Test & Tools
Test & Tools
Documents Keithley Linecard
  • Author Author: Yiying
  • Date Created: 29 Nov 2012 3:27 AM Date Created
  • Last Updated Last Updated: 7 Mar 2014 9:01 PM
  • Views 1453 views
Keithley Linecard
Power Supplies | Digital Multimeters
Power SuppliesBack to Top
Product Series
ModelsMax. Power OutputMax. Voltage OutputMax. Current Output Description
2302/2306
23022302
23062306
6015 V3A
The single-channel Model 2302 Battery Simulator and dual-channel Model 2306 2306 Battery/Charger Simulator were designed specifically for development and test applications of portable, battery-operated products, such as cellular and cordless telephones, mobile radios, and pagers. Learn More
2303/2304
23032303
2304A2304A
100 W20V5A
The Model 2303/2304A Power Supplies provide both voltage control and power consumption monitoring for automated testing of portable, battery-operated devices. Learn More
2308 2308 2308
50W
15V3A
The Model 2308 Portable Device Battery/Charger Simulator is optimized for use in testing mobile phones and other portable, battery-operated devices. When a device-under-test (DUT) transitions nearly instantaneously from a sleep or standby mode to the full power transmit state, the Model 2308 's rapid response to load changes means there's little transient voltage drop from the programmed output voltage and the output recovers quickly. Learn More
2200
2200-20-52200-20-5
2200-30-52200-30-5
2200-32-32200-32-3
2200-60-22200-60-2
2200-72-12200-72-1
100 W
150 W
96 W
150 W
86 W
20V
30V
32V
60V
72V
5A
5A
3A
2.5A
1.2A
The Series 2200 Programmable DC Power Supplies provide a wide range of voltage outputs to address the testing and characterization of components, circuits, modules, and complete devices whether you are in a research laboratory, in design and development, or in production test. Learn More
Digital Multimeters (DMM)Back to Top
Product Series
ModelsMeasurementsResolution DigitsDC AccuracyDescription
Integra
27002700
27012701
27502750
DC/AC Voltage, Current, Resistance, Continuity, Diode Test, Temperature6.5 Digit100mV to 1KV
Integra Series systems (2700, 2701,2750), DC power supply products, combine precision measurement, switching, and control in a single, tightly integrated enclosure for either rack-mounted or benchtop applications. Learn More
2000
2000 2000
2001 2001
20022002
20102010
2015 2015
20162016
6.5 Digit
7.5 Digit
8.5 Digit
7.5 Digit
6.5 Digit
6.5 Digit
1000V
1100V
1100V
1000V
1000 V
1000 V
2000 Series Digital Multimeter offers a unique combination of measurement capabilities that make them ideal for high speed production testing. Their half-rack design fits easily into just about any test rack or benchtop. With maximum resolutions from 61.2 to 81.2 digits and a variety of built-in capabilities, there's sure to be a Series 2000 DMM that matches your application. Learn More
