Blog [CaTS] ForgetMeNot - Week 11: Starting the build
  • Author Author: fvan
  • Date Created: 13 Oct 2014 7:11 AM Date Created
  • Views 996 views
  • forget_me_not
  • design_challenge
  • openhab
  • tektronix
  • rpisoc
  • iot_pet_care
  • eclipse
  • internet_of_things
  • enocean
  • cats
  • raspberrypi
  • smarthome
  • challenge
  • iot
  • enocean_pi
fvan
fvan
13 Oct 2014
Previous posts for this project:
  • [CaTS] ForgetMeNot - Index
  • [CaTS] ForgetMeNot - Week 0: Project Description
  • [CaTS] ForgetMeNot - Week 1: EnOceanPi and Sensors
  • [CaTS] ForgetMeNot - Week 2: Elro CoCo and Pi Cam with OpenHAB
  • [CaTS] ForgetMeNot - Week 3: Data persistence and charts with OpenHAB
  • [CaTS] ForgetMeNot - Week 4: Arduino-OpenHAB communication
  • [CaTS] ForgetMeNot - Week 5: Getting familiar with EAGLE
  • [CaTS] ForgetMeNot - Week 6: Getting to know the TBS1052B-EDU oscilloscope
  • [CaTS] ForgetMeNot - Week 7: First tests with RPiSoC
  • [CaTS] ForgetMeNot - Week 7 (2): More testing with RPiSoC
  • [CaTS] ForgetMeNot - Week 8: Water dispenser and temperature
  • [CaTS] ForgetMeNot - Week 9: RFID Cat detection and identification
  • [CaTS] ForgetMeNot - Week 10: Peltier cooling experiment
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean sensor bracket
  • [CaTS] ForgetMeNot - 3D Printing: EnOcean rocker switch and magnet holder
  • [CaTS] ForgetMeNot - 3D Printing: Food dispenser prototype
  • [CaTS] ForgetMeNot - 3D Printing: Weighing scale
  • [CaTS] ForgetMeNot - Security: Some basic tips
  • [CaTS] ForgetMeNot - Minion: Dave, the gassy minion
  • [CaTS] ForgetMeNot - Pi Camera: Wide Angle Lens
  • Introduction
  • Sketch
  • Front
  • Back
This weekend I started building the frame of my pet care system, which will hold all the different modules used over the past weeks.
I got some wood, screws, etc ... from the hardware store and started building. This is the progress so far.
Hopefully, I'll be able to unveil the final build before the end of the challenge image
Sketch
I had a rough idea in mind of what the build would look like, but no precise measurements.
Taking a piece of wood and some of the components, I sketched where I would place them.
The base ended up becoming a reasonable 36x36cm where I would use half of it for the bowls, RFID readers and load cells, and the other half for the two containers and the rest of the electronics.
I'm taking a step by step approach, keeping options open as I progress with the build.
Front
With some dimensions to work with, I started working on the front part of the build.
This part houses the following components:
- 2x RFID readers with Arduino UNO
- 2x scales with 1kg load cell
- 2x bowls
I cut the MDF to the correct dimensions using a table saw and created a basic box.
Fitting the weighing scales inside, I determined where to cut the holes for the two bowls.
The dimensions are such, that the bowl will rest on the weighing scale, and not on the wood. This is obviously important in order to be able to weigh the contents accurately.
The hole's purpose is to keep the bowl in place above the scale and to keep it removable for washing.
I wasn't entirely happy with the quality of some prints, so I decided to redo them. I was able to resolve my lifting problems, so the new prints came out much nicer.
With the parts reprinted, I fitted them into the front part of the build.
So this is where the front part stands now, what do you think ?
Back
I'll be working on the back side of the build now, I hope to be able to post an update by the end of the week.
  • fvan
    fvan over 12 years ago in reply to mcb1
    Thanks Mark.
    You cheated by using wood (since you have a 3D printer)
    With a possible print dimensions of maximum 10x10x10 cm, it would have taken ages!
    it needs a good sealer unless you like it growing with the moisture.
    I plan to treat the MDF before final assembly, but yes indeed. I do find MDF easy to work with though.
    I presume the cats have chosen their favorite colour.??
    I have yet to present them some colour swatches, so we'll see what they come up with!
    mcb1 over 12 years ago
    Nice job.
    You cheated by using wood (since you have a 3D printer) but the new parts look great.
    MDF is hard on blades, and it needs a good sealer unless you like it growing with the moisture.
