FPGA
FPGA
Blog Port a VHDL design from AMD Zynq & Pynq to Spartan-7 & MicroBlaze - part 1: hardware
  • Date Created: 9 May 2023 6:42 PM Date Created
  • Views 2462 views
  • Likes 11 likes
  • Comments 7 comments
  • amdzynqultrasoundpulse
  • zynq
  • fpga
  • vivado
  • vhdl
  • pynq
  • amd
  • vitis
  • microblaze
9 May 2023
A little double post to document the porting of a small FPGA design from a Zynq with ARM + Linux + Pynq + Python to a smaller Spartan with MicroBlaze soft controller + bare metal.
The post focuses on the software / firmware aspect. How I migrated logic running on the physical microcontroller inside the Zynq package, to firmware in a MicroBlaze soft controller core inside the Spartan fabric.
The original VHDL design is a set of IPs that generate pulses for an ultrasone instrument. That part ports as-is between Spartan and Zynq without changes. I will not elaborate on it. Check here to learn more: Learning AMD Zynq: a project to generate a set of PWM signals. 1 - problem statement and possible approach.
Hardware
This is the Spartan-7 block diagram. Blue on the left is the MicroBlaze soft controller core and friends. Middle green parts is the interface between the software and fabric. Virtually identical to what I used in the Zynq. The blue block on the right is the unchanged VHDL. A few contraptions to replace the Pynq / Jupyter user interface are purple at the top right side.
And the same design on a Zynq. Here, the software runs on a hard ARM microprocessor core, at the left in blue. The green register and clock bridges, and VHDL at the right, are identical.
part 2 will review the software and the process to write it.
  • dang74
    dang74 over 3 years ago in reply to Jan Cumps
    True enough.
    Jan Cumps over 3 years ago in reply to dang74
    > useful to those that need to 'downgrade' from hard Arm to soft Microblaze.
    Maybe also for those that have to choose between them, for a new design...
    I posted part 2, about the software approach for Spartan-7 vs ZYNQ/PYNQ:  Port a VHDL design from AMD Zynq & Pynq to Spartan-7 & MicroBlaze - part 2: software
  • dang74
    True I agree on the portability of the VHDL.  This blog is most useful to those that need to 'downgrade' from hard Arm to soft Microblaze.  Also if they aren't well acquainted with the Vivado HLS block diagram methodology they will surely appreciate the side by side top level blocks you presented here for Spartan 7 and Zynch.  I am going to tear apart the lab at work and try to find that darn Arty.  That way I can retrace some of your steps and get some practice in with Vivado... you know, to justify its 40GB install.  Wink
    Jan Cumps over 3 years ago in reply to DAB
     DAB , and I used only standard constructs in the VHDL part. No vendor specific. It ported unchanged between 2 AMD FPGA families. But I'd expect that this VHDL code would port without problems for any manufacturer.
