FPGA
FPGA
Blog Program MiniZed over WiFi using Simulink
  • Author Author: mbrown
  • Date Created: 15 Feb 2018 11:02 PM Date Created
  • Views 4041 views
  • Comments 17 comments
  • soc
  • avnet design
  • avnet
  • zynq
  • xilinx
  • fpgafeatured
  • mathworks
  • matlab
  • matthew brown
  • avnet_coding
  • minized_content
  • simulink
  • minized
mbrown
mbrown
15 Feb 2018
Though MiniZed be but small, she is fierce.
A terrible use of Shakespeare’s famous quote, but still a perfect fit for MiniZedTm and its Xilinx ZynqTm SoC.
In this blog we’ll explore a new way to program this fierce little board without being an SoC expert.
At first glance it may be daunting to start your design, but there’s good news for anyone new to SoC programming. Avnet created a support package to enable you to program MiniZed using code generation directly from SimulinkRegistered. This means that you don’t need to be an SoC expert or write a single line of HDL or C code. Instead we leverage the MathWorks Guided Workflow for Zynq, allowing you to explore at the application level.
You can also impress your friends by doing it all over WiFi – no cords!
Start your design in Simulink. Once you’ve perfected your algorithm model and the simulations look good, the code generation tools will handle the minutia of IP peripheral creation, AXI4 data movement, Linux device drivers, application code, and finally building and executing the deployed model on MiniZed. That’s a mouthful!
Here’s a simplified diagram to help you visualize what’s automatically created for you. In a word – everything.  You just need to come up with the algorithm. The tools do the rest.
Not shown here, but extremely useful, is the ability to communicate with your deployed model from Simulink through a network connection. This can be either a USB-to-Ethernet adapter, or wirelessly through your WiFi router.
Simulink comes from MathWorks, the makers of MATLABRegistered. Both tools are familiar to engineers who need to model and simulate computational algorithms. The Avnet MiniZed Support Package for Simulink provides the customizations needed to target the hardware on MiniZed. The package can be downloaded from MATLAB’s Add-On Explorer or on the web at MATLAB File Exchange (search for ‘avnet minized’).
Installation is just a few mouse clicks. It includes a Getting Started tutorial to walk you through your first design – blinking an LED (of course). From there, you can start designing your own algorithm for MiniZed.
You won’t need to set aside an entire Tuesday to get started. Get a cup of coffee and try it out one morning this week.
Just another way to have some fun with this fierce little board.
If you don't have a MiniZed yet, click this link: Buy MiniZedBuy MiniZed
Enjoy!
  • michaelkellett
    michaelkellett over 8 years ago in reply to genebren +4
    Before you get too carried away try checking out the cost of the other software you need to use this: https://uk.mathworks.com/matlabcentral/fileexchange/66004-avnet-minized-support-package-for-simulink…
  • weiwei2
    weiwei2 over 8 years ago in reply to mbrown +2
    ok this solves the problem. It is my mistake to have miss this step
    genebren over 8 years ago +1
    Nice write up. Soon you will have everyone writing code for FPGAs.
  • weiwei2
    I use MATLAB R2017b, and unlike the support package getting started guide where we can click YES to accept the incompatible xilinx, i don't have the YES button. How to force this?
  • weiwei2
  • michaelkellett
    michaelkellett over 8 years ago in reply to weiwei2
    Why not get the tool version it wants - should be possible to get the old one if you have a current license.
    MK
  • mbrown
    mbrown over 8 years ago in reply to weiwei2
    After installing the MiniZed Support Package for Simulink, did you run the minized_setup.m script (this is step #3 under "Set Up MATLAB")?
    The script performs the SDK version limit override.
    /Matt
  • weiwei2
    weiwei2 over 8 years ago in reply to michaelkellett
    the Avnet support package needs 2017.2 and above
  • weiwei2
  • mbrown
    Great - glad you have it working!
    FYI - our support package works with Vivado 2017.1 and 2017.2, MATLAB R2017a/b
