Design For A Cause 2021
  • Design For A Cause 2021
Blog BLOG# 1 - Beats Per Minute Nano - INTRODUCTION
  • Author Author: skruglewicz
  • Date Created: 6 Mar 2021 4:56 PM Date Created
  • Views 1622 views
  • Likes 13 likes
  • design_challenge
  • beats per minute nano
  • design_for_a_cause_2021
skruglewicz
skruglewicz
6 Mar 2021
A Heart Rate Monitor using the Arduino Nano 33 IoT Board
INTRODUCTION
This is my Introductory blog post for this Design Challenge: Design for A Cause 2021
Updated
version 1.4
For this design challenge, I've decided to port a project that I developed during a challenge in the Azure Sphere Group, to the Arduino Nano 33 IoT Board
  • Beats Per Minute -- Home Is Where the Hack Is Challenge
    • In this blog, I demonstrated how I connected a Heart Rate Sensor to the Avnet MT3620 kit. The Beats Per Minute are calculated and displayed on an attached OLED Display. The RED LED will indicate the users heart beat..
    • I will replace the MT3620 kit with the Arduino Nano 33 IoT Board
Beats Per Minutes project photos and video
  • The 5 Blogs
  • My Idea
  • The Project Plan Blogs
    • Blog#2 Beats Per Minute Nano - Research & Experimentation
    • Blog#3 Beats Per Minute Nano - System Design
    • Blog#4 Beats Per Minute Nano - System Implementation and Testing
    • Blog#5 Beats Per Minute Nano -  Conclusions and Future Enhancements
  • REFERENCES
The 5 Blogs
    • To comply with the Challenge requirement to create 5 blogs,  my plan is to use this blog post as a table of contents and will add the other blogs as links..
    • Blog Naming Format
      • In order to keep track of the BLOGS, I use the following naming convention to title my blogs related to this challenge.
      • Blog# <n> Beats Per Minute Nano - <topic>
    • Blog Version numbering
      • Blogs will be marked with a version number to indicate changes over time. The naming convention for version number will be (<major#>. <minor#>)
        • for example 1.0 is the first edition of the blog and 1.1 is the 2nd and so on.
      • The major number will not change during this challenge and will be used for a later Design cycle, if ever.
My Idea
My plan, is to use the supplied challenge kit (Nano 33 IoT ) as a Beats Per Minute Heart Sensor Unit. I will be designing this heart Sensor unit for this challenge.
  • For my Design, I'll be attaching a Heart Rate Sensor and a OLED Display to the supplied challenge kit (Nano 33 IoT )
  • I never worked with an Arduino before so, I will be experimenting with the Nano 33 IoT and the components I'll be using for this challenge.
    • Connecting the Heart Sensor
    • Connecting the OLED Display
  • Researching and experimenting with persisting telemetry data.
    • I'll experiment with the Arduino's IoT Cloud, in order to store Heart Rate Sensor Data
    • If time permits, I'd like to research attaching to MongoDB atlas, which is a NoSQL database engine that I used in the following challenge:
      • Blog# 8.2 (Part 2 of 2) EAS - DATA REPOSITORY MongoDB
  • I will be using a developer workstation that I configured with Ubuntu.
    • Here are my notes: My OLD/NEW Linux Developer workstation.
    • I have attached the Nano to it.
    • I plan to use Visual Studio Code with an exciting extension I just discovered, called PlatformIO
  • In addition to Arduino's IoT Cloud, I'm intrigued to experiment and implement the following technologies into my design using the following project listed on Arduino page
    • Blynk: a simple project from our community connecting to Blynk to operate your board from a phone with little code
    • IFTTT: see an in-depth case of building a smart plug connected to IFTTT
    • AWS IoT Core: we made this example on how to connect to Amazon Web Services
    • If time permits:
      • Azure: visit this github repository explaining how to connect a temperature sensor to Azure's Cloud
    • Firebase: If you want to connect to Google's Firebase, this Arduino library will show you how
Required Hardware (Bill of Materials)
Here are the components I used for the project. I also used: Breadboards and Jumper wires for experimenting and the challenge Heart Sensor circuit.
NANO 33 IOT W/HEADER
DEVELOPMENT BOARD
BUY NOW:
• Heart Sensor
BUY on Amazon
SSD1306 I2C OLED Display
128x64 Yellow Blue
eg. this one for $6.99 from Amazon...
BUY on Amazon
    • Since I have not used Arduino before I will need to research and experiment with the following:
    • The Challenge Kit Arduino Nano 33 IoT
      • connecting the Nano to the IDE.
        • I plan to use VS Studio with the PlatformIO extension, which is claimed to function like the Arduino IDE
        • I will be experimenting with a few example sketches.
    • Connecting the Heart Sensor to the Nano
    • Connecting the OLED to the Nano
    • Using the Arduino IoT Cloud
    • Experimenting with selected projects from the Element14 community: Blynk, IFTTT, Azure
    • Using MongoDB Atlas if Possible.
    • Block diagram
      • Wiring Diagram
        • Show the components (Nano & OLDED) wired to a breadboard.
    • Software Design
      • UML Sequence Diagram
        • Show the Logic of the flow of the Software
      • Libraries
        • All the libraries are used in Blog#2
    • Electronics build
      • Use the wiring diagram described in the design blog#2
    • Software Programming
      • Use a GitHub repository to maintain the source code
      • Describe the routines used.
      • Conclusions and/or Problem encountered.
    • Testing
      • Electrical
        • Test the wiring.
        • Conclusions and Findings
      • Software
        • Unit test the code dealing with the 2 components (Pulse sensor,& OLED)
      • Run Application
        • Run the application and compare the BPM to another BPM app if possible.
        • Show a video
        • Conclusions
          • Any Problems?
    • Conclusions
      • Give some conclusions as to what you have gained from this Design Challenge
      • Did everything work as designed?
      • What were the biggest hurdles you had to overcome?
    • Future Enchantments
      • List some possible enhancements that can be added to make the system more useful.
      • The subjects that I did not have time to implement:
1. Using the Arduino IoT Cloud
          • LINK to Project page
2. Experimenting with selected projects from the Element14 community: Blynk, IFTTT, Azure
3. Using MongoDB Atlas if Possible?
          • Connect to MongoDB Atlas with C
          • Write the data from the Heart Sensor Project to the Database.
      • Other Enhancement Ideas?
REFERENCES
    DAB over 5 years ago +2
    Nice plan. DAB
    Nice plan.
    Nice plan.
