Experimenting with Magnetic Components
  • Experimenting with Magnetic Components
Blog Experimenting with Magnetic Components - Boost Converter part 1: Inductor and Calculations
  • Date Created: 2 Oct 2021 11:23 AM Date Created
  • Views 4660 views
  • Comments 9 comments
  • experimenting_with_magnetic_components
  • magnetic_components
  • bourns
2 Oct 2021
I'm reviewing a set of inductors for the Experimenting with Magnetic Components design challenge.
Because it's a design challenge, I'd like to start with a working product. A switch mode DC converter.
It's one of the standard circuits: the boost converter. A design that increases a DC voltage.
Goals:
  • 9 - 12 V DC input
  • 30 - 60 V DC output
  • up to 20 mA output current
  • max 200 mV ripple
  • common components
  • no regulation or feedback
But first:
Post 1#: Introduce yourself and explain what experiments you plan to perform
I live in Schaerbeek, Belgium and have studied electronics, measurement & control techniques, and information systems.
My theme is "grow the love for inductors as LAB project building block".
  • What they do
  • Where you use them,
  • Review the inductors in the kit
  • How to measure, without LCR meter
  • How to use an LCR meter
  • How to roll your own coil, your own little transformer
  • PCB transfo
Back to the story:
The inductor: Bourns RLB Series 1mH Radial Lead InductorBourns RLB Series 1mH Radial Lead Inductor
image: Bourns RLB0914-102KLRLB0914-102KL 1MH inductor with candidate MOSFETs
The datasheet is available on element14. All info is taken from that document.
image: the specifications of the 1mH inductor
Measurements on the component in my kit:
The datasheet did the measurements at 252 KHz. I'm doing them at the maximum setting of my meter: 100 KHz.
The meter (comparable with GW INSTEK LCR-916) was calibrated before the measurements.
Results (f = 100 KHz)
L:955.5µH
Q:  106.5
D: 0.009 (1/Q)
ϕ: 89.4°
ESR: 5.64 Ω
The Boost Converter Calculations
I'm using the most common boost converter design. Adafruit (and others) posted a calculator online.
I used that, and changed parameters until the design matched the 1 mH inductor.
image source: calculation done with the Adafruit boost converter calculator.
Whe in I use a switching frequency of 72000 Hz, the calculator suggests exactly 1 mH.
Texas Instruments has an application note on the calculations.
Coursera has an excellent Power Electronics course, from U of Colorado Boulder.
Hang on while I'm starting the build.
Related posts
1. Boost Converter part 1: Inductor and Calculations
2. Boost Converter part 2: Build
3. Boost Converter part 3: Measure the Inductor in action
4. LCR meter experiments
5. SMD transformers experiment gizmo part 1: Build
6. SMD transformers experiment gizmo part 2: Measure
7. Common Mode Choke
8. Make your own Inductor
9. Calculate your own Inductor
10. Boost Converter part 4: Efficiency
11. DIY Inductance Meter
Planar PCB Transformer: GaN Point of Load converter 48V to 1V 50A
Measure Unknown Inductor Value with Function Generator and Oscilloscope
Experimenting with Magnetic Components: About the Competition
    Jan Cumps over 5 years ago
    Some measurements of one coil of inductor #10 with LCR (100 kHz): Common Mode choke 9 µHCommon Mode choke 9 µH
    Inductance:
    Phase angle (θ):
    Dissipation factor (1/Q)
    Quality factor (tanθ, 1/D)
    Equivalence serial resistance:
    Inductance:
    Phase angle (θ):
