Radio Control
  • Radio Control
Radio Control
Blog FPGA: a quadrature oscillator with rotary encoder control
Join Radio Control to participate - click to join for free!
  • Date Created: 20 Oct 2021 6:48 PM Date Created
  • Views 7124 views
  • Comments 15 comments
  • summer_of_fpgas
  • radiocontrolch
  • fpga
20 Oct 2021
This design is a pure VHDL quadrature signal generator.
With variable frequency. The frequency can be controlled with a scroll wheel.
The purpose of this design is to build an alternative local oscilator for Shabaz' Software Defined Radio (SDR) Experiment Board.
I tried to make everything as standard as possible, so that it can be used on many FPGA makes and sizes.
I'm working on a Xilinx Spartan 6, with a 12 MHz clock (Xess XuLA2 kit).
The design has 4 inputs
  • rotary encoder pins A and B
  • clock  input
  • reset
and 5 outputs:
  • quadrature signals 0 -> 3
  • the variable clock based on the input clock and the encoder setting
The design is broken up in 3 components:
  • decoder to translate the movements of a scroll wheel into a numeric value.
  • variable clock that will stretch the input clock based on the value coming out of the decoder
  • quadrature signal generator will create 4 90° phase-shifted signals from that variable clock.
A wrapper glues the components together.
All this has been used before for my Pynq blog series and this Spartan 6 article: XuLA2 FPGA - Rotary Encoder and VHDL.
Because all the code has been documented before, I'm just putting the source here.
Check the link earlier in this post for explanations.
quad_decode_quad_osc.vhd
This code should be portable.
The external pins are defined in wrapper entity quad_decode_quad_osc.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
entity quadrature_decoder is
    Port ( QuadA : in  STD_LOGIC;
           QuadB : in  STD_LOGIC;
           Clk : in  STD_LOGIC;
           nReset : in STD_LOGIC;
           Position : out  unsigned (7 downto 0));
end quadrature_decoder;
architecture Behavioral of quadrature_decoder is
signal QuadA_Delayed: std_logic_vector(2 downto 0) := (others=>'0');
signal QuadB_Delayed: std_logic_vector(2 downto 0) := (others=>'0');
signal Count_Enable: STD_LOGIC;
signal Count_Direction: STD_LOGIC;
signal Count: unsigned(Position'length-1 downto 0) := (others=>'0');
begin
process (Clk, nReset)
begin
   if (nReset = '0') then
      Count <= (others=>'0');
      QuadA_Delayed <= (others=>'0');
      QuadB_Delayed <= (others=>'0');
   elsif rising_edge(Clk) then
      QuadA_Delayed <= (QuadA_Delayed(1), QuadA_Delayed(0), QuadA);
      QuadB_Delayed <= (QuadB_Delayed(1), QuadB_Delayed(0), QuadB);
      if Count_Enable='1' then
         if Count_Direction='1' then
            Count <= Count + 1;
            Position <= Count;
         else
            Count <= Count - 1;
            Position <= Count;
         end if;
      end if;
   end if;
end process;
Count_Enable <= QuadA_Delayed(1) xor QuadA_Delayed(2) xor QuadB_Delayed(1)
            xor QuadB_Delayed(2);
Count_Direction <= QuadA_Delayed(1) xor QuadB_Delayed(2);
end Behavioral;
library IEEE;
entity variable_clock is
    Port (
      clk_i    : in  STD_LOGIC;
      resetn_i : in  STD_LOGIC;
      ticks_i  : in  unsigned (7 downto 0);
      clk_o    : out STD_LOGIC
end variable_clock;
architecture Behavioral of variable_clock is
  signal counter_s: natural range 0 to 2**ticks_i'length-1 := 0;
  signal clk_out_s: STD_LOGIC := '0';
begin
process (clk_i, resetn_i)
  procedure perform_reset is -- this procedure contains the reset action
  begin
      counter_s <= 0;
      clk_out_s <= '0';
  end procedure;
  procedure perform_action is -- this procedure contains the reset action
  begin
      if counter_s >= ticks_i then -- >= because the value can change
        counter_s <= 0;
        clk_out_s <= not clk_out_s;
      else
        counter_s <= counter_s + 1;
      end if;
  end procedure;
begin
  if rising_edge(clk_i) then
    if resetn_i = '0' then
      perform_reset;
    else
      perform_action;
    end if;
    clk_o <= clk_out_s;
  end if;
end process;
end Behavioral;
library IEEE;
entity quadrature_oscillator is
  Port (
    clk_i     : in std_logic;
    resetn_i  : in std_logic;
    outputs_o : out std_logic_vector (3 downto 0)
end quadrature_oscillator;
architecture Behavioral of quadrature_oscillator is
  signal pattern_s: std_logic_vector (6 downto 0) := "0011001";
  signal counter_s: natural range 0 to 3 := 0;
begin
  begin
    counter_s <= 0;
  end procedure;
  begin
    if counter_s = 3 then
      counter_s <= 0;
    else
    end if;
  end procedure;
begin
      perform_reset;
    else
      perform_action;
    end if;
    outputs_o(0) <= pattern_s(counter_s + 3);
    outputs_o(1) <= pattern_s(counter_s + 2);
    outputs_o(2) <= pattern_s(counter_s + 1);
    outputs_o(3) <= pattern_s(counter_s + 0);
  end if;
end process;
end Behavioral;
library IEEE;
entity quad_decode_quad_osc is
    Port ( QuadA_in : in  STD_LOGIC;
           QuadB_in : in  STD_LOGIC;
           clk_in : in  STD_LOGIC;
           nReset_in : in  STD_LOGIC;
           oscillator_quad_out : out  STD_LOGIC_VECTOR (3 downto 0);
           clk_out : out  STD_LOGIC);
end quad_decode_quad_osc;
architecture Behavioral of quad_decode_quad_osc is
signal position_s : unsigned (7 downto 0);
signal clk_s : STD_LOGIC;
component quadrature_decoder is
           Clk : in  STD_LOGIC;
end component quadrature_decoder;
component variable_clock is
    Port (
end component variable_clock;
component quadrature_oscillator is
  Port (
end component quadrature_oscillator;
begin
quadrature_decoder_i: component quadrature_decoder
     port map (
   QuadA => QuadA_in,
   QuadB => QuadB_in,
   Clk => clk_in,
   nReset => nReset_in,
   Position (7 downto 0) => position_s (7 downto 0)
variable_clock_i: component variable_clock
     port map (
   clk_i => clk_in,
   resetn_i => nReset_in,
   ticks_i (7 downto 0) => position_s (7 downto 0),
   clk_o => clk_s
quadrature_oscillator_i: component quadrature_oscillator
     port map (
   clk_i => clk_s,
   outputs_o (3 downto 0) => oscillator_quad_out (3 downto 0)
  clk_out <= clk_s;
end Behavioral;
constraints.ucf
The external pins defined in quad_decode_quad_osc are mapped here.
I've mapped them for my specific board. Adapt for your FPGA/kit.
net clk_in                      loc=a9; # 12 MHz clock to FPGA.
net nReset_in                   loc=k15;
# PM1 connections for rotary encoder module.
net QuadA_in                    loc=r15;
net QuadB_in                    loc=m15;
# PM1 connections for the pwm outputs
net oscillator_quad_out[0]      loc=r7;
net oscillator_quad_out[1]      loc=r16;
net oscillator_quad_out[2]      loc=m16;
net oscillator_quad_out[3]      loc=k16;
net clk_out                     loc=t7;
Untested. I'll update if there are errors.
If used for Shabaz' SDR, pins [0]and [2] should go to the JFETS for one opamp. Pins [1] and [3] to the JFETS for the other. Because they are the 2 differential pairs.
    Jan Cumps over 4 years ago in reply to Jan Cumps
    I'm testing it with the SDR. Look and feel is good.
    With a 60 MHz source clock at the moment. Because I know there's a channel to catch when I use that as the prime clock for the FPGA.
    Jan Cumps over 4 years ago in reply to dougw
    Try it image. I don't have a PSoC4.
    I have had one, and was under the impression that:
    • yes, it has configurable hardware blocks
    • no it's not the type of fabric like an fpga that you can VHDL-design with.
    • It might be able to do it if it has 2 configurable D flipflops. That and a programmable timer is all you need.
    The TI Hercules has a programmable timer, and it can do funny things
    dougw over 4 years ago
    Would a PSoC 4 have enough programmable fabric and speed to implement this function?
    With the 12 MHz clock:
    • the fastest quad is 1.5 MHz. period = 666 ns
    • Each click of the rotary adds 666 ns to the period of the signals.
    • After one click: period = 1333 ns = 750 kHz
    • After two clicks: period = 2 µS = 500 kHz, ...
    To have narrow steps at higher frequency, it helps to have a fast clock.
    On a Spartan 6, you can speed up with a clock manager:
    begin
       DCM_SP_inst : DCM_SP
       generic map (
          CLKFX_DIVIDE => 1,                     -- Divide value on CLKFX outputs - D - (1-32)
          CLKFX_MULTIPLY => 25                    -- Multiply value on CLKFX outputs - M - (2-32)
       port map (
          CLKFX => clk_fast,    -- 1-bit output: Digital Frequency Synthesizer output (DFS)
          CLKIN => clk_i,       -- 1-bit input: Clock input
          RST => '0'            -- 1-bit input: Active high reset input
    It's specific for this device, not portable.
    edit: tested it
    20 ns per click of the encoder. It makes it more usable in low MHz range .
    Changes made to the source file:
    All in the very last object, quad_decode_quad_osc. Under the last -- ========================= divider.
    Added the custom Xilinx UNISIM lib for the clock manager primitive:
    library IEEE;
    library UNISIM;
    use UNISIM.VComponents.all;
    Created a signal to hold the fast clock generated by the primitive:
    signal clk_fast: STD_LOGIC;
    Put the primitive just after begin, wired input to the original 12 MHz clock, output to the new signal clk_fast
    begin
       generic map (
       port map (
          CLKIN => clk_in,       -- 1-bit input: Clock input
    Last step: used that clk_fast signal as input for the variable clock object:
         port map (
       clk_i => clk_fast,
    ticks_i => position_s,
    clk_o => clk_s
    It works on the Zynq too, but strange enough,
    only if I place the 3 individual blocks on the block diagram, and combine them there.
    If I put the wrapped design on the block diagram, it doesn't work.
    I'll retry from fresh tomorrow.
    This is how it looks like now (+ action video):
    edit: it works with the wrapper too. I made a typo and had assigned the reset of the quad generator to a rotary encoder pin.
    fixed and all ok now:
