FPGA
FPGA
Blog Ultra96-V2 Dual Camera Mezzanine Petalinux Build Instructions
  • Author Author: ctammann
  • Date Created: 14 Jan 2021 9:14 PM Date Created
  • Views 6226 views
  • Comments 23 comments
  • image sensor
  • avnet
  • mezzanine
  • vision
  • petalinux
  • xilinx
  • ultra96
  • 96boards
  • ai
  • on semiconductor
ctammann
ctammann
14 Jan 2021
As a follow up to the blog I posted on building the hardware design for the out of box image for the ON Semiconductor Dual Camera Mezzanine card, here are the instructions to complete the build with the Petalinux project. The original blog can be found here -
Ultra96-V2 ON Semiconductor Dual Camera Mezzanine hardware build instructions
The process of porting the full design over to our Github repo has now been completed. Below I've pasted the instructions to build the full design including Petalinux from the repo. The final command will build the hardware design as part of the script and create the full design.
# Clone the repositories
$ cd ~
$ mkdir -p git/avnet
$ cd git/avnet/
$ git clone https://github.com/Avnet/bdf.git
$ git clone https://github.com/Avnet/hdl.git
$ git clone https://github.com/Avnet/petalinux.git
$ cd bdf
$ git checkout master
$ cd ../petalinux
$ git checkout 2020.1
$ cd ../hdl
# Run the Vivado build script for the Ultra96-V2 dualcam design
$ cd ../petalinux
$ ./scripts/make_ultra96v2_dualcam.sh
This process will take a long time and will depend on your pc hardware. When complete, you should see something similar to this:
Your design has now successfully been built (yay!). So now we need to put it on an SDcard to use on your hardware. Pulling from my colleague Tom Curran's excellent instructions, if you haven't already followed the Getting Started Guide you will need to first partition the SD card with - for example - a 1GB FAT32 boot partition and (assuming you are using the provided 16GB Delkin micro SD card) and a 15GB ext4 partition. I've also attached a handy guide on formatting a new SDcard to this blog.
If you have successfully configured your SDcard you are ready to copy over the files. Here are the commands to create the SDcard image. First you must navigate to the folder where the files were generated, then you can copy them over to the proper partitions on your SDcard.
$ cd ~/git/avnet/petalinux/projects/ultra96v2_dualcam_2020_1
$ cp ./images/linux/BOOT.BIN /media/training/<UUID of FAT32 partition>/.
$ cp ./images/linux/boot.scr /media/training/<UUID of FAT32 partition>/.
$ cp ./images/linux/image.ub /media/training/<UUID of FAT32 partition>/.
$ sudo rm -rf /media/training/<UUID of ext4 partition>/*
$ sudo tar xvf ./images/linux/rootfs.tar.gz -C /media/training/<UUID of ext4 partition>/
$ sync; sync (VERY IMPORTANT to sync the filesystem BEFORE ejecting the SD card!  If you don't the filesystem may be corrupted. This process can take minutes to complete)
You should now be able to run the out of box design from your SDcard with the command
$ run_1920_1080
The out of box image will show 2 live streams from the cameras on a 1080p monitor.
Ultra96-V2Ultra96-V2
imageSD Card Formatting an SD Card.docx
  • albertabeef
    albertabeef over 5 years ago in reply to _david_ +3
    David, We are actively working on this. My colleagues are stabilizing the hardware/software portions generated by the hdl/petalinux repositories. I am working on the Vitis-AI designs generated by the vitis…
  • zedhed
    zedhed over 5 years ago in reply to jomoenginer +1
    Hi jomoenginer , Yes, I agree that seeing the CRC mismatch is unsettling, but I asked our driver developer about this and the explanation that I got is that it is mostly innocuous. The driver will attempt…
  • narrucmot
    narrucmot over 5 years ago in reply to dje666x +1
    Hi David, This script error is a result of the BUILD_FROM_TAG script variable is set to "true" in the scripts/common.sh file: Change this to "false" and re-run the script and it should complete successfully…
  • jomoenginer
    jomoenginer over 5 years ago in reply to jomoenginer
    The VM changes, along with adding the Voucher License, seem to have eliminated the issues I was having with the build. It did take about a day and half to compile though.
    After copying the image to a SD card and then booting the Ultra96-V2 with Dual Cam Mezz, I see this in the JTAG/UART term window:
    Starting random number generator daemon
    Initializing available sources
    Failed to init entropy source hwrng
    [   20.839061] add_virtual_intf name[mon.p2p0] vnum[2], nl-type[6]
    [   20.845564] add_virtual_intf:monitor name[p2p0] vnum[2], idx[1], wilc-type[1], nl-type[3]
    [   20.907533] start_ap,dev[p2p0]
    [   23.264212] random: crng init done
    [   23.649047] ap1302 4-003c: CRC mismatch: expected 0xf80f, got 0x1cae
    [   23.671867] ap1302 4-003c: AP1302 revision 0.2.6 detected
    Initializing AES buffer
    Enabling JITTER rng support
    Initializing entropy source jitter
    The CRC mismatch for the ap1302 image sensor device concerns me.
  • jomoenginer
    I may have a partial solution:
    VirtualBox Ubuntu VM Setting:
    1. Set CPU Execution Cap to 80% to prevent from using all available CPU resources.
    2. Increase the swap space (swapfile) in the VM from 2GB to 8GB to match the memory allocated to the VM
    I still need to test this, but I was able to get further with the Hardware build with this setting which was failing for the same thing.
  • jomoenginer
    Sorry, I'm on a posting frenzy.
    I attempted to run through the steps listed here, however it appears to have stopped and then failed at the "Wait for bitstream to be written" step.
    Does this require having gone through the hardware build instructions first?
    Does this require having the Ultra96-V2 connected in JTAG mode before running through this?
    These are the steps I took to run the PetaLinux build:
    vitis20201@vitis20201-VirtualBox:~/develop$ . /tools/Xilinx/Vitis/2020.1/settings64.sh
    vitis20201@vitis20201-VirtualBox:~/develop$ . /opt/xilinx/xrt/setup.sh
    vitis20201@vitis20201-VirtualBox:~/develop$ . /tools/Xilinx/Vivado/2020.1/settings64.sh
    vitis20201@vitis20201-VirtualBox:~/develop$ rm -rf git/
    vitis20201@vitis20201-VirtualBox:~/develop$ mkdir -p git/avnet
    vitis20201@vitis20201-VirtualBox:~/develop$ cd git/avnet/
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet$ git clone https://github.com/Avnet/bdf.git
    Cloning into 'bdf'...
    remote: Enumerating objects: 123, done.
    remote: Counting objects: 100% (123/123), done.
    remote: Compressing objects: 100% (86/86), done.
    remote: Total 380 (delta 48), reused 110 (delta 37), pack-reused 257
    Receiving objects: 100% (380/380), 23.20 MiB | 4.12 MiB/s, done.
    Resolving deltas: 100% (145/145), done.
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet$ git clone https://github.com/Avnet/hdl.git
    Cloning into 'hdl'...
    remote: Enumerating objects: 669, done.
    remote: Counting objects: 100% (669/669), done.
    remote: Compressing objects: 100% (244/244), done.
    remote: Total 5006 (delta 442), reused 595 (delta 372), pack-reused 4337
    Receiving objects: 100% (5006/5006), 14.86 MiB | 2.81 MiB/s, done.
    Resolving deltas: 100% (3006/3006), done.
    Checking out files: 100% (1874/1874), done.
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet$ git clone https://github.com/Avnet/petalinux.git
    Cloning into 'petalinux'...
    remote: Enumerating objects: 209, done.
    remote: Counting objects: 100% (209/209), done.
    remote: Compressing objects: 100% (97/97), done.
    remote: Total 3039 (delta 158), reused 150 (delta 106), pack-reused 2830
    Receiving objects: 100% (3039/3039), 6.14 MiB | 2.99 MiB/s, done.
    Resolving deltas: 100% (1676/1676), done.
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet$ cd bdf/
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/bdf$ git checkout master
    Already on 'master'
    Your branch is up to date with 'origin/master'.
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/bdf$ cd ../petalinux/
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/petalinux$ git checkout 2020.1
    Branch '2020.1' set up to track remote branch '2020.1' from 'origin'.
    Switched to a new branch '2020.1'
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/petalinux$ cd ../hdl/
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/hdl$ git checkout 2020.1
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/hdl$ ls
    avnet_logo.png  Boards  IP  Projects  README.md  Scripts  Software
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/hdl$ cd ../petalinux/
    Result of the build:
    // Run Build
    vitis20201@vitis20201-VirtualBox:~/develop/git/avnet/petalinux$ ./scripts/make_ultra96v2_dualcam.sh
    Verifying repositories ...
    Checking Environment (Xilinx tools sourced) ...
    Checking 'ultra96v2_dualcam/ULTRA96V2_2020_1' Vivado Project ...
    No built Vivado HW project ultra96v2_dualcam/ULTRA96V2_2020_1 found.
    Will build the hardware platform now.
    ****** Vivado v2020.1 (64-bit)
      **** SW Build 2902540 on Wed May 27 19:54:35 MDT 2020
      **** IP Build 2902112 on Wed May 27 22:43:36 MDT 2020
        ** Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
    source make_ultra96v2_dualcam.tcl -notrace
    *-        Welcome to the Avnet Project Builder         -*
    BDF path set to /home/vitis20201/develop/git/avnet/bdf
    | Setting          |     Configuration                  |
    | Board            |     ULTRA96V2                      |
    | Project          |     ultra96v2_dualcam              |
    | SDK              |     no                             |
    | No Close Project |     no                             |
    | Version override |     yes                            |
    | Device           |     zynqmp                         |
    Overriding Version Check, Please Check the Design for Validity!
     Selected Board and Project as:
     ULTRA96V2 and ultra96v2_dualcam
    Not Requesting Tag
    Setting Up Project ultra96v2_dualcam...
    ***** Creating Vivado Project...
    create_project: Time (s): cpu = 00:00:04 ; elapsed = 00:00:10 . Memory (MB): peak = 2032.109 ; gain = 2.016 ; free physical = 4557 ; free virtual = 8669
    ***** Assigning Vivado Project board_part Property to ultra96v2...
    ***** Generating IP...
    ***** Updating Vivado to include IP Folder
    INFO: [IP_Flow 19-234] Refreshing IP repositories
    INFO: [IP_Flow 19-1700] Loaded user IP repository '/home/vitis20201/develop/git/avnet/hdl/IP'.
    INFO: [IP_Flow 19-2313] Loaded Vivado IP repository '/tools/Xilinx/Vivado/2020.1/data/ip'.
    update_ip_catalog: Time (s): cpu = 00:00:06 ; elapsed = 00:00:15 . Memory (MB): peak = 2032.109 ; gain = 0.000 ; free physical = 4506 ; free virtual = 8655
    ***** Creating Block Design...
    Wrote  : </home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ULTRA96V2.bd>
    create_bd_design: Time (s): cpu = 00:00:01 ; elapsed = 00:00:05 . Memory (MB): peak = 2096.023 ; gain = 21.051 ; free physical = 4449 ; free virtual = 8637
    ***** Add defined IP blocks to Block Design...
    INFO: [Device 21-403] Loading part xczu3eg-sbva484-1-i
    INFO: [Ipptcl 7-1463] No Compatible Board Interface found. Board Tab not created in customize GUI
    WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'RX_EQUALIZATION_S' from 'NONE' to 'EQ_NONE' has been ignored for IP 'ULTRA96V2_mipi_csi2_rx_subsyst_0_0/bd_1b41/bd_1b41_phy_0/bd_1b41_phy_0_hssio_rx'
    create_bd_cell: Time (s): cpu = 00:00:07 ; elapsed = 00:00:07 . Memory (MB): peak = 2594.449 ; gain = 0.000 ; free physical = 3195 ; free virtual = 7787
    create_bd_cell: Time (s): cpu = 00:00:38 ; elapsed = 00:01:21 . Memory (MB): peak = 2594.449 ; gain = 498.422 ; free physical = 3192 ; free virtual = 7784
    create_bd_cell: Time (s): cpu = 00:00:09 ; elapsed = 00:00:09 . Memory (MB): peak = 2594.449 ; gain = 0.000 ; free physical = 3172 ; free virtual = 7765
    WARNING: [BD 41-1731] Type mismatch between connected pins: /system_rst_out(rst) and /phy/system_rst_out(undef)
    WARNING: [BD 41-1306] The connection to interface pin /reset_sel_axi_mm/gpio_io_o is being overridden by the user. This pin will not be connected as a part of interface connection GPIO
    WARNING: [BD 41-1306] The connection to interface pin /reset_sel_axi_mm/gpio_io_i is being overridden by the user. This pin will not be connected as a part of interface connection GPIO
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /smartconnect_1/aresetn(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /vdma_trunc/aresetn(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /vdma_pad/aresetn(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /video_router/M03_AXIS_ARESETN(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /video_router/S03_AXIS_ARESETN(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /video_router/S09_AXIS_ARESETN(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /dint/ap_rst_n(rst)
    WARNING: [BD 41-1731] Type mismatch between connected pins: /reset_sel_axi_mm/gpio_io_o(undef) and /deint_cc/m_axis_aresetn(rst)
    WARNING: [BD 41-1306] The connection to interface pin /reset_sel_axis/gpio_io_o is being overridden by the user. This pin will not be connected as a part of interface connection GPIO
    WARNING: [BD 41-1306] The connection to interface pin /reset_sel_axis/gpio_io_i is being overridden by the user. This pin will not be connected as a part of interface connection GPIO
    WARNING: [BD 41-1306] The connection to interface pin /deint_ss/m_axis_tuser is being overridden by the user. This pin will not be connected as a part of interface connection M_AXIS
    WARNING: [BD 41-1306] The connection to interface pin /deint_cc/s_axis_tuser is being overridden by the user. This pin will not be connected as a part of interface connection S_AXIS
    WARNING: [BD 41-1306] The connection to interface pin /deint_cc/m_axis_tuser is being overridden by the user. This pin will not be connected as a part of interface connection M_AXIS
    WARNING: [BD 41-1306] The connection to interface pin /dint/s_axis_video_TUSER is being overridden by the user. This pin will not be connected as a part of interface connection s_axis_video
    1
    true
    true
    Slave segment '/axi_vdma/S_AXI_LITE/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0000_0000 [ 64K ]>.
    Slave segment '/csc/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0001_0000 [ 64K ]>.
    Slave segment '/dint/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0002_0000 [ 64K ]>.
    Slave segment '/hcr/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0003_0000 [ 64K ]>.
    Slave segment '/hsc/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0004_0000 [ 64K ]>.
    Slave segment '/ltr/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0005_0000 [ 64K ]>.
    Slave segment '/reset_sel_axi_mm/S_AXI/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0006_0000 [ 64K ]>.
    Slave segment '/reset_sel_axis/S_AXI/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0007_0000 [ 64K ]>.
    Slave segment '/vcr_i/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0008_0000 [ 64K ]>.
    Slave segment '/vcr_o/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0009_0000 [ 64K ]>.
    Slave segment '/video_router/xbar/S_AXI_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x000A_0000 [ 64K ]>.
    Slave segment '/vsc/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x000B_0000 [ 64K ]>.
    create_bd_cell: Time (s): cpu = 00:00:06 ; elapsed = 00:00:08 . Memory (MB): peak = 2594.449 ; gain = 0.000 ; free physical = 3097 ; free virtual = 7694
    0
    false
    false
    Slave segment '/hsc/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0000_0000 [ 64K ]>.
    Slave segment '/reset_sel_axis/S_AXI/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0001_0000 [ 64K ]>.
    Slave segment '/vsc/s_axi_CTRL/Reg' is being assigned into address space '/s_axi_ctrl' at <0x0002_0000 [ 64K ]>.
    Wrote  : </home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ui/bd_8b17350d.ui>
    WARNING: [BD 41-1306] The connection to interface pin /GPIO/axi_gpio_0/gpio_io_o is being overridden by the user. This pin will not be connected as a part of interface connection GPIO
    WARNING: [BD 41-1306] The connection to interface pin /LIVE_VIDEO_DP/alpha_control_0/video_active_out is being overridden by the user. This pin will not be connected as a part of interface connection video_out
    WARNING: [BD 41-1306] The connection to interface pin /LIVE_VIDEO_DP/alpha_control_0/video_dout is being overridden by the user. This pin will not be connected as a part of interface connection video_out
    WARNING: [BD 41-1306] The connection to interface pin /LIVE_VIDEO_DP/alpha_control_0/video_hsync_out is being overridden by the user. This pin will not be connected as a part of interface connection video_out
    WARNING: [BD 41-1306] The connection to interface pin /LIVE_VIDEO_DP/alpha_control_0/video_vsync_out is being overridden by the user. This pin will not be connected as a part of interface connection video_out
    CRITICAL WARNING: [PSU-1]  Actual device frequency is : 479.995209. Minimum actual device frequency supported for DDR for current part is 500.000000.
    create_bd_cell: Time (s): cpu = 00:00:05 ; elapsed = 00:00:07 . Memory (MB): peak = 2717.453 ; gain = 106.996 ; free physical = 2937 ; free virtual = 7568
    INFO: [PSU-0] Address Range of DDR (0x1ff00000 to 0x1fffffff) is reserved by PMU for internal purpose.
    INFO: [PSU-1]  DP_AUDIO clock source: RPLL is also being used by other peripheral clocks. Their outputs may get impacted if any driver changes DP_AUDIO PLL source to support runtime audio change
    create_bd_cell: Time (s): cpu = 00:00:47 ; elapsed = 00:01:32 . Memory (MB): peak = 3177.770 ; gain = 460.316 ; free physical = 2451 ; free virtual = 7102
    WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'MMCM_DIVCLK_DIVIDE' from '1' to '5' has been ignored for IP 'clk_wiz'
    WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'MMCM_CLKFBOUT_MULT_F' from '12.000' to '32.000' has been ignored for IP 'clk_wiz'
    WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'MMCM_CLKIN1_PERIOD' from '10.000' to '5.333' has been ignored for IP 'clk_wiz'
    WARNING: [IP_Flow 19-3374] An attempt to modify the value of disabled parameter 'MMCM_CLKIN2_PERIOD' from '10.000' to '10.0' has been ignored for IP 'clk_wiz'
    Slave segment '/ZYNQ/zynq_ultra_ps_e_0/SAXIGP2/HP0_DDR_LOW' is being assigned into address space '/CAPTURE_PIPLINE/v_frmbuf_wr_0/Data_m_axi_mm_video' at <0x0000_0000 [ 2G ]>.
    Slave segment '/ZYNQ/zynq_ultra_ps_e_0/SAXIGP2/HP0_DDR_LOW' is being assigned into address space '/LIVE_VIDEO_DP/v_frmbuf_rd_0/Data_m_axi_mm_video' at <0x0000_0000 [ 2G ]>.
    Slave segment '/LIVE_VIDEO_DP/alpha_control_0/S00_AXI/S00_AXI_reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA001_1000 [ 4K ]>.
    Slave segment '/GPIO/axi_gpio_0/S_AXI/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA004_0000 [ 4K ]>.
    Slave segment '/CAPTURE_PIPLINE/mipi_csi2_rx_subsyst_0/csirxss_s_axi/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA002_0000 [ 128K ]>.
    Slave segment '/LIVE_VIDEO_DP/v_frmbuf_rd_0/s_axi_CTRL/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA00C_0000 [ 64K ]>.
    Slave segment '/CAPTURE_PIPLINE/v_frmbuf_wr_0/s_axi_CTRL/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA000_0000 [ 64K ]>.
    Slave segment '/LIVE_VIDEO_DP/v_osd_0/ctrl/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA007_0000 [ 64K ]>.
    Slave segment '/CAPTURE_PIPLINE/v_proc_ss_0/s_axi_ctrl/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA008_0000 [ 256K ]>.
    Slave segment '/LIVE_VIDEO_DP/v_tc_0/ctrl/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA006_0000 [ 64K ]>.
    Slave segment '/LIVE_VIDEO_DP/v_tpg_0/s_axi_CTRL/Reg' is being assigned into address space '/ZYNQ/zynq_ultra_ps_e_0/Data' at <0xA005_0000 [ 64K ]>.
    ***** General Configuration for Design...
    ***** Adding Source Files to Block Design...
    WARNING: [BD 41-721] Attempt to set value '0' on disabled parameter 'HAS_LOCK' of cell '/m00_exit_pipeline/m00_exit' is ignored
    WARNING: [BD 41-721] Attempt to set value '0' on disabled parameter 'HAS_LOCK' of cell '/m01_exit_pipeline/m01_exit' is ignored
    WARNING: [BD 41-721] Attempt to set value '0' on disabled parameter 'HAS_LOCK' of cell '/m02_exit_pipeline/m02_exit' is ignored
    INFO: [xilinx.com:ip:v_axi4s_vid_out:4.0-913] /LIVE_VIDEO_DP/v_axi4s_vid_out_0 C_S_AXIS_VIDEO_FORMAT has been set to manual on the GUI. It will not be updated during validation with a propagated value.
    INFO: [xilinx.com:ip:clk_wiz:6.0-1] /clk_wiz clk_wiz propagate
    WARNING: [BD 41-237] Bus Interface property AWUSER_WIDTH does not match between /ZYNQ/zynq_ultra_ps_e_0/S_AXI_HP0_FPD(1) and /ZYNQ/axi_mem_intercon/xbar/M00_AXI(0)
    WARNING: [BD 41-237] Bus Interface property ARUSER_WIDTH does not match between /ZYNQ/zynq_ultra_ps_e_0/S_AXI_HP0_FPD(1) and /ZYNQ/axi_mem_intercon/xbar/M00_AXI(0)
    WARNING: [BD 41-237] Bus Interface property AWUSER_WIDTH does not match between /ZYNQ/ps8_0_axi_periph/s00_couplers/auto_ds/S_AXI(0) and /ZYNQ/ps8_0_axi_periph/s00_couplers/auto_cc/M_AXI(16)
    WARNING: [BD 41-237] Bus Interface property ARUSER_WIDTH does not match between /ZYNQ/ps8_0_axi_periph/s00_couplers/auto_ds/S_AXI(0) and /ZYNQ/ps8_0_axi_periph/s00_couplers/auto_cc/M_AXI(16)
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/xbar/m_axi_rid'(2) to pin: '/ZYNQ/axi_mem_intercon/m00_couplers/S_AXI_rid'(6) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/xbar/m_axi_bid'(2) to pin: '/ZYNQ/axi_mem_intercon/m00_couplers/S_AXI_bid'(6) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/s00_mmu/s_axi_arlock'(1) to pin: '/ZYNQ/axi_mem_intercon/S00_AXI_arlock'(2) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/s00_mmu/s_axi_awlock'(1) to pin: '/ZYNQ/axi_mem_intercon/S00_AXI_awlock'(2) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/s03_mmu/s_axi_arlock'(1) to pin: '/ZYNQ/axi_mem_intercon/S03_AXI_arlock'(2) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/axi_mem_intercon/s03_mmu/s_axi_awlock'(1) to pin: '/ZYNQ/axi_mem_intercon/S03_AXI_awlock'(2) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/zynq_ultra_ps_e_0/saxigp2_awid'(6) to pin: '/ZYNQ/axi_mem_intercon/M00_AXI_awid'(2) - Only lower order bits will be connected.
    WARNING: [BD 41-2384] Width mismatch when connecting pin: '/ZYNQ/zynq_ultra_ps_e_0/saxigp2_arid'(6) to pin: '/ZYNQ/axi_mem_intercon/M00_AXI_arid'(2) - Only lower order bits will be connected.
    VHDL Output written to : /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/synth/ULTRA96V2.v
    VHDL Output written to : /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/sim/ULTRA96V2.v
    VHDL Output written to : /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/hdl/ULTRA96V2_wrapper.v
    make_wrapper: Time (s): cpu = 00:00:26 ; elapsed = 00:00:28 . Memory (MB): peak = 3261.922 ; gain = 84.152 ; free physical = 2343 ; free virtual = 7008
    ***** Adding Vitis Directves to Design...
    update_compile_order: Time (s): cpu = 00:00:04 ; elapsed = 00:00:05 . Memory (MB): peak = 3269.949 ; gain = 8.027 ; free physical = 2335 ; free virtual = 7009
    INFO: [filemgmt 20-334] All file(s) are already imported in fileset: 'constrs_1'
    INFO: [filemgmt 20-348] Importing the appropriate files for fileset: 'constrs_1'
    INFO: [filemgmt 20-334] All file(s) are already imported in fileset: 'sources_1'
    INFO: [filemgmt 20-348] Importing the appropriate files for fileset: 'sources_1'
    ***** Building Binary...
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/axis_subset_converter_1 .
    Exporting to file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_mipi_csi2_rx_subsyst_0_0/bd_0/hw_handoff/ULTRA96V2_mipi_csi2_rx_subsyst_0_0.hwh
    Generated Block Design Tcl file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_mipi_csi2_rx_subsyst_0_0/bd_0/hw_handoff/ULTRA96V2_mipi_csi2_rx_subsyst_0_0_bd.tcl
    Generated Hardware Definition File /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_mipi_csi2_rx_subsyst_0_0/bd_0/synth/ULTRA96V2_mipi_csi2_rx_subsyst_0_0.hwdef
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/mipi_csi2_rx_subsyst_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/proc_sys_reset_1 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/proc_sys_reset_2 .
    WARNING: [IP_Flow 19-1971] File named "sim/ULTRA96V2_v_frmbuf_wr_0_0.v" already exists in file group "xilinx_verilogsimulationwrapper", cannot add it again.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/v_frmbuf_wr_0 .
    Exporting to file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_1/hw_handoff/bd_793d_smartconnect_0_0.hwh
    Generated Block Design Tcl file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_1/hw_handoff/bd_793d_smartconnect_0_0_bd.tcl
    Generated Hardware Definition File /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_1/synth/bd_793d_smartconnect_0_0.hwdef
    WARNING: [IP_Flow 19-1971] File named "sim/bd_793d_vsc_0.v" already exists in file group "xilinx_verilogsimulationwrapper", cannot add it again.
    WARNING: [IP_Flow 19-1971] File named "sim/bd_793d_hsc_0.v" already exists in file group "xilinx_verilogsimulationwrapper", cannot add it again.
    Exporting to file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_0/hw_handoff/ULTRA96V2_v_proc_ss_0_0.hwh
    Generated Block Design Tcl file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_0/hw_handoff/ULTRA96V2_v_proc_ss_0_0_bd.tcl
    Generated Hardware Definition File /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_v_proc_ss_0_0/bd_0/synth/ULTRA96V2_v_proc_ss_0_0.hwdef
    INFO: [BD 41-1029] Generation completed for the IP Integrator block CAPTURE_PIPLINE/v_proc_ss_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/axi_gpio_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_1 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_2 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_3 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_4 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block GPIO/xlslice_5 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/Subset_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/alpha_control_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/axis_subset_converter_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/axis_subset_converter_2 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/proc_sys_reset_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/proc_sys_reset_2 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/v_axi4s_vid_out_0 .
    WARNING: [IP_Flow 19-1971] File named "sim/ULTRA96V2_v_frmbuf_rd_0_0.v" already exists in file group "xilinx_verilogsimulationwrapper", cannot add it again.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/v_frmbuf_rd_0 .
    WARNING: [IP_Flow 19-650] IP license key 'v_osd@2013.03' is enabled with a Design_Linking license.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/v_osd_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/v_tc_0 .
    WARNING: [IP_Flow 19-1971] File named "sim/ULTRA96V2_v_tpg_0_0.v" already exists in file group "xilinx_verilogsimulationwrapper", cannot add it again.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/v_tpg_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/xlconstant_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block LIVE_VIDEO_DP/xlconstant_1 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/axi_mem_intercon/xbar .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/ps8_0_axi_periph/xbar .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/rst_clk_wiz_100M .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/rst_ps8_0_100M .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/xlconcat_0 .
    INFO: [xilinx.com:ip:zynq_ultra_ps_e:3.3-0] ULTRA96V2_zynq_ultra_ps_e_0_0:
    Changes in your design (including the PCW configuration settings) are not automatically exported from Vivado to Xilinx's SDK, Petalinux or Yocto.
    This is by design to avoid disrupting existing embedded development efforts. To have any changes of your design taking effect in the embedded software flow please export your
    design by going through Vivado's main menu, click on File, then Export finally select Export Hardware, please ensure you click on the Include BitStream option.
    The auto-generated HDF file is all you need to import in Xilinx's SDK, Petalinux or Yocto for your changes to be reflected in the Embedded Software Flow.
    For more information, please consult PG201, section: Exporting PCW Settings to Embedded Software Flows
    INFO: [PSU-0] Address Range of DDR (0x7ff00000 to 0x7fffffff) is reserved by PMU for internal purpose.
    WARNING: [IP_Flow 19-5611] Unable to find an associated reset port for the interface 'M_AXI_HPM0_FPD'. A default connection has been created.
    WARNING: [IP_Flow 19-5611] Unable to find an associated reset port for the interface 'S_AXI_HP0_FPD'. A default connection has been created.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/zynq_ultra_ps_e_0 .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block clk_wiz .
    WARNING: [IP_Flow 19-4994] Overwriting existing constraint file '/home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_auto_us_0/ULTRA96V2_auto_us_0_ooc.xdc'
    WARNING: [IP_Flow 19-5611] Unable to find an associated reset port for the interface 'S_AXI'. A default connection has been created.
    WARNING: [IP_Flow 19-5611] Unable to find an associated reset port for the interface 'M_AXI'. A default connection has been created.
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/axi_mem_intercon/s03_couplers/auto_us .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/axi_mem_intercon/s00_mmu .
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/axi_mem_intercon/s03_mmu .
    WARNING: [IP_Flow 19-4994] Overwriting existing constraint file '/home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_auto_cc_0/ULTRA96V2_auto_cc_0_ooc.xdc'
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/ps8_0_axi_periph/s00_couplers/auto_cc .
    WARNING: [IP_Flow 19-4994] Overwriting existing constraint file '/home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_auto_ds_0/ULTRA96V2_auto_ds_0_ooc.xdc'
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/ps8_0_axi_periph/s00_couplers/auto_ds .
    WARNING: [IP_Flow 19-4994] Overwriting existing constraint file '/home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/ip/ULTRA96V2_auto_pc_0/ULTRA96V2_auto_pc_0_ooc.xdc'
    INFO: [BD 41-1029] Generation completed for the IP Integrator block ZYNQ/ps8_0_axi_periph/s00_couplers/auto_pc .
    Exporting to file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/hw_handoff/ULTRA96V2.hwh
    Generated Block Design Tcl file /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/hw_handoff/ULTRA96V2_bd.tcl
    Generated Hardware Definition File /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.srcs/sources_1/bd/ULTRA96V2/synth/ULTRA96V2.hwdef
    [Wed Mar 17 00:12:00 2021] Launched bd_793d_hsc_0_synth_1, ULTRA96V2_mipi_csi2_rx_subsyst_0_0_synth_1, bd_793d_rst_axis_0_synth_1, ULTRA96V2_axis_subset_converter_1_0_synth_1, bd_793d_input_size_set_0_synth_1, bd_793d_reset_sel_axis_0_synth_1, ULTRA96V2_proc_sys_reset_2_0_synth_1, ULTRA96V2_v_proc_ss_0_0_synth_1, ULTRA96V2_v_frmbuf_wr_0_0_synth_1, bd_793d_smartconnect_0_0_synth_1, bd_1b41_rx_0_synth_1, bd_1b41_r_sync_0_synth_1, bd_793d_axis_register_slice_0_0_synth_1, bd_793d_vsc_0_synth_1, bd_1b41_xbar_0_synth_1, bd_1b41_phy_0_synth_1, bd_793d_axis_fifo_0_synth_1, ULTRA96V2_proc_sys_reset_1_0_synth_1, bd_1b41_vfb_0_0_synth_1, ULTRA96V2_axi_gpio_0_0_synth_1, ULTRA96V2_Subset_0_0_synth_1, ULTRA96V2_alpha_control_0_0_synth_1, ULTRA96V2_axis_subset_converter_0_0_synth_1, ULTRA96V2_axis_subset_converter_2_0_synth_1, ULTRA96V2_proc_sys_reset_0_0_synth_1, ULTRA96V2_proc_sys_reset_2_1_synth_1, ULTRA96V2_v_axi4s_vid_out_0_0_synth_1, ULTRA96V2_v_frmbuf_rd_0_0_synth_1, ULTRA96V2_v_osd_0_0_synth_1, ULTRA96V2_v_tc_0_0_synth_1, ULTRA96V2_v_tpg_0_0_synth_1, ULTRA96V2_clk_wiz_0_synth_1, ULTRA96V2_auto_us_0_synth_1, ULTRA96V2_s00_mmu_0_synth_1, ULTRA96V2_s03_mmu_0_synth_1, ULTRA96V2_auto_cc_0_synth_1, ULTRA96V2_auto_ds_0_synth_1, ULTRA96V2_auto_pc_0_synth_1, ULTRA96V2_xbar_0_synth_1, ULTRA96V2_xbar_1_synth_1, ULTRA96V2_rst_clk_wiz_100M_0_synth_1, ULTRA96V2_rst_ps8_0_100M_0_synth_1, ULTRA96V2_zynq_ultra_ps_e_0_0_synth_1, synth_1...
    Run output will be captured here:
    bd_793d_hsc_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_hsc_0_synth_1/runme.log
    ULTRA96V2_mipi_csi2_rx_subsyst_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_mipi_csi2_rx_subsyst_0_0_synth_1/runme.log
    bd_793d_rst_axis_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_rst_axis_0_synth_1/runme.log
    ULTRA96V2_axis_subset_converter_1_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_axis_subset_converter_1_0_synth_1/runme.log
    bd_793d_input_size_set_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_input_size_set_0_synth_1/runme.log
    bd_793d_reset_sel_axis_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_reset_sel_axis_0_synth_1/runme.log
    ULTRA96V2_proc_sys_reset_2_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_proc_sys_reset_2_0_synth_1/runme.log
    ULTRA96V2_v_proc_ss_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_proc_ss_0_0_synth_1/runme.log
    ULTRA96V2_v_frmbuf_wr_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_frmbuf_wr_0_0_synth_1/runme.log
    bd_793d_smartconnect_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_smartconnect_0_0_synth_1/runme.log
    bd_1b41_rx_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_1b41_rx_0_synth_1/runme.log
    bd_1b41_r_sync_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_1b41_r_sync_0_synth_1/runme.log
    bd_793d_axis_register_slice_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_axis_register_slice_0_0_synth_1/runme.log
    bd_793d_vsc_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_vsc_0_synth_1/runme.log
    bd_1b41_xbar_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_1b41_xbar_0_synth_1/runme.log
    bd_1b41_phy_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_1b41_phy_0_synth_1/runme.log
    bd_793d_axis_fifo_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_793d_axis_fifo_0_synth_1/runme.log
    ULTRA96V2_proc_sys_reset_1_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_proc_sys_reset_1_0_synth_1/runme.log
    bd_1b41_vfb_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/bd_1b41_vfb_0_0_synth_1/runme.log
    ULTRA96V2_axi_gpio_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_axi_gpio_0_0_synth_1/runme.log
    ULTRA96V2_Subset_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_Subset_0_0_synth_1/runme.log
    ULTRA96V2_alpha_control_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_alpha_control_0_0_synth_1/runme.log
    ULTRA96V2_axis_subset_converter_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_axis_subset_converter_0_0_synth_1/runme.log
    ULTRA96V2_axis_subset_converter_2_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_axis_subset_converter_2_0_synth_1/runme.log
    ULTRA96V2_proc_sys_reset_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_proc_sys_reset_0_0_synth_1/runme.log
    ULTRA96V2_proc_sys_reset_2_1_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_proc_sys_reset_2_1_synth_1/runme.log
    ULTRA96V2_v_axi4s_vid_out_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_axi4s_vid_out_0_0_synth_1/runme.log
    ULTRA96V2_v_frmbuf_rd_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_frmbuf_rd_0_0_synth_1/runme.log
    ULTRA96V2_v_osd_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_osd_0_0_synth_1/runme.log
    ULTRA96V2_v_tc_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_tc_0_0_synth_1/runme.log
    ULTRA96V2_v_tpg_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_v_tpg_0_0_synth_1/runme.log
    ULTRA96V2_clk_wiz_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_clk_wiz_0_synth_1/runme.log
    ULTRA96V2_auto_us_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_auto_us_0_synth_1/runme.log
    ULTRA96V2_s00_mmu_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_s00_mmu_0_synth_1/runme.log
    ULTRA96V2_s03_mmu_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_s03_mmu_0_synth_1/runme.log
    ULTRA96V2_auto_cc_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_auto_cc_0_synth_1/runme.log
    ULTRA96V2_auto_ds_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_auto_ds_0_synth_1/runme.log
    ULTRA96V2_auto_pc_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_auto_pc_0_synth_1/runme.log
    ULTRA96V2_xbar_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_xbar_0_synth_1/runme.log
    ULTRA96V2_xbar_1_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_xbar_1_synth_1/runme.log
    ULTRA96V2_rst_clk_wiz_100M_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_rst_clk_wiz_100M_0_synth_1/runme.log
    ULTRA96V2_rst_ps8_0_100M_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_rst_ps8_0_100M_0_synth_1/runme.log
    ULTRA96V2_zynq_ultra_ps_e_0_0_synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/ULTRA96V2_zynq_ultra_ps_e_0_0_synth_1/runme.log
    synth_1: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/synth_1/runme.log
    [Wed Mar 17 00:12:01 2021] Launched impl_1...
    Run output will be captured here: /home/vitis20201/develop/git/avnet/hdl/Projects/ultra96v2_dualcam/ULTRA96V2_2020_1/ULTRA96V2.runs/impl_1/runme.log
    launch_runs: Time (s): cpu = 00:01:41 ; elapsed = 00:01:55 . Memory (MB): peak = 3842.887 ; gain = 572.938 ; free physical = 2188 ; free virtual = 6962
    [Wed Mar 17 00:12:01 2021] Waiting for impl_1 to finish...
    /tools/Xilinx/Vivado/2020.1/bin/loader: line 286:  2934 Killed                  "$RDI_PROG" "$@"
  • ctammann
    ctammann over 5 years ago in reply to jomoenginer
    I fixed the GSG link too, it should now take you to the pdf. Thanks for the feedback!
    Chris
  • ctammann
    corrected
