FPGA
FPGA
Blog Received Arty-S7 Board
  • Author Author: misaz
  • Date Created: 28 May 2022 2:20 PM Date Created
  • Views 1541 views
  • Likes 8 likes
  • arty-s7
  • xilinx
  • fpga
  • spartan-7 fpga
  • digilent
  • arty s7
  • spartan-7
  • verilog
  • spartan
misaz
misaz
28 May 2022
Hello everyone.
Yesterday I received Arty S7 Board for the 7 Ways to Leave Your Spartan-6 FPGA contest.
Board is offered available in two variants differing in FPGA. We received the better variant with Spartan XC7S50 FPGA featuring 52160 logic cells, 2700 kilobits of RAM memory (after bits to bytes conversion it is 337.5 kilobytes), 120 DSP blocks and much more.
Board looks nice and is preloaded by demo featuring buttons, switches, LEDs and RGB leds.
I started with installing Vivado of course. Since I used Vivado last time it grown again, so I begin with cleaning disk for being able to install it. Blush It requires 120 GiB of storage when installing and after installation it occupy almost 80 GiB of disk storage. WTF?!
After installing I of course tried to make my own simple demo for testing functionality of the board. So, I created simple verilog module blinking with led.
module led_test(input wire clk, input wire rst, output reg led);
    reg [24:0] timer;
    always @(posedge clk) begin
        if (rst == 1) begin
            led <= 1;
            timer <= 0;
        end else begin
            if (timer >= 1000000) begin
                led <= ~led;
                timer <= 0;
            end else begin
                timer <= timer + 1;
            end
        end
    end
endmodule
Then I deployed the code to the FPGA, and it worked well! So, I consider my board as functional and ready to make my project.
But before I start making my project, I need to complete blog posts about my experiments as part of Maxim Integrated Experimenting with Current Sense Amplifiers Design Chanllege. So, for next two weeks I will be quite about Spartan, but then I will come back, and I will post blogs about my project which I promised as part of application for this competition. Later I will connect some sensor to this board and finally I will make some experiment. So, thank you for reading this blog post and stay tuned. Blush
  • 14rhb
    14rhb over 4 years ago
    A great start, well done. The Arty S7 is a very useful board; I was kindly sent one many years back from E14 and it started my journey into FPGA and Vivado. I look forward to your future posts.
  • misaz
    misaz over 4 years ago in reply to javagoza
    Latest 2022.1
  • javagoza
    javagoza over 4 years ago
    Nice. I've also received the S7-50 variant.
    Which version of Vivado are you using?
