FPGA
FPGA
Forum ICE40UP5k in stock
  • Replies 21 replies
  • Subscribers 583 subscribers
  • Views 5100 views
ICE40UP5k in stock
michaelkellett
michaelkellett over 8 years ago
For anyone interested in a cheap DIY pcb assembly kind of FPGA:
Mouser have the Lattice ICE40UP5K-SG48ITR in stock at £4.98 each (25 off).
These are in a 48 pad QFP package with 0.5mm pitch but readily hand solderable (to a suitable pcb of course).
This part has 128k of RAM on chip as well as some other fun stuff.
iCE40 Ultra / UltraLite / UltraPlus - Lattice Semiconductor
  • rachaelp
    rachaelp over 8 years ago in reply to johnbeetem +7
    I just looked at the other thread you linked to and then saw the schematic linked by shabaz for the board. OMG... I'd have not bothered even looking at the PCB based on the schematic design alone. It looks…
    shabaz over 8 years ago in reply to rachaelp +7
    I think it is a bit mean he is blaming a 'high school kid from Sri Lanka'. The product is from his firm with his name on his website, he should take responsibility. The buck stops with him. He should have…
    shabaz over 8 years ago in reply to johnbeetem +5
    Hi John! I think it is possible the price-point is low because it could be reusing old components, maybe.. There was some comment on the other thread that the serial flash had strings in it from some other…
  • rachaelp
    rachaelp over 8 years ago in reply to michaelkellett
    Thanks Michael, that's a good point about the cost of the programmer adding a lot to the board cost. Maybe there could be a couple of versions, a really stripped back to the bare minimum version and one with the integrated programmer. I guess my goal is to have something that is fairly self contained to make it as easily accessible as possible. Like with the Arduino, if you want to put a quick MCU board into a project and easily program it you just need a USB cable to plug it into your PC to program it. I think that would be fairly useful to help people be able to use FPGA's in their projects more easily.
    Regarding the clocks, I wasn't thinking of anything so involved as that Cirrus clock synthesizer. One or two simple oscillators feeding into global clock inputs. I was thinking maybe 50MHz for one of them and 24.576MHz for the other as that's a common frequency for audio applications. The second one could be a VCXO which combined with the FPGA logic would allow you to build functionality similar to that synthesizer for much lower cost.
    You are right I should get some on order before they all get snapped up. This is the sort of thing a company might easily buy in volume if they see they are available so I don't want to miss out!
    Many thanks,
    Rachael
    michaelkellett over 8 years ago in reply to rachaelp
    Bearing in mind the slowness of the ICE40s and the on chip PLL I think I'd go with a slower basic clock (I usually go for 10 or 12MHz.)
    If you use a standard oscillator footprint it doesn't really matter until you solder it on.
    For designs with a STM32xxx processor I often use a processor pin for the FPGA clock. The processor runs from its internal RC clock (good enough for asynchronous serial but not much more) and the FPGA is clocked synchronously with the processor (often useful).
    The Cirrus chip is very nice (and hard to duplicate in just logic) but way too expensive unless you really need it.
  • rachaelp
    I think I have been using Altera for too long! Yeah that's a good point, looking at the datasheet I see Fmax for a lot of it is only 50MHz.
    Yes that's a good point. My plan was that all the IO's would be available externally anyway so there would be nothing stopping you doing this I don't think.
    Yeah I've used that Cirrus chip before, and you are right it's way too expensive for a lot of applications hence I have usually ended up implementing various schemes within the FPGA itself. You are right, to completely replicate the Cirrus chip wouldn't be trivial but there is plenty you can do without too much difficulty.
    Best Regards,
    Rachael
  • rachaelp
    In the hope that it might be useful here are some design notes I did for a customer who did their own pcb design (lots of other audio stuff on it that we won't talk about).
    I'm glad you shared that schematic as no matter how hard I search I can't find the full pinout on the Lattice website! They refer to a pinout file in the datasheet but give no link to it and it's nowhere to be seen!
    Best Regards,
    Rachael
    You need to know the secrets of Lattice's web site and organisation image
    Near the bottom of the page, download the ICE40UP5k pinout - it's a .xlsx file.
    http://www.latticesemi.com/view_document?document_id=50697
    BTW - my schematic is the iCE5LP4k which may be slightly different.
  • rachaelp
    Oh so it is.... I didn't scroll down far enough.... But I searched for pinout previously and it didn't show, this time I type it and it finds it.... I guess I had a typo when I searched before.... image
    Ah ok, maybe not best to copy the pinout from there then!
    I think I am having an off weekend.... I've been doing dumb things too much the last couple of days image
    Best Regards,
    Rachael
    michaelkellett over 8 years ago in reply to michaelkellett
    There is one difference in pins between the Lattice speadsheet for the up5k and my schematic and Lattice's spreadsheet for the LP4k
    It won't break any thing much but RGB0 and RGB2 are swapped on my schematic re the up5k.
  • rachaelp
    There is a note at the top about fixing a pin swap with the RGB pins. So either they based it on the 4k and that is different for the 5k, or it was wrong on the 4k too when you created that part and now they've updated it. Either way, it's not actually a problem that would cause any serious issues as you say.
    Best Regards,
    Rachael
  • johnbeetem
    johnbeetem over 8 years ago in reply to rachaelp
    rachaelp  wrote:
    Is there anything else which could be added to give value which would make people more likely to want to pay a little more?
    From a software perspective, I guess the open source IceStorm tools would be the ideal base for such a platform but it looks like this part isn't supported yet so the only option is to use Lattice's own toolset.
    I like your feature set.  As a general rule, you have to be very careful with "creeping featurism" where you add features to try to get more users, but then you add cost for everybody which means fewer users.  A good example of this is the Nandland GoBoard which includes 7-segment LEDs, VGA output, buttons, and LEDs.  Nice board, but it's over US$50 for a board with only an iCE40 HX1K part.  Or you can make it modular, but then the cost of the connectors becomes a killer.  A good example of this are the Gadget Factory Papilio boards: they have wonderful connectors, but they add to the cost and you need "wings" to do anything useful.
    I like Michael's suggestion of not having a programmer on the board, since that almost doubles the cost.  One approach would be to have a break-away programmer like the Cypress PSoC4 prototyping kit.  I think that's a very clever design.  You could have an FT2232H on the break-away section to get both SPI and UART.  Then you could sell both the fully-populated version and a cheap version for those who have an alternate way to program it.
    For programming, I recommend the scheme used by Lattice's iCE40HX-8K Breakout Board.  It has 0.1" jumpers to select programming the serial flash or the FPGA config RAM directly.  However, don't populate those jumpers: just leave holes for them on the PC board and hard-wire the serial flash option with traces that are easily cut with an X-acto knife.  That way there's no cost other than drilling a few extra holes, and someone who wants the board to be configurable can easily add jumper options.
    IceStorm does now support the UP5K.  I think the software is "beta test" at this point.  I haven't tried it yet myself, but when I downloaded IceStorm and arachne-pnr a couple weeks ago it did build the files for the 5K.
  • johnbeetem
    Here's another iCE40 board in DIP form factor that's useful for price/capability comparison.  The US$38 TinyFPGA B2 has an iCE40 LP8K which is only available in micro BGA packages as far as I know.  The B2 has a USB port for programming, but from a quick scan it looks like they do something clever that required a lot of design work.  The serial flash is 4 times larger than it needs to be, so 1/4 of it is a bootloader that makes the LP8K a USB device (most likely low- or full-speed) that can program other sections of the serial flash.  That's clever, and a fun project (depending on your definition of "fun").
    The TinyFPGA B2's small number of I/O pins is a bummer given the capabilities of the LP8K.
