Test & Tools
Test & Tools
Forum New Rigol dho804 oscillocope
  • Replies 82 replies
  • Subscribers 379 subscribers
  • Views 13555 views
ahmedfotoh
ahmedfotoh over 1 year ago
imageI just bought a new Rigimage
ol Dho804 Oscilloscope, but there is a problem, I connect the attached power supply to the 220 v power source and turn it on but the display stays black and no boot to the operating system, What should I do?
    michaelkellett over 1 year ago in reply to geralds +3
    I'll try to get round to a mini road test of the DHO924 in a couple of weeks. MK
    dougw over 1 year ago +2
    Check the power supply - is it providing the right voltage to the main controller card?
  • cstanton
    cstanton over 1 year ago in reply to ahmedfotoh +2
    Was this the original power supply you received with the device? If not, have you looked at the manual/datasheet for the oscilloscope to see what voltage and amps it requires from the power supply?
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Andrew J
    I upload the DHO800_UserGuide_EN manual, This power supply has Type C terminal.
  • ahmedfotoh
    I bought it from local China supplier, You recommend me to change the power supply with another has 15v 4 A and test?
  • PavelKCZ
    0 PavelKCZ over 1 year ago
    Well, the display is working, at least for some time (Rigol logo can be seen in the video).
    I would say that there is faulty flash image or something similar, bad RAM or something similar. Boot sequence is able to display logo, but halt shortly after this.
    If the scope is new and under warranty, I would suggest to contact the vendor and ask for exchange.
    0 Jan Cumps over 1 year ago in reply to ahmedfotoh
    Looks like they gave you a wrong one. This is shown in an unboxing blog:
    source: https://www.eevblog.com/forum/testgear/rigols-new-dho800-oscilloscope-unbox-teardown/msg4965181/#msg4965181
  • Andrew J
    0 Andrew J over 1 year ago in reply to Jan Cumps
    I saw a different one in a different unboxing video!!
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to PavelKCZ
    Yes,  The scope is new and under warranty, But the vendor in China and I'm in Egypt to ask for exchange. I ask for what can ÷ do any thing to reset the hardware  or something like that
  • Andrew J
    0 Andrew J over 1 year ago in reply to ahmedfotoh
    I would only recommend going back to the supplier or checking with Rigol support what power supply it should have based on the serial number.  If it really does require 12V you don't want to plug a 15V supply in.
    0 Jan Cumps over 1 year ago in reply to Andrew J
    I've seen 2 unboxings with that one
    https://www.bilibili.com/video/BV1ox4y1R7qj/
    https://www.bilibili.com/video/BV1Lz4y1E7bt/
    There may be different versions out there. Did the one you see, have a good enough clarity to read the current?
  • PavelKCZ
    0 PavelKCZ over 1 year ago in reply to ahmedfotoh
    If you have a proper connector somewhere, you can solder a piece of wire to it, connect to your bench power supply and try it. If it will work, the AC adapter is faulty. If it will not work, something inside the scope is faulty. One way or another, you should ask the vendor for exchange for a working unit or money back.
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Jan Cumps
    Ok, Many thanks  I will going back to the supplier and checking with Rigol support what power supply it should have based on my scope serial number.
