Internet of Things
Internet of Things
Blog Road Test notepad: Infineon Blockchain Starter Kit
  • Date Created: 14 Mar 2022 9:58 AM Date Created
  • Views 981 views
  • blockchain
  • rt
14 Mar 2022
This document is a scrapbook for the Infineon Blockchain Starter Kit road test.
1 (YES) see if it is possible to run a blockchain ledger on a Raspberry Pi
Before applying (check this thread that shows several people moving from not interested to interested) we floated some balloons on how to use the kit to show a real world case, and how we could learn from it.
The project will try using hyperledger and blockchain to create a record of trusted transactions.
install hyperledger burrow https://wiki.hyperledger.org/display/burrow
dependency for docker: python 3.6. I don't know if docker is needed , because you can also install from binary and source...
Not needed with latest raspbian. It has version 3.7.
Install python 3.6
https://gist.github.com/dschep/24aa61672a2092246eaca2824400d37f
dependency for hyperledger
Install docker and docker-compose
Not needed if build from source.
https://withblue.ink/2019/07/13/yes-you-can-run-docker-on-raspbian.html
docker-compose --version
If Java is a prereq (yes for the SDK, no for Burrow, I believe):
sudo apt-get install -y openjdk-11-jdk
If building from source
sudo apt install git
get go https://golang.org/doc/install
nano ~/.bashrc
#20200203 jc added  $GOPATH
export GOPATH=$HOME/go
source ~/.bashrc
For deploying contracts you will need a local installation of Solidity
https://solidity.readthedocs.io/en/v0.6.2/installing-solidity.html
failed with ubuntu and docker image
snap: install of snap worked but then the instal of solc not
sudo apt-get install snap
Ah, needs snapd:
sudo apt-get install snapd
sudo snap install solc
2020-02-03T19:44:25+01:00 INFO Waiting for restart...
solc v0.5.2 from Ethereum Build Automation (builds-c) installed
There's an error message.
pi@raspberrypi:~ $ snap run solc
ERROR: ld.so: object '/usr/lib/arm-linux-gnueabihf/libarmmem-${PLATFORM}.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
solc, the Solidity commandline compiler.
I may have a different version than latest raspberry now because I ran sudo raspi-update, as advised by
https://stackoverflow.com/questions/42443273/raspberry-pi-libarmmem-so-cannot-open-shared-object-file-error
sudo mv /etc/ld.so.preload /etc/ld.so.preloadbak
Now Burrow
from source: https://github.com/hyperledger/burrow/tree/master/docs#source
go get github.com/hyperledger/burrow
cd $GOPATH/src/github.com/hyperledger/burrow
make build
To install in ~/go/bin:
make install
Yay
pi@raspberrypi:~/go/bin $ ./burrow --version
0.29.7+commit.v0.29.7-2-gbfa9180e+2020-02-03
Start a session; for test only
The genesys is lost after doing this , so you can't restart burrow. Delete the .burrow subfolder for a fresh start
pi@raspberrypi:~/go/bin $ ./burrow spec -v1 | ./burrow configure -s- | ./burrow start -c-
Sourcing config from first of: Config from STDIN then defaults
Sourcing config from Config from STDIN
Using validator address: 13B9648F4115CBB6E8671AD12012877952B5A995
{"caller":"blockchain.go:55","database_key":"426C6F636B636861696E5374617465","height":0,"log_channel":"Info","message":"Trying to load blockchain state from database","run_id":"1eedf0c6-46c5-11ea-8697-79aff69a1094","scope":"LoadOrNewBlockchain","time":"2020-02-03T20:38:23.038665957Z"}
{"caller":"blockchain.go:76","height":0,"log_channel":"Info","message":"No existing blockchain state found in database, making new blockchain","run_id":"1eedf0c6-46c5-11ea-8697-79aff69a1094","scope":"LoadOrNewBlockchain","time":"2020-02-03T20:38:23.039876582Z"}
{"caller":"kernel.go:125","height":0,"log_channel":"Info","message":"Creating new application state from genesis","run_id":"1eedf0c6-46c5-11ea-8697-79aff69a1094","scope":"NewKernel()","time":"2020-02-03T20:38:23.042889707Z"}
{"caller":"kernel.go:136","height":0,"log_channel":"Info","message":"State loading successful","run_id":"1eedf0c6-46c5-11ea-8697-79aff69a1094","scope":"NewKernel()","time":"2020-02-03T20:38:23.046791685Z"}
{"caller":"service.go:138","component":"tendermint","height":0,"impl":"multiAppConn","log_channel":"Info","message":"Starting multiAppConn","module":"proxy","run_id":"1eedf0c6-46c5-11ea-8697-79aff69a1094","scope":"tendermint.NewNode","time":"2020-02-03T20:38:23.26226321Z"}
A test:
pi@raspberrypi:~/go/bin $ ./burrow accounts
Account: 0000000000000000000000000000000000000000
  Sequence: 0
Account: 13B9648F4115CBB6E8671AD12012877952B5A995
  Sequence: 0
A reusable (not tested in any way for safety!!!) run seed
cd ~/go/bin
Creating a reusable Genesis config file
./burrow spec -v1 | ./burrow configure -s- > startup.cfg
Running and rerunning that burrow , restoring the database:
cat startup.cfg | ./burrow start -c-
If you'd rather want to run that as a background process:
cat startup.cfg | ./burrow start -c-  > ./burrow.log &
You can then check the log by executing
tail -f ./burrow.log
Get info, from browser (replace with your Pi's IP). If you use chrome, install JSON viewer plugin. FF has a default viewer.
http://192.168.1.10:26658
or from the linux prompt
curl localhost:26658/status
Web3: Ethereum interface
http://192.168.1.10:26660/
Tutorial: https://hyperledger.github.io/burrow/#/
Prereq: JSON processor:
sudo apt-get install jq
When doing the Bonding example, check the errata in https://github.com/hyperledger/burrow/issues/1316
instead of
burrow tx --config burrow001.toml formulate bond --amount 10000 | burrow tx commit
do this:
burrow tx --config burrow001.toml formulate bond --amount 10000 > tx.json
burrow tx --config burrow001.toml commit --file tx.json
Trying to link 2, with a seeds node: https://github.com/silasdavis/burrow/blob/develop/docs/tutorials/6-seed-nodes.md
todo: show content
Restart with the 3 files after the seed substitution has been done once:
killall burrow
rm -rf .burrow_node0 .burrow_node1 .burrow_node2 .burrow_seed_0
OLD_URL=$SEED_URL
burrow start --address=`basename .keys_seed/data/* .json` --config=.burrow_seed.toml  > .burrow_seed.log 2>&1 &
SEED_URL=`curl -s 127.0.0.1:10001/network | jq -r '.result.ThisNode | [.ID, .ListenAddress] | join("@") | ascii_downcase'`
sed -i s%${OLD_URL}%${SEED_URL}% .burrow_val0.toml
sed -i s%${OLD_URL}%${SEED_URL}% .burrow_val1.toml
sed -i s%${OLD_URL}%${SEED_URL}% .burrow_val2.toml
burrow start -v=0 --config=.burrow_val0.toml  > .burrow_val0.log 2>&1 &
burrow start -v=1 --config=.burrow_val1.toml  > .burrow_val1.log 2>&1 &
burrow start -v=2 --config=.burrow_val2.toml  > .burrow_val2.log 2>&1 &
curl -s 127.0.0.1:40001/network | jq -r '.result.peers[].node_info.moniker'
curl -s 127.0.0.1:10001/network | jq -r '.result.peers[].node_info.moniker'
curl -s 127.0.0.1:10001/consensus | jq -r '.result.round_state.height'
2. to see if I can write to my cardreader in linux
Detected when enumerating:
Ubuntu VM on Windows10
T:  Bus=02 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#=  3 Spd=1.5 MxCh= 0
D:  Ver= 1.01 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=4242 ProdID=e131 Rev=01.02
S:  Manufacturer=EHUOYAN.COM
S:  Product=RfidLoginer
C:  #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I:  If#=0x0 Alt= 0 #EPs= 1 Cls=03(HID  ) Sub=00 Prot=00 Driver=usbhid
[ 1403.513744] usb 2-2: new low-speed USB device number 3 using ohci-pci
[ 1403.833455] usb 2-2: New USB device found, idVendor=4242, idProduct=e131, bcdDevice= 1.02
[ 1403.833459] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1403.833462] usb 2-2: Product: RfidLoginer
[ 1403.833465] usb 2-2: Manufacturer: EHUOYAN.COM
[ 1403.853390] input: EHUOYAN.COM RfidLoginer as /devices/pci0000:00/0000:00:06.0/usb2/2-2/2-2:1.0/0003:4242:E131.0002/input/input8
[ 1403.911931] hid-generic 0003:4242:E131.0002: input,hidraw1: USB HID v1.01 Keyboard [EHUOYAN.COM RfidLoginer] on usb-0000:00:06.0-2/input0
files generated (but doesn't output anyting)
/dev/hidraw1
Readers advised by Infineon: https://ccid.apdu.fr/select_readers/?features=contactless
This will need rework because the reader I have will not do in its current form
3 SC/PC setup on Linux
The Infinione examples use a python library based on SC/PC.
This is a set of libraries and a service that support accessing card readers and talking to cards.
I have not been able to run this with a smart RFC card reader yet. It works with the ID card reader for Belgian id cards
Tested on Ubuntu VM on my windows 10 laptop
Software needed:
Instructions: https://github.com/Infineon/BlockchainSecurity2Go-Python-Library
sudo apt-get install swig
pip3 install blocksec2go
install PCSC-lite.
service pcscd (start as sudo)
sboxes@osboxes:~/.local/bin$ python3 psycardtest
connecting to Generic Smart Card Reader Interface [Smart Card Reader Interface] sensored
Traceback (most recent call last):
  File "psycardtest", line 78, in <module>
    cardservice.connection.connect()
  File "/home/osboxes/.local/lib/python3.7/site-packages/smartcard/CardConnectionDecorator.py", line 54, in connect
    self.component.connect(protocol, mode, disposition)
  File "/home/osboxes/.local/lib/python3.7/site-packages/smartcard/pcsc/PCSCCardConnection.py", line 126, in connect
    SCardGetErrorMessage(hresult))
smartcard.Exceptions.CardConnectionException: Unable to connect with protocol: T0 or T1. Card is unresponsive.
disconnecting from Generic Smart Card Reader Interface [Smart Card Reader Interface] sensored
4a. (NO) See if hyperledger fabric can run on a raspberry pi
Prereqs: https://hyperledger-fabric.readthedocs.io/en/release-2.0/prereqs.html
(I had everything from installing Burrow, except the golang version. I had 1.11x and 1.13 or higher is needed
https://gist.github.com/nikhita/432436d570b89cab172dcf2894465753#gistcomment-2350191
nano ~/.profile
# 20200229 jc: set PATH so it includes GO
PATH=$PATH:/usr/local/go/bin:$GOPATH/bin
NPM and node.js needed
sudo apt-get install npm
pi@raspberrypi:~/go/bin $ node -v
v10.15.2
pi@raspberrypi:~/go/bin $ npm -v
5.8.0
Proceed with Fabric: https://hyperledger-fabric.readthedocs.io/en/release-2.0/getting_started.html
clone the fabric_samples, then follow instructions in the readme https://github.com/hyperledger/fabric-samples
git clone https://github.com/hyperledger/fabric-samples.git
https://medium.com/swlh/hyperledger-chapter-7-installing-hyperledger-fabric-89430e61b7bb
git clone -b master https://github.com/hyperledger/fabric-samples.git
cd fabric-samples
git checkout 1.3.0-rc1
then stuck at the next command because the dowload folder is gone https://github.com/hyperledger/fabric/releases/download/
The best step guide I found is this one:
https://www.joemotacek.com/hyperledger-fabric-v1-0-on-a-raspberry-pi-docker-swarm-part-1/
unfortunately, hyperledger has just sunset their maven repos on nexus, and the scripts depend on them, so stuck. (https://www.joemotacek.com/hyperledger-fabric-v1-0-on-a-raspberry-pi-docker-swarm-part-2/#comment-16765 , under moderation)
4b. (YES) on a ubuntu VM
prereqs: git, wget, docker, docker-compose, go
I followed the instructions for version 2: https://hyperledger-fabric.readthedocs.io/en/release-2.0/getting_started.html
both prereqs and getting started
raw dump of commands I used. I may clean this up - contains every typo and goof-up
    1  cd ~
    2  pwd
    3  set
    4  exit
    5  pwd
    6  sudo -s -u hyperledger
    7  su osboxes
    8  sudo -s -u hyperledger
    9  exit
   10  sudo -s -u hyperledger
   11  exit
   12  set
   13  echo $PATH
   14  cd ~
   15  whoami
   16  mkdir huperledger
   17  cd hyperledger
   18  cd fabric
   19  rm -fr huperledger
   20  mkdir hyperledger
   21  cd hyperledger
   22  mkdir fabric
   23  cd fabric
   24  git clone https://github.com/hyperledger/fabric-samples.git
   25  ls
   26  cd fabric_samples
   27  ls
   28  cd fabric-samples
   29  git tag
   30  git checkout v1.4.1-rc1
   31  curl -sSL https://goo.gl/6wtTN5 | bash -s 1.1.0
   32  cd
   33  ls
   34  cd
   35  cd ~/hyperledger
   36  ls
   37  cd fabric
   38  ls
   39  rm -fr fabric_samples
   40  python~
   41  python3
   42  sudo apt install -y --no-install-recommends     docker-ce     cgroupfs-mount
   43  apt install -y --no-install-recommends     docker-ce     cgroupfs-mount
   44  sudo apt install -y --no-install-recommends     docker-ce     cgroupfs-mount
   45  sudo apt install -y      apt-transport-https      ca-certificates      curl      gnupg2      software-properties-common
   46  curl -fsSL https://download.docker.com/linux/$(. /etc/os-release; echo "$ID")/gpg | sudo apt-key add -
   47  # Add the Docker official repos
   48  echo "deb [arch=armhf] https://download.docker.com/linux/$(. /etc/os-release; echo "$ID") \
   49       $(lsb_release -cs) stable" |     sudo tee /etc/apt/sources.list.d/docker.list
   50  # Install Docker
   51  # The aufs package, part of the "recommended" packages, won't install on Buster just yet, because of missing pre-compiled kernel modules.
   52  # We can work around that issue by using "--no-install-recommends"
   53  sudo apt update
   54  sudo apt install -y --no-install-recommends     docker-ce     cgroupfs-mount
   55  sudo apt-get remove docker docker-engine docker.io containerd runc
   56  sudo apt-get update
   57  sudo apt-get install     apt-transport-https     ca-certificates     curl     gnupg-agent     software-properties-common
   58  curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
   59  apt-key fingerprint 0EBFCD88
   60  sudo add-apt-repository    "deb [arch=amd64] https://download.docker.com/linux/ubuntu \
   61     $(lsb_release -cs) \
   62     stable"
   63  sudo apt-get update
   64  sudo apt-get install docker-ce docker-ce-cli containerd.io
   65  docker --version
   66  docker-composer --version
   67  docker-compose --version
   68  sudo systemctl start docker
   69  sudo systemctl enable docker
   70  sudo usermod -a -G docker hyperledger
   71  docker-compose --version
   72  sudo apt  install docker-compose
   73  docker-compose --version
   74  go --version
   75  whereis go
   76  sudo add-apt-repository ppa:longsleep/golang-backports
   77  sudo apt update
   78  sudo apt install golang-go
   79  go
   80  whereis go
   81  ls
   82  cd
   83  ls
   84  ls -a
   85  cd .local
   86  lq
   87  ls
   88  cd ..
   89  pwd
   90  ls -l
   91  nano .profile
   92  . .profile
   93  echo $GOPATH
   94  npm
   95  sudo apt install npm
   96  node --version
   97  nodejs --version
   98  pwd
   99  ls
  100  cd hyperledger
  101  ls
  102  cd fabric
  103  ls
  104  cd fabric-samples
  105  ls
  106  git status
  107  cd
  108  ls
  109  cd hyperledger
  110  ls
  111  cd fabric
  112  ls
  113  rm -fr fabric-samples
  114  git clone https://github.com/hyperledger/fabric-samples.git
  115  cd fabric-samples
  116  git tag
  117  git checkout v2.0.0-beta
  118  ls
  119  cd
  120  rm -fr fabric-samples
  121  curl -sSL https://bit.ly/2ysbOFE | bash -s -- 2.0.1 1.4.6 0.4.18
  122  sudo curl -sSL https://bit.ly/2ysbOFE | bash -s -- 2.0.1 1.4.6 0.4.18
  123  sudo groupadd docker
  124  sudo usermod -aG docker ${USER}
  125  su -s ${USER}
  126  echo $USER
  127  su -s hyperledger
  128  exit
  129  sudo -s -u hyperledger
  130  exit
  131  pwd
  132  cd hyperledger
  133  ls
  134  cd fabric
  135  docker run hello-world
  136  cd fabric-samples
  137  ls
  138  curl -sSL https://bit.ly/2ysbOFE | bash -s -- 2.0.1 1.4.6 0.4.18
  139  ls
  140  cd bin
  141  ls
  142  nano .profile
  143  n
  144  nano  .profile
  145  nano ~/.profile
  146  . ~/.profile
  147  echo $PATH
  148  cd /
  149  cd fabric-samples/test-network
  150  cd hyperledger
  151  pwd
  152  cd ~/hyperledger
  153  cd fabric-samples/test-network
  154  cd fabric
  155  cd fabric-samples/test-network
  156  ./network.sh -h
  157  ./network.sh down
  158  ./network.sh up
  159  docker ps -a
  160  ./network.sh createChannel
  161  ./network.sh down
  162  ./network.sh up createChannel
  163  ./network.sh deployCC
  164  export PATH=${PWD}/../bin:${PWD}:$PATH
  165  export FABRIC_CFG_PATH=$PWD/../config/
  166  export CORE_PEER_TLS_ENABLED=true
  167  export CORE_PEER_LOCALMSPID="Org1MSP"
  168  export CORE_PEER_TLS_ROOTCERT_FILE=${PWD}/organizations/peerOrganizations/org1.example.com/peers/peer0.org1.example.com/tls/ca.crt
  169  export CORE_PEER_MSPCONFIGPATH=${PWD}/organizations/peerOrganizations/org1.example.com/users/Admin@org1.example.com/msp
  170  export CORE_PEER_ADDRESS=localhost:7051
  171  peer chaincode query -C mychannel -n fabcar -c '{"Args":["queryAllCars"]}'
  172  export CORE_PEER_TLS_ENABLED=true
  173  export CORE_PEER_LOCALMSPID="Org2MSP"
  174  export CORE_PEER_TLS_ROOTCERT_FILE=${PWD}/organizations/peerOrganizations/org2.example.com/peers/peer0.org1.example.com/tls/ca.crt
  175  export CORE_PEER_MSPCONFIGPATH=${PWD}/organizations/peerOrganizations/org2.example.com/users/Admin@org1.example.com/msp
  176  export CORE_PEER_ADDRESS=localhost:9051
  177  peer chaincode query -C mychannel -n fabcar -c '{"Args":["queryAllCars"]}'
  178  cd organisations
  179  ls
  180  export CORE_PEER_TLS_ENABLED=true
  181  export CORE_PEER_LOCALMSPID="Org2MSP"
  182  export CORE_PEER_TLS_ROOTCERT_FILE=${PWD}/organizations/peerOrganizations/org2.example.com/peers/peer1.org2.example.com/tls/ca.crt
  183  export CORE_PEER_MSPCONFIGPATH=${PWD}/organizations/peerOrganizations/org2.example.com/users/Admin@org2.example.com/msp
  184  export CORE_PEER_ADDRESS=localhost:9051
  185  peer chaincode query -C mychannel -n fabcar -c '{"Args":["queryAllCars"]}'
  186  cd organizations
  187  ls
  188  cd peerOrganizations
  189  ls
  190  cd org2.example.com
  191  cd peers
  192  ls
  193  cd peer0.org2.example.com
  194  ls
  195  cd tls
  196  ls
  197  cd ../../../..
  198  cd ../..
  199  export CORE_PEER_TLS_ENABLED=true
  200  export CORE_PEER_LOCALMSPID="Org2MSP"
  201  export CORE_PEER_TLS_ROOTCERT_FILE=${PWD}/organizations/peerOrganizations/org2.example.com/peers/peer0.org2.example.com/tls/ca.crt
  202  export CORE_PEER_MSPCONFIGPATH=${PWD}/organizations/peerOrganizations/org2.example.com/users/Admin@org2.example.com/msp
  203  export CORE_PEER_ADDRESS=localhost:9051
  204  peer chaincode query -C mychannel -n fabcar -c '{"Args":["queryAllCars"]}'
  205  hystory > hystory.log
  206  history > history.log
5: Run your own Ethereum full node on a Pi (4)
https://kauri.io/running-an-ethereum-full-node-on-a-raspberrypi-4-m/9695fcca217f46feb355245275835fc0/a
Requires an SSD card
For my own memory: cards/keys with ropsten ether loaded:
Card Key
1 1
2 1, 2
Related Blog
Blockchain - HyperLedger Fabric pt 1: post and search transactions on a distributed trusted ledger
Blockchain - Hyperledger Burrow: set up a distributed ledger
Blockchain - Get Some Crypto Currency on an Infineon Security 2Go Card
Blockchain - Debug the Infineon Demo App with Android Studio and Your Phone
Blockchain - Analyse the Infineon Android Demo App - part a: Detect Card
Blockchain - Analyse the Infineon Android Demo App - part b: Retrieve Ethereum Crypto Currency Balance
Blockchain - Analyse the Infineon Android Demo App - part c: Transaction, Move Crypto Currency to Another Account
Blockchain - Talk Directly to the Infineon 2Go Smart Cards API
Blockchain - Smart Contract Test
Infineon Blockchain Starter Kit - Review
Blockchain - HyperLedger Fabric pt 2: application using blockchain and smart contract
Blockchain - HyperLedger Fabric pt 3: web console
