Upcycle IoT Design Challenge
  • Upcycle IoT Design Challenge
Blog ColdCase - Blog #7 - Final demo
Join Upcycle IoT Design Challenge to participate - click to join for free!
  • Author Author: amgalbu
  • Date Created: 25 Jan 2024 5:49 PM Date Created
  • Views 2143 views
  • Likes 10 likes
  • Comments 11 comments
  • coldcase
amgalbu
amgalbu
25 Jan 2024
For the sake of a fair competition, I tried to complete this challenge within two months since I received the challengers kit (which is hopefully the same amount of time all the other participants had available to build their project).
In any case, this is the final result of my efforts.
Unfortunately, the results are not as expected: I probably made a wrong estimation of the requirements for the Peltier cell, and I can lower the temperature inside the fridge only 8 degrees from external temperature. I probably need to mount a larger Peltier cell or to improve the insulation, but the available space does not allow me the increase the thickness of the foam that much.
Apart from that, as usual I had a lot of fun making this project. I already had some experience with MPLab and this helped me the make the Curiosity board up and running in a reasonable amount of time.
Source code for both the Curiosity board and the Android app is available on github (I will probably clean up the code in the next days, but the functionality is there)
  • https://github.com/ambrogio-galbusera/coldcase
  • https://github.com/ambrogio-galbusera/coldcasemon
Finally, I would like to thanks Element14 and Microchip for sponsoring this challenge.
Thanks for reading and see you soon!
Other posts in this serie
  • ColdCase - Blog# 1 - Introduction
  • ColdCase - Blog #2 - The refrigerated cell
  • ColdCase - Blog #3 - Preparing the environment
  • ColdCase - Blog #4 - The software
  • ColdCase - Blog #5 - Final assembly
  • ColdCase - Blog #6 - The Android app
  • ColdCase - Blog #7 - Final assembly
    DAB over 2 years ago
    Nice finish.
  • amgalbu
    amgalbu over 2 years ago in reply to DAB
    Thanks DAB
  • amgalbu
    Thanks DAB
