Upcycle IoT Design Challenge
  • Upcycle IoT Design Challenge
Blog ColdCase - Blog #2 - The refrigerated cell
Join Upcycle IoT Design Challenge to participate - click to join for free!
  • Author Author: amgalbu
  • Date Created: 5 Jan 2024 3:14 PM Date Created
  • Views 843 views
  • coldcase
amgalbu
amgalbu
5 Jan 2024
In this post, I will show how I built the refrigerated cell of the mini fridge
Other posts in this serie
  • ColdCase - Blog# 1 - Introduction
  • ColdCase - Blog #2 - The refrigerated cell
  • ColdCase - Blog #3 - Preparing the environment
  • ColdCase - Blog #4 - The software
  • ColdCase - Blog #5 - Final assembly
  • ColdCase - Blog #6 - The Android app
  • ColdCase - Blog #7 - Final assembly
First of all, I removed the bottom part of the frame that used to host the Hard Disk drives. This will let me create a larger refrigerated cell
{gallery}Metalwork
Then, I created a box made of Plexyglass and angular brackets. These will be the internal walls of the fridge. Brackets have 15-millimeters supports to keep the right distance from the external walls.
{gallery}The refrigerated cell
Brackets that are placed on the front side of the box also have some insets to keep a frame in place.
The wall on the back has a hole for the Peltier cell. Peltier cell and heatsink are kept in place by a 3D-printed support made of TPU. I chose TPU because it has a better heat resistance and is flexible. Thanks to this flexibility, I can position both the Peltier cell and the heatsink without need for extra screws.
{gallery}Installing the Peltier Cell
Box has been put in place and covered with expanded polyurethane foam. Excesses have then been trimmed using a cutter
{gallery}Cell covered with foam
The Temp&Hum Click board has been put in place and covered with insulating material (not foam, to make it easy to access and replace in case of issues)
Finally, I mounted back in place the power supply
Everything is ready to install the control board with all the electronic components. Stay tuned for the next blog!
    DAB over 2 years ago
    I am interested to see how well this implementation works.
