    • Avnet Boards Community
Test & Tools
Test & Tools
Forum New Rigol dho804 oscillocope
  • Replies 82 replies
  • Subscribers 350 subscribers
  • Views 5378 views
ahmedfotoh
ahmedfotoh 5 months ago
imageI just bought a new Rigimage
ol Dho804 Oscilloscope, but there is a problem, I connect the attached power supply to the 220 v power source and turn it on but the display stays black and no boot to the operating system, What should I do?
    michaelkellett 5 months ago in reply to geralds +3
    I'll try to get round to a mini road test of the DHO924 in a couple of weeks. MK
    dougw 5 months ago +2
    Check the power supply - is it providing the right voltage to the main controller card?
  • cstanton
    cstanton 5 months ago in reply to ahmedfotoh +2
    Was this the original power supply you received with the device? If not, have you looked at the manual/datasheet for the oscilloscope to see what voltage and amps it requires from the power supply?
  • anniel747
    anniel747 5 months ago
    This reply was deleted.
  • ahmedfotoh
    0 ahmedfotoh 5 months ago in reply to anniel747
    I use  the power adaptor provided in the accessories box and I connect it to the AC power source (220 V, 50 Hz ).
  • ahmedfotoh
    0 ahmedfotoh 5 months ago in reply to michaelkellett
    michaelkellett  Ok, thank you. Do you know which the Back button in the front panel that Rigol service mean
    0 michaelkellett 5 months ago in reply to ahmedfotoh
    It's not clear in the 924s manual but I think they might mean this key:
  • ahmedfotoh
    This one
    Do you know how to ubdate scope firmware, I download the file from Rigol site "" rel="noopener noreferrer nofollow" target="_blank" data-e14adj="t">supportint.rigol.com/.../software-firmware-download.html"
    It looks to me as if the scope must be working to update the firmware - you put the new code on a USB stick, plug into the scope and open the file. Which means you need to have it working well enough to work the disk management functions.
    There is a .pdf file (which may have cold boot instructions) at the link you gave me but it won't let me look at it (no password) but you might be able to look.
    There are some more ideas here:
    www.eevblog.com/.../
  • anniel747
    anniel747 5 months ago in reply to Andrew J
  • Andrew J
    0 Andrew J 5 months ago in reply to anniel747
    Nope.  He has a 15V 3A PD supply (so could supply different voltages) but the manual he is reading says he needs 12V 4A.
    • Vote Up -1 Vote Down
  • anniel747
    0 anniel747 5 months ago in reply to ahmedfotoh
  • anniel747
  • Andrew J
    Yes, sorry, you are right, it does both.  The scope manual he is referring to says it needs 4A at 12V; a newer version of the manual says the scope needs 3A at 15V.  Either way, 12V/3A is not the right supply power.
  • anniel747
  • anniel747
  • Andrew J
    Yeh....especially during the startup tests which might explain why it gets so far and then restarts.  It's quite a slow startup machine from what I can see.
  • anniel747
    0 anniel747 5 months ago in reply to Andrew J
  • ahmedfotoh
    0 ahmedfotoh 5 months ago in reply to Andrew J
    I send email include the photo of power adapter to Rigol service, But he didn't mention that the problem is charger he said that the problem is software. "
    • Press the power button and quickly press the BACK button on the front panel multiple times. This may reset any incorrect settings.
    • Alternatively, place the latest firmware on a FAT32 USB drive, power on the device, and follow the on-screen prompts to upgrade the firmware.
  • anniel747
  • ahmedfotoh
    Not yet, I will try to do that
