Test & Tools
Test & Tools
Blog PST.. Program the Pico SCPI labTool?
  • Date Created: 6 Aug 2023 9:31 AM Date Created
  • Views 8341 views
  • Likes 15 likes
  • Comments 55 comments
  • pico_usbtmc_scpi
  • pico
  • USBTMC
  • Pico SCPI labTool
  • labview
  • scpi
  • PST
  • pyvisa
6 Aug 2023
The Pico SCPI labTool (PST) allows you to connect your PC to equipment to control and monitor all sorts of things. It runs on a Raspberry Pico.
In this post: functionality, and how to use SCPI or LabVIEW to program the device.
Capabilities
Functions
control output pins Set gpio outputs high or low (can drive a LED, relays, actuator, buzzer, ...)
get output pin status query the current state of an output pin
get input pin status query the state of an input pin (can be a digital signal, switch status, ...) added in release 3
get analogue input query the Pico ADC inputs, or the measurements from an attached ADS1115 added in release 2
set analogue output Control a Pico pin's output value with variable duty cycle added in release 3
get analogue output value query the current set duty cycle of a Pico pin added in release 3
digital input in: registers instrument specific registers for digital input pins added in release 4
service request IEEE488.2 compliant service requests (e.g.: react on digital input status change) added in  release 5
Programming interface
control language SCPI
connectivity Universal Serial Bus Test and Measurement Class (USBTMC), VISA compatible
client software
LabVIEW Virtual Instrument driver (VI)
direct SCPI control with pyVisa, MathLab, LabVIEW
VISA compatible clients
Command reference
This section describes the supported (and not yet supported) commands. It lists
  • the SCPI syntax,
  • LabVIEW Virtual Instrument driver block
  • the pins that are used,
  • parameters, return values.
set digital output
drive digital output pin of PICO high or low
pins:
0: GP22
1: GP14
2: GP15
SCPI DIGItal:OUTPut# <0|1>
example: DIGI:OUTP0 1
#: pin
parameter 1: boolean (0|1 or OFF|ON )
return: na
VI
Public/Action-Status/Digital Out Control
inputs:
pin (int)
state (bool)
outputs:
na
get digital output query the state of a digital output
pins:
0: GP22
1: GP14
2: GP15
SCPI DIGItal:OUTPut#?
example: DIGI:OUTP0?
#: pin
return: state (bool 0|1)
VI
Public/Data/Read Digital Out
inputs:
pin (int)
outputs:
state (bool 0|1)
get digital input
query the state of a digital input
pins:
0: GP20
1: GP21
2: GP27
SCPI DIGItal:INPut#?
example: DIGI:INP0?
#: pin
VI
Public/Data/Read Digital In
inputs:
pin (int)
outputs:
state (bool 0|1)
get analogue input (standard) query an ADC input of the Pico
pins:
0: GP26 (ADC0)
1: GP28 (ADC2)
SCPI ANAlog:INPut#:RAW?
example: ANA:INP0:RAW?
#: pin
return: ADC value(integer 0-4095)
VI
Public/Data/Read Analog
inputs:
pin (int)
outputs:
ADC value (integer 0-4095)
get analog input (high resolution) query an input of attached ADS1115 ADC
pins:
ADS1115 pin 0 - 3
developed by shabaz !
See the Extensions section below for hardware requirements.
SCPI ANAlog:HIRES:INPut#:RAW? #: pin
return: ADC value(integer 0-32766)
VI
Public/Data/Read Analog HiRes
inputs:
pin (int)
outputs:
ADC value (integer 0-32766)
set analog output control pin of Pico with variable duty cicle
pins:
0: GP16
1: GP17
2: GP18
developed by shabaz
SCPI ANAlog:OUTPut#:RAW <0-4095> inputs:
pin (int)
Duty cycle value (integer 0-4095)
outputs:
na
VI
Public/Action-Status/Analog Out Control
inputs:
pin (int)
duty cycle (integer 0-4095)
outputs:
na
get analog output query the set duty cycle set on a pin of Pico
pins:
0: GP16
1: GP17
2: GP18
developed by shabaz
SCPI ANAlog:OUTPut#:RAW? inputs:
pin (int)
outputs:
VI
Public/Data/Read Analog Out
inputs:
pin (int)
outputs:
init resource initiate connection VISA url: USB0::0xCAFE::0x4000::123456::INSTR
SCPI na, connect via VISA API client dependent
VI
Public/Initialize
inputs:
VISA url
outputs:
na
close resource release connection
SCPI na, disconnect via VISA API client dependent
VI
Public/Close
inputs:
na
outputs:
na
Command reference: instrument specific registers
  • the SCPI syntax,
  • registers and bits that are used,
digital input registers query the registers of a digital input, set filter and fan-out to IEEE488.2 Operation Status register
bits:
0: GP20
1: GP21
2: GP27
registers:
CONDition
PTRansition
NTRansition
EVENt
ENABle
fan-out to IEEE488.2:
Operation Status[0]
SCPI STATus:OPERation:DIGItal:INPut:CONDition?
STATus:OPERation:DIGItal:INPut:PTRansition
STATus:OPERation:DIGItal:INPut:PTRansition?
STATus:OPERation:DIGItal:INPut:NTRansition
STATus:OPERation:DIGItal:INPut:NTRansition?
STATus:OPERation:DIGItal:INPut:EVENt?
STATus:OPERation:DIGItal:INPut:ENABle
STATus:OPERation:DIGItal:INPut:ENABle?
Example
To run your first LabVIEW flow on the instrument, go to the Downloads section below, and get the latest firmware and LabVIEW VI driver with examples.
VI read analogue pin
image image This is one of the examples that's included in the LabVIEW VI Driver download
PyVISA control and query digital output pins
ANA:OUT test at 100, 75, 50, 25 and 0%
Extensions
Connect an ADS1115 ADC to Pico I2C0 (GP4[SDA], GP5[SCL]) to enable the get analog input (high resolution) function.
Contributors
 shabaz  analogue output, high resolution analogue support,
code reviews
 ggabe  IEEE488.2 service request support
If you want to contribute to this project, check PST.. Have you worked with the Pico SCPI labTool? and github instructions.
If you want to use this project start your own SCPI instrument, check these 2 posts:
  •  Do you want to create your own Pico SCPI device, based on PST.. Pico SCPI USBTMC labLib (and labTool)?
  •  PSA.. SCPI firmware for Pico Data Acquisition Board as a plug-in module
Downloads
The release has all you need to get started. The firmware contains the binary .uf2 that you can copy on your Pico. The LabVIEW VI Driver contains examples that you can run right away.
software latest release (source and bin) development branch (source)
Pico Firmware github release github branch
LabVIEW Virtual Instrument driver with examples github release github branch
link to all posts
  • scottiebabe
    scottiebabe over 3 years ago in reply to Jan Cumps +2
    Your Widget has made a new friend...
    Jan Cumps over 3 years ago in reply to scottiebabe +1
    untested 21.0 version community.element14.com/.../usbtmc_5F00_scpi_5F00_labtool-Folder.zip
    scottiebabe , the binary that supports the same functions of the LabVIEW driver isn't released yet (source is available, under branch "development-set-3"). Here's a binary: community.element14.com…
  • scottiebabe
    Your sample VI appears to only work with the latest labview version?
    usbtmc_scpi_labtool Folder.zip
  • scottiebabe
    Yay! Thank you so much, will try later today and report back.
  • scottiebabe
    Okay, Okay, JC this is pretty neat.
    Pico shows up as a TinyUSB device, yay!
    But I don't know how to use it yet...
    You're the best!
    This example sets a pin on or off if you press apply.
    0: GP22
    1: GP14
    2: GP15
  • scottiebabe
    scottiebabe over 3 years ago in reply to scottiebabe
    NVM, I didn't realize your pin mapping,
    100% works on this side of the world!
    Here's a binary:
    pico_scpi_usbtmc_labtool.zip
    Here's a binary:
  • scottiebabe
    This is wonderful, I will try it out later today, thanks JC.
    Have you thought about how to id more than one pico tool?
    Not saying this is appropriate but its one avenue
    https://www.raspberrypi.com/documentation/pico-sdk/hardware.html#ga5c6452005ad28f1e444698b0b97194d2
    Yes. Thought about it, and would use that Pico ID.
    The one we're using now (1..6) is from TinyUSB's example.
    It would require to replace the default implementation of the SCPI lib (that uses 4 constants to create that string) with a call to a custom function.
        { .pattern = "*IDN?", .callback = SCPI_CoreIdnQ,},
    That function could first call the default function, then overwrite the id with the Pico ID. Or copy the default function and change the ID logic.
    edit:
    also needs to adapt the TinyUSB - may require to step from using TinyUSB Pico port, to using an own source base:
    In the examples of TinyUSB, this is usually set inusb_descriptors.c
      "123456",                      // 3: Serials, should use chip ID
    If you're up to it: https://github.com/jancumps/pico_scpi_usbtmc_labtool/issues/29
    contribution instructions: https://github.com/jancumps/pico_scpi_usbtmc_labtool/wiki
    start from branch develop-set-3
     shabaz and I would support the first pull request.
    Jan Cumps over 3 years ago in reply to Jan Cumps
    here is the source that needs to be amended:
    https://github.com/jancumps/pico_scpi_usbtmc_labtool/blob/c49cbc1549dc5886d0bd99bac16f8286b4b39de9/source/usb/usb_descriptors.c#L192
    see also function tud_descriptor_string_cb
  • scottiebabe
    Manufacturer: "JC Corporate Towers" Slight smile
