to source the setting scripts? Thanks in advance.
  • javagoza
    javagoza over 4 years ago in reply to juanyi
    I think he refers to run the settings script with the source command
    https://xilinx.github.io/kria-apps-docs/main/build/html/docs/build_petalinux.html
    for Vivado:
    for Vitis:
    source /tools/Xilinx/Vitis/2020.2/settings64.sh
    For Vitis HLS:
    source /tools/Xilinx/Vitis_HLS/2020.2/settings64.sh
    Jan Cumps over 4 years ago in reply to Jan Cumps
    (edit: it doesn't matter which of the 3 scripts you call, because they are identically and all work for vivado, Vitis and vitis_hls)
