FPGA
FPGA
Forum Pedestrian detection using image processing
  • Subscribers 582 subscribers
  • Views 1266 views
  • processing
  • image
Hi, I am doing a project on pedestrian detection using imageimage processing from a liive video feed.
I would really like to know what the best product for this will be? Will it be a DSP development board or FPGA? And also if it is possible what part number.
The costs will not matter that much, but it should not be way to expensive.
Any advise is helpful, thank you in advanced.
  • clem57
    0 clem57 over 11 years ago
    FPGA because of so much pixel analysis is the best.
    element14jamie please move to FPGA group. TY
    Clem
    0 e14 Contributor over 11 years ago in reply to clem57
    It seems that I have to use a DSP board, specifications changed.
    I was looking at the tms320DMxx processors and evm. They all looked like they supported it, but I'm not sure which one will be the best for my project?
    0 autodeskguest over 11 years ago in reply to e14 Contributor
    project?
    How exactly is this related to EAGLE CAD?
    Tilmann
  • element14jamie
    0 element14jamie over 11 years ago
    Hello savvas1
    Welcome to the element14 Community, I will move this over to the FPGA area as it is a better fit, thank you clem57
    Thank you again,
    Jamie
    Hi Savva,
    It really depends on your final application requirments, ie power requirements, time requirements, amount of effort wanted to develop the product.
    It would be best to start using openCV on a full PC to figure out which algorithms work best for your applcation.  You can quickly tune your algorithm to fit your needs without all of the development overhead of creating custom hardware in an FPGA.
    Once you have figured out your required algorithm, processing intensity of application you can decide which platform you would like to use for the end applcation.  If not very processing intensive you may be able to get away with a Rpi or BBB running openCV.  But, you may need to port some of the heavy lifting to custom hardware on an FPGA.  You can see Jonathan Piat's blog posts on running machine vision on an FPGA to get feel for what it might take to use an FPGA for your application.
    Gradient Filter implementation on an FPGA - Part 1 Interfacing an FPGA with a camera
    Gradient Filter implementation on FPGA : Part 2 Implementing gradient Filter
    Anyhow good luck and keep us posted on your progress and design decision making!
