Test & Tools
Test & Tools
Documents Programmable Electronic Load - Analyse the Summing Node Zero Point
  • Date Created: 1 Dec 2017 4:08 PM Date Created
  • Last Updated Last Updated: 15 May 2020 3:38 PM
  • Views 12895 views
  • Likes 8 likes
  • Comments 107 comments
This blog documents investigates the feedback node of the electronic load that Robert Peter Oakes, jc2048 and Jan Cumps are designing.
It's an important spot in the load's design. It measures the set point and the feedback from the output.
When the output is driven to 0, it should be on a potential as close as possible to 0 V.
On the first prototype it's -0.2 V. Not so much off, but the negative value  influences our ADC measurements.
This document checks how we can get this node to 0 V.
Because this document is evolving, some comments below may be out of sync with the content. That's because the content is adapted based on the conversation.
The measurements taken here are based on the original design, without R32 in place and U3B + tied to ground.
The current sense side of R7 is connected to ground, and a variable negative voltage from 0 V down is applied to the current sense side of R8 to simulate current being sensed.
The circuit isn't complex. The set point is driven by a DAC. It's set to 0 for this test.
The second input to this node is OpAmp 3C. It has both inputs tied to ground so should theoretically have 0 V at the output.
On my board I measure a potential of -0.212V at the left side of R33.
I hope to get this closer to 0 V to ease the ADC a bit - its performance degrades with negative voltage at its inputs.
Like the other blogs for the electronic load, this is a working document that will be updated with findings from anyone who wants to chime in.
Behaviour at 0V
buzy image
  • metrology
  • differentiator
  • boosterpack
  • opamp
  • msp432
  • launchpad
  • analog
  • laboratory
  • instrument
  • jc2048
    jc2048 over 8 years ago in reply to Robert Peter Oakes +4
    As you say, changing the op-amp is one possibility. There are bipolar op-amps with much lower bias currents, but an alternative nowadays is a precision CMOS op-amp (you'd have to check whether other characteristics…
  • Robert Peter Oakes
    Robert Peter Oakes over 8 years ago +3
    To hopefully simplify things a little We have this, Upper op amp is simply to provide an inversion of the measured value back tot he ADC, hence the gain of -1 Lower right op amp measures the volts across…
  • jc2048
    jc2048 over 8 years ago in reply to Jan Cumps +3
    Love the advertisement for "John's excellent probes". It's like one those things from the old days of American TV where the presenter would suddenly turn, look very earnestly at the camera, and start reading…
    Jan Cumps over 8 years ago in reply to Jan Cumps
    Here's a long running sample. 5400+ samples. Ignore the blip at 2400 because that's when I paused the test to go out with my youngest daughter. I don't want to burn my house.
    It's still running. I'll stop it when I close for the night (bloody early flight, need to be up at 4:00 image ).
  • jc2048
    For a comparatively simple circuit, it's been a very good vehicle for blogging. I'm learning a lot from it, though I think it will be a while before you give me my diploma in servo systems (I never was any good at maths, and I'm certainly not now).
    One worry I have about those blogs you refer to is that I'm not an expert in this. All the simple project stuff [I'm thinking about Arduino stuff here] doesn't matter too much (it's just fluff, though it's fun and serves a useful purpose in getting people interested and acts as a way of introducing concepts), but those blogs were moving into the area of theory, but theory that I'm not qualified to teach. I think, on balance, it's worth doing this stuff (as much because it gives an idea of how electronic design is done and how you think about things and solve problems as the actual detail of what you're blogging about), but I often think that there are lots of people out there who could do it so much better than I could.
    To extend the range down you just need a higher value sense resistor (though you obviously lose the top end). A 5R sense resistor should get you down a couple more decades. You might need to swap the MOSFET (though it would be an interesting experiment to try the 5R in the existing circuit and see what happens with the MOSFET if you take the drain current down further). That then leads to the idea you could switch the load resistors into circuit, but that falls on the difficulty that anything you use as a switch has a significant resistance compared to the 50mOhm. Another possibility would be the two resistors in series, with a relay to short out the 5R for higher currents, but you'd need two sense circuits and some way to switch between them.
    A further idea, if the current when forced off is very low, is two parallel two circuits with either being allowed to operate - a high current one and a low current one. You might even be able to arrange for both to be operating together, though I suspect the loop stuff gets a bit hairy if you do that. [One thing to watch, though, is that the clever scheme of shifting the ground point to the source of the MOSFET rather than the negative load connection would compromise that.]
    I've got a much, much lower cost design using transistors (a completely op-amp free zone!) - I did that a while back as a challenge to myself to see if I could design something more complex than a textbook circuit. I haven't prototyped it yet but it works ok in the simulator. (I'm a bit slow in my old age - it was only after I'd started it that I realised I was actually designing a discrete op amp, though it does differ a bit from the traditional do-anything op-amp design). It's nothing like the precision of this one and it's not a true servo system, but it's much faster. Component cost would be a few pounds. I'm saving it for the next DIY Test Equipment contest.
    Jan Cumps over 8 years ago in reply to jc2048
    jc2048  wrote:
    It doesn't matter to you because the loop seems to be dealing with it quite happily.
    Yes, it's impressive that the control mechanism gets such a good grip on the current with the MOSFET being a tough device to control in this range of operation.
    But do you actually need the load to be able to do this? Do you need the load to operate continuously over more than 4 decades of current?
    No. My main goal was to see if I could turn Peter's design into a programmable one. I started from that point, with no other goals.
    It's certainly not a perfect exercise.  I learned and re-learned a lot while doing this (I'm expected to be a diploma'd control mechanism guy but I needed loads of studying to get hold of the theory and practice again - this exercise bumped me back into the stratosphere of control theory image ). And I'm pleased that it yielded those blog posts you made that explain the behaviour of the control part.
    I think this instrument as it stands now is useful in its operating range. Mine is fairly stable and linear between 2 mA and 6 A for the control part. The measurement part I have only roughly tamed. It needs more work before we can see how well that behaves.
    Maybe, because everything is published, there is a chance that someone improves on it. Maybe by increasing range and precision. Or by reducing the costs by factoring out some of the ridiculously expensive components I used ... (and improving the PCB design)
  • jc2048
    The MOSFET behaviour is very interesting and I'd like to investigate that. I don't know much about how these power MOSFETs behave if you try and use them in the linear region like this - the manufacturer intends them as power switches, so the datasheet doesn't help very much - but if I had to guess, I'd say that maybe you're seeing the effect of having an array of MOSFETs in parallel, all with slightly different characteristics, and characteristics that change with temperature and so are dependent on how the currents arrange themselves (a power MOSFET like this will be an array of smaller MOSFETs). It's possible that down around the threshold voltage there's a certain amount of somewhat chaotic behaviour to the gate voltage (ie there might be several arrangements that allow for the small total current and which you get may depend on very subtle variations as you approach - if that were the case, it ought to be possible to repeat the measurement many times and map the various 'paths' through that area).
    Anyway, that's just wild speculation [quite out of character for me!] and might be totally wrong - where are all the experts when you need them? It doesn't matter to you because the loop seems to be dealing with it quite happily.
    Back to the load. I've just sat thinking about all this and it seems to me that you're asking a lot of this circuit. The sense resistor is 50mOhms, so for 1mA current you get 50uV on the sense. You then give it to an op amp with an offset voltage of 180uV (typ)/ 600uV(max) to deal with. I suspect we're getting to the point where you would need to think about trimming the offset on that first amplifier.
    But do you actually need the load to be able to do this? Do you need the load to operate continuously over more than 4 decades of current? If you don't, perhaps you might do better to build two instruments covering different ranges.
    Well, it didn't smoothen that out image
    The input voltage this time was 6 volt.
    Here is the same exercise with Scope bandwidth on and input voltage = 5 V.
    I'm doing the gate measurements again. I've just learned how to program the Bandwidth filter of my scope.
    I've done the same measurement a second time. Even though the current graph is stable, the gate graph shows significant difference:
    jc2048  wrote:
    Can you measure the voltage at P7.1 so we can see what the integrator thinks it is telling the MOSFET to do as you go past the cut-off in the current.
    No offset remediation, 5 V input:
    Current:
    Gate voltage:
    DAC ACurrentGate Voltage00,00143,35343710,00143,35269820,00143,3507330,00143,35337440,00143,35242250,00143,35390960,00143,35404570,00143,3546680,00143,35480390,00143,354254100,00143,35567110,00143,351876120,00143,352835130,00143,352695140,00143,355678150,00143,351142160,00143,354182170,00143,348902180,00143,352893190,00143,353103200,00143,348097210,00143,345566220,00143,350055230,00143,351615240,00143,348017250,00143,348708260,00143,346317270,00143,347818280,00143,347957290,00143,344709300,00143,344922310,00143,349371320,00143,348553330,00143,348708340,00143,348363350,00143,351747360,00143,351609370,00143,349983380,00143,348498390,00143,351478400,00143,353572410,00143,349933420,00143,351079430,00143,352707440,00143,352893450,00143,354721460,00143,351874470,00153,354321480,00153,355607490,00143,356076500,00143,353433510,00143,35324520,00143,354931530,00143,353911540,00153,35405550,00153,35445560,00143,355271570,00153,355128580,00143,35331590,00143,354188600,00143,353165610,00143,349245620,00143,352023630,00143,348979640,00143,348836650,00143,348171660,00143,350323670,00143,34721680,00143,346877690,00143,351272700,00143,347602710,00143,353373720,00143,351874730,00143,352428740,00143,355275750,00143,355136760,00143,355128770,00143,354117780,00143,353505790,00143,354453800,00143,350465810,00143,353911820,00143,352018830,00143,352834840,00153,356083850,00143,353508860,00143,352357870,00143,352086880,00143,351743890,00143,354119900,00143,35405910,00143,351533920,00143,353846930,00143,349652940,00143,354663950,00143,350929960,00153,354728970,00153,352423980,00143,349096990,00143,3555381000,00143,3539931010,00143,3539781020,00153,3554681030,00153,3567651040,00163,3606141050,00183,3609571060,00183,3613481070,00193,3619461080,0023,3634011090,00223,3678861100,00233,3818541110,00243,3895671120,00263,3974531130,00263,4006511140,00273,404911150,00293,4192361160,0033,42611170,00313,4361551180,00333,4420671190,00343,4439051200,00343,4441751210,00363,4454071220,00363,446081230,00383,4479351240,0043,4514211250,00413,4518071260,00433,4542371270,00423,4552941280,00443,4581661290,00463,4618811300,00463,4618341310,00483,4641871320,00493,4667011330,0053,4678361340,00523,4697751350,00533,4713181360,00543,4741281370,00553,4796891380,00573,4783691390,00583,4840441400,00593,494371410,00593,4981731420,00613,4984081430,00623,5082021440,00633,5141291450,00643,5185741460,00653,5243791470,00673,5276281480,00683,5278771490,00683,5320271500,0073,5342361510,00713,536711520,00723,538541530,00743,5452391540,00753,5559571550,00763,5520351560,00783,5588611570,00793,5569111580,00793,5617021590,0083,5686871600,00823,5707941610,00833,5802261620,00843,5796111630,00853,5795491640,00863,5817841650,00883,5834721660,00883,583961670,0093,5846981680,00913,5852371690,00923,58831700,00933,5895111710,00943,5891811720,00963,5923681730,00973,5920971740,00983,591411750,00993,5940531760,013,5954081770,01033,5958141780,01043,5975061790,01063,5974391800,01073,5977771810,01073,5981171820,01093,5981151830,01093,5986571840,01113,5990731850,01123,5991351860,01133,5989321870,01143,5994011880,01153,5991981890,01163,5991981900,01183,5994011910,01193,5995461920,0123,5998741930,01223,5994691940,01233,5996721950,01233,599811960,01253,5996081970,01263,5996721980,01263,5995411990,01273,5996082000,01293,5996722010,0133,5996722020,01313,5999462030,01333,5999422040,01343,5999432050,01373,5997392060,01373,5999452070,01393,5998732080,01393,6000192090,0143,5996722100,01413,6001422110,01423,5998072120,01453,6008022130,01463,6000732140,01463,6003452150,01483,600542160,01483,6024532170,0153,6018612180,01513,6019922190,01523,6052992200,01543,6056292210,01553,6099792220,01553,6085942230,01563,6177022240,01583,6042422250,01593,6114462260,0163,6197482270,01613,6184872280,01623,6173672290,01633,6256712300,01653,6258672310,01663,6216582320,01673,6283142330,01693,6300722340,0173,6346222350,01723,6320452360,01733,6304862370,01753,6350782380,01763,6348292390,01773,6352352400,01783,63492410,01783,6350922420,0183,6359062430,01813,6378722440,01823,6396022450,01833,6400592460,01853,6403332470,01853,6409362480,01863,6399622490,01883,6420982500,01893,6403982510,0193,6417612520,01913,6413452530,01933,6433012540,01943,6471122550,01963,645142560,01973,6482732570,01973,6460842580,01983,6476552590,023,6496892600,02013,6546552610,02023,6549942620,02043,6524092630,02043,6549912640,02063,6574952650,02083,6566192660,02093,6595192670,0213,6593962680,02113,6583082690,02123,6636062700,02133,6680072710,02143,662322720,02153,6655672730,02163,6667212740,02173,6679412750,02183,6672682760,02193,6696382770,0223,6697072780,02223,6715322790,02233,6698382800,02243,6720032810,02253,673092820,02273,673232830,02273,6724112840,02293,674512850,0233,674512860,02323,6737052870,02333,6758642880,02343,6744422890,02353,6757962900,02353,6753972910,02363,6757282920,02383,6753982930,02393,676272940,02413,6764082950,02423,6776232960,02433,6772852970,02453,6777582980,02463,6776232990,02473,6778943000,02483,677961
    I have this working. I'm logging pin P7.A via the scope ...
    I'm adapting the test set to allow 4 additional measures using an oscilloscope. I'll start with P7.1
    I don't have a LabVIEW capable DMM, so I'm using the scope as voltage probe.
    I'm making it an optional instrument. I'd like to be able to run quick tests without having to set up the oscilloscope just to make it work.
    Are you interested in the gate voltage with or without offset compensation? I'm running it without first (I've removed the compensation botches)?
    Might be an idea to give it a look-over with a scope too. The meters might not be showing you the whole picture.
    Todo
