NI LabVIEW Community
  • NI LabVIEW Community
Labview Blogs Automate Measuring the Analogue Front-end of Data Acquisition Board for Pi Pico - Pt. 1: test setup
  • LabVIEW Challenge Blogs
Join NI LabVIEW Community to participate - click to join for free!
  • Date Created: 5 Nov 2023 2:02 PM Date Created
  • Views 1639 views
  • Likes 8 likes
  • Comments 5 comments
  • 2000-scan
  • dmm6500
  • pico
  • labview
  • raspberry_pi_projects
5 Nov 2023
In this little series, I'll automate this exercise: Measure the Analogue Front-end of Data Acquisition Board for Pi Pico .
In the first post: what is the setup and what will I automate?
summary:
The test flow will use a function generator to sweep a DC test input to the analogue front end between +4V and -4V, in steps of 0.5V.
At each step, 5 "interesting "voltages will be sampled with a multi-channel DMM.
Lab Setup
The test signal generator is a multicomp PRO MP750065 Function Generator. It can generate positive and negative signals, with a positive and negative offset. And it's programmable.
In this setup, I'll use its offset capability to generate a DC signal between -4V and +4V. That's not my original idea:
DMM: Keithley DMM6500 with multi-channel switch card. It 'll be able to measure all signals in a single shot. It can do this fast in auto-range. Or I can fine-tune the settings, with each channel set to its optimal range and measurement precision. And use filtering at the cost of speed.
I'm using a Rigol DP832A as supply for the +5V and +3.3V rails. I will not automate it because its only role is to supply constant voltage. And the rails will be provided by a Pico later.
Automation: LabVIEW
I've developed a driver for the function generator earlier:  MULTICOMP PRO MP750065 Function Generator - Programming Pt6: LabVIEW Driver Lib: High Level Functional blocks . I will use the driver to automate the input sweep. I created a block that knows how to select DC as waveform, and how to set offset. It 'll be an easy exercise. Ideal for the first automation post.
Sneak preview:
For the DMM6500, I will probably base it on the Keithley driver example "Keithley DMM6500 DAQ6500 Series Measuring DCV With High Accuracy DCV". It's already set up to work multi-channel.
I'll also reuse a little incrementor block that I made as a LabVIEW exercise:  LabVIEW: Module to Generate Step Increments
I think this will be a fairly easy exercise. Hang on ...
    Jan Cumps over 2 years ago
    Voila
    DAB over 2 years ago
    Looks like a good set up.
    This was the type of testing LabVIEW was made for.
     Automate Measuring the Analogue Front-end of Data Acquisition Board for Pi Pico - Pt. 2: control function generator
    First part done:
  • scottiebabe
    scottiebabe over 2 years ago
    EEVBlog tech tip 100
