Project Videos
  • Project Videos
Project Videos
Documents Adding Android Auto as Non-Permanent Add-On with Raspberry Pi -- Episode 520
  • Date Created: 14 Oct 2021 2:24 PM Date Created
  • Last Updated Last Updated: 15 Oct 2021 7:24 AM
  • Views 10986 views
  • Comments 17 comments
Cars can last a long time, they certainly outlast the fast pace of tech advances. So I thought I'd see if I could add some modern conveniences to a slightly older car using a Raspberry Pi and Android Auto.
Supplemental Content:
  • Episode 520: Bonus Content: Adding Android Auto
  • Enter the Project14 Auto Hacks Competition for a Chance to Win a Shopping Cart!  View ContestDetails!
  • Vidor4000 CAN-Bus Project by alisterw
  • Vehicle Speed Camera - Beaglebone AI by gam3t3ch
  • BBAI Seein' Around Corners, Talkin', IoT Exploitin' Backup Car Cam with Onboard Vision AI by Sean_Miller
  • Driver State Monitor with OpenCV and BeagleBone AI by vlasov01
  • Virtual Loop Sensor by skywalker1211
  • A more Intelligent Idiot Light by mcb1
Bill of Material:
RPI4-MODBP-8GB Raspberry Pi 4 Model B 8GB RAM Raspberry-Pi 1 Buy Now
83-17980 Development Board, ChronoPi Real Time Clock (RTC) Module, For Raspberry Pi MACETECH 1 Buy Now
25HK-AB-120A250-D56-FR AC/DC Power Supply, ITE, 1 Output, 30 W, 12 V, 2.5 A Ideal Power 1 Buy Now
767KS17 SEALED POWER PLG, 5A, 30VDC, 2.1MM PIN DIA SWITCHCRAFT/CONXALL 1 Buy Now
TSRASPI10-16GB MIRCO SD CARD PRELOADED W/NOOBS, 16GB TRANSCEND 1 Buy Now
TOUCHSCREEN 10.1 Touchscreen Display, 10.1″, IPS HD Resolution, Raspberry Pi Compute Module/A/A+/2/3B/3B+/4 Multicomp Pro 1 Buy Now
BC517-D74Z NPN Transistors ONSEMI 1 Buy Now
Additional Parts Manufacturer Quantity
0.5mm 2 core Flex cable ~1M
TP223 touch sensor
Wire (small gague, mutiple colours help!)
Miscellaneous metal and screws
LED
5V Fan
Resistors
David Edwards - Additional.zip
element14 presents
element14 presents  | About David |  Project Videos
  • android auto
  • david edwards
  • e14presents_daveedwards
  • upgraded head unit
  • car
  • autohacksch
  • switchcraft
  • ideal power
  • raspberry pi
  • multicomp
  • open auto
  • friday_release
  • navigation
  • a531016
    a531016 over 4 years ago in reply to siwinter +1
    Good question, I thought there was one in the attachments. Let me have a look and I'll see what I can find for you!
  • a531016
    a531016 over 4 years ago in reply to AShiftySpock
    Apologies for the delay, I took the time today to take it out to properly draw a scematic too. Long story short, there are screws fitted to captive nuts that grab onto the "shade" part of the dash and clamp down. To make sure they don't bite into the dash too much, I used a few spacers:
    Covers removes for illustrative purposes!
  • a531016
    Apologies for the delay! I have had some time off from the day job, so took the time to take it out and document it properly!
  • AShiftySpock
    AShiftySpock over 4 years ago
    Was wondering how you mounted this to the dash without destructively screwing in the mount, have you got any pictures of this? I was also wondering if you knew where would be best to look for some place that sell the screen without the Pi to make it a bit cheaper? I already have a couple Pi 3s lying around the house.
  • siwinter
    siwinter over 4 years ago in reply to a531016
    Hi, any good in finding it?  Thanks
  • a531016
  • siwinter
    Hi, do you have sketch of the wiring? Im bit confused just seeing it on video. Thanks
  • a531016
    a531016 over 5 years ago in reply to koudelad
    Thank you! I'm glad you lIked it! Let us know if you build your own!
  • koudelad
    koudelad over 5 years ago
    Fantastic and useful project. Thank you, David, I made a bookmark.
  • a531016
    a531016 over 5 years ago in reply to glennvanderveer
    Perfect! Well don't forget to blog about the build and share the result with us - or better publish a video!
  • glennvanderveer
    glennvanderveer over 5 years ago
    This could not be more timely.  I have a 2013 Ford Focus (the radio actually is a piece of garbage), and the latest upgrade of my Pixel 5 to android 12, disabled the Android Auto over Bluetooth...
