Pi Chef Design Challenge
  • Pi Chef Design Challenge
Blog The Spice of Pi - Blog Doug 8
  • Author Author: dougw
  • Date Created: 1 Mar 2018 4:52 AM Date Created
  • Views 2222 views
  • Likes 10 likes
  • Comments 10 comments
  • doug wong
  • spice of pi
  • pi chef design challenge
  • pi chef
dougw
dougw
1 Mar 2018
I have finally assembled the complete mechanical system. Both the carousel rotation mechanism and the jar lifter mechanism have been mounted on the bamboo base plate. The video below shows the first operation of the complete mechanism.
Hopefully the PCB I designed at the beginning of the project will arrive soon so I can get the electronics build completed.
And then it is on to the software....
Design Challenge Links:
About the challenge
The other challengers
The kit
Terms & Conditions
Summaries by Charles Gantt
Project Links:
Blog Doug 1 - The Concept
Blog Glenn 1 - AIY Voice Kit Unboxing
Blog Doug 2 - The Block Diagram and Bill of Materials
Blog Doug 3 - Spice Jar Lift Mechanism
Blog Glenn 2 - Firmware Considerations
Blog Doug 4 - Carousel Design
Blog Doug 5 - Platter Rotation Mechanism
Blog Doug 6 - 3D Printed Platter Parts
Blog Doug 7 - Main Drive Assembly
Blog Doug 8 - Working Carousel
    genebren over 8 years ago +2
    Doug, Great job! I don't know if I am having a slow internet day, or if there is a problem with your video, but I could not get past the 10 sec mark of your video. I will try again later. Gene
  • three-phase
    three-phase over 8 years ago +2
    Nice video showing the operation. I also had a problem viewing in within the blog, I got to 15 seconds and it then stopped, but it played fine when viewed directly on Youtube. Kind regards
    dougw over 8 years ago in reply to three-phase +2
    If problems persist, I will reload the video.
    Doug,
    Gene
    Doug,
    Gene
    dougw over 8 years ago in reply to genebren
    I'm not sure what the issue is. The first time I viewed the blog, the audio got out of sync when the rotating segment started, but I restarted the video and it seems to work fine now on both IE and Chrome.
    genebren over 8 years ago in reply to dougw
    Doug,
    I still could not view the video on my computer (others are working fine, I did try it with Youtube on my computer, and that did not work).  I was able to view it on my phone (youtube), and I am very impressed.  You did a great job designing and fabricating the parts.  It does seem like the rotation servo is working pretty hard and the lifting servo could use a tad more lift, but working is far more important that working perfectly at this point.  Hope fully your drive electronics will give you a more stable movement with a little resolution.
    Great work!
    Gene
    The motor sounds about the same with no load.
    The platter has good bearings and takes almost no torque to start spinning, regardless of how much the jars weigh.
    The torque only affects the magnitude of acceleration and deceleration.
    The servo supplies about 13 Kg-cm, which is more than adequate acceleration and deceleration.
    I didn't measure it, but it reaches top speed in under 1 second - I think the servo circuit might be limiting acceleration.
    I think I will have a look at the servo tester signal on a scope....
    I re-did the video - it is now working better for me....
    Doug,
    Looks good now!
    Gene
