Test & Tools
Test & Tools
Forum New Rigol dho804 oscillocope
  • Replies 82 replies
  • Subscribers 379 subscribers
  • Views 13618 views
ahmedfotoh
ahmedfotoh over 1 year ago
imageI just bought a new Rigimage
ol Dho804 Oscilloscope, but there is a problem, I connect the attached power supply to the 220 v power source and turn it on but the display stays black and no boot to the operating system, What should I do?
    michaelkellett over 1 year ago in reply to geralds +3
    I'll try to get round to a mini road test of the DHO924 in a couple of weeks. MK
    dougw over 1 year ago +2
    Check the power supply - is it providing the right voltage to the main controller card?
  • cstanton
    cstanton over 1 year ago in reply to ahmedfotoh +2
    Was this the original power supply you received with the device? If not, have you looked at the manual/datasheet for the oscilloscope to see what voltage and amps it requires from the power supply?
  • anniel747
    0 anniel747 over 1 year ago in reply to Andrew J
    [deleted]
  • Andrew J
    0 Andrew J over 1 year ago in reply to anniel747
    Yeh....especially during the startup tests which might explain why it gets so far and then restarts.  It's quite a slow startup machine from what I can see.
  • anniel747
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to Andrew J
    I send email include the photo of power adapter to Rigol service, But he didn't mention that the problem is charger he said that the problem is software. "
    • Press the power button and quickly press the BACK button on the front panel multiple times. This may reset any incorrect settings.
    • Alternatively, place the latest firmware on a FAT32 USB drive, power on the device, and follow the on-screen prompts to upgrade the firmware.
  • anniel747
    0 anniel747 over 1 year ago in reply to ahmedfotoh
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to anniel747
    Not yet, I will try to do that
    0 michaelkellett over 1 year ago in reply to Andrew J
    The Liteon psu that comes with the scope does provide 15V at enough current to work the scope. The scope current starts off at about 0.8A and rises in steps during boot up.
    I had a lot of trouble with power sources and cables and the order of starting things to get the FNB58 to work. Other USB monitors that I have don't have the correct gender of connectors to connect the Liteon psu to the Rigol. The FNB58 only works if the scope is connected after the FNB58 has woken up. My power bank can't work the scope - its OK until the last stage of the bootup ( scope screen lights up and the scope display shows along with a lot of relay clicking) the current goes up to about 2.3A at that point.
    I don't think Ahmed has a psu problem - I've proved that the scope draws about 0.8A when showing the Rigol name so his psu is at least that functional. My scope has the same psu and works fine.
    If he had a faulty psu that couldn't manage full working current he would get the relay clicking or other signs before it cut off.
  • geralds
    0 geralds over 1 year ago in reply to anniel747
     Hi  ahmedfotoh  you need a 15V 3A DC power supply with THIS USB C connector.
    Please look on the back side on your scope:
    So, if you have another device this is wrong. May be that Rigol provide a universal power supply.
    But the cord with such USB connector AND with this coding pin must be mounted into the power supply.
    In the manual is a caution (page 13) that you do not use the PS for other devices.
    Here the official website:
    https://www.rigolna.com/products/rigol-digital-oscilloscopes/dho800/
    Please read careful the manual.
    Well USC C has power wires that are "normally" mounted mirrored on the plug, but not a universal power supply.
    So, you can rotate ("normally single voltage"), but not this for the Rigol.
    Regards
    Gerald
  • ahmedfotoh
    0 ahmedfotoh over 1 year ago in reply to geralds
     geralds  Ok , Thank you very much for this clarification, I understand that the my adapter i not the proper one and I need another one has 15V 3 A but it has the same terminal of Rigol no the universal Type C one?
    How can I update its firmware without turn on the device ?
    0 michaelkellett over 1 year ago in reply to geralds
    It is possible that the DHO8xx is different from the DHO9xx - but as you can see from the picture above my DHO924S is being powered and working with its own PSU plugged into the FNB58 USB meter and a standard (but good quality) USB C cable connecting the FNB58 to the Rigol scope.
