PCB Design, Prototyping and Production
PCB Blogs Create a custom footprint in KiCad 7 - 1: collect info and component details
Join PCB Design, Prototyping and Production to participate - click to join for free!
  • Date Created: 21 Jan 2023 12:22 PM Date Created
  • Views 4673 views
  • Likes 8 likes
  • kicad
  • footprint
  • pcb
  • amphenol
  • SF2921-61506
  • SF2921-61506-1S
21 Jan 2023
I'm going to draw my first footprint in the KiCad 7 Footprint editor.
I have experience with previous versions. To try out version 7, I'm going to make one for the Amphenol /  SV Microwave SF2921-61506-1S   SMA coaxial connector. In a first post on KiCad 7, I checked how to import a public domain footprint. This time I will try to mimic the microstripdesign that scottiebabe  spotted in an application note. In this exercise, I will make it single layer, without vias. I don't want to prescribe that the microstrip's reference plane is the bottom layer of a PCB stack. I can always make a second version with reference plane and vias.
Info collection and component details
As comparison, the imported footprint from previous post, the one from the application note with the best view, and the one from the note that I want to achieve:
image source for 2 and 3: Amphenol / SV Microwave app note
The middle pin of the coax connector is best set on a PCB copper layer. It has spring action and does not need a hole. The housing should land on a copper pad that's the size of the connector's footprint. The middle pin's microstrip trace (conductor) should snake out via the opening in the underside of the connector.
image source: Amphenol datasheet on element14 shop, annotated and edited by me
With this info, I should be able to define a footprint that looks approximately like this:
Blog Index
  • Overview: Amphenol / SV Microwave SF2921-61506-1S SMA coaxial connector series
  • Amphenol / SV Microwave SF2921-61506-1S SMA coaxial connector: behavior under vibration
  • Create a custom footprint in KiCad 7 - 1: collect info and component details
  • Create a custom footprint in KiCad 7 - 2a: create the footprint for an SMA coax connector with the editor - initial outline
  • Create a custom footprint in KiCad 7 - 2b: create the footprint for an SMA coax connector with the editor - copper pour, solder mask clearance, holes, pads
  • Use a LibraryLoader Footprint in KiCad 7
    Jan Cumps over 3 years ago
    The stock footprint left, the end result of this blog right.
    With 3D components:
    plain top view:
